Racing 6DOF stewart platform
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Feb 15, 2019.
  1. Gadget999
    12,331Coins
  2. luu trung
    luu trung Member
    172Coins
    What is the difference between 1800 rpm and 3000 rpm engine and 135 rpm and 75 rpm gearbox?
  3. Gadget999
    12,331Coins
    some motors have different max rpms
    the output shaft from the gearbox can have different ratios
    the slower the rpm, the slower the speed of the actuator will be
    however - the gearbox ratio will affect how much torque the output has
    choose the most powerful motor you can get and a gearbox ratio between 50:1 and 30:1
  4. Gadget999
    12,331Coins
    I have done some work on the air bags to create a sustained G affect
    its a pnematic cylinder I had laying about that acts in both directions - I will connect it to an actutator soon and get simtools to drive it
    https://www.youtube.com/shorts/6pARdaAAItE
  5. Gadget999
    12,331Coins
    another video of the airbag pump
    its basically an arduino nano running SMC3 software and a wheelchair motor and gearbox
    it uses a lot more current than I expected - the air resists being forced up the small diameter tubes - the big motor does the job forcing the air where it needs to be, a very fast response
    you can feel small changes in the force change as the car looses grip - quite a useful addition and adds another feedback to the senses of the driver.
  6. Gadget999
    12,331Coins
    Over time it appears the bags are pumping up and becoming firmer.
    The piston seal in the cylinder seems to leak a tiny bit sucking in air on the backstroke.
    Simple solution was to fit 2x small pressure relief valves so any pressure above a few psi is blown off
    Seems to work really well and ensures the air bags can't be overinflated
  7. Rodrigomarcos1978
    Rodrigomarcos1978 New Member
    Brasil
    103Coins
    hello.. I'm on my 10th project here with motions in Brazil, where I live. I decided to start a new project with wheelchair motors, but it didn't work out initially because the IBT2 bridges didn't support it.. So I found your post here and bought two of those 100A bridges, one for each motor.. However, I don't have the electrical schematic for connecting the Arduino to this 100A H bridge and I didn't quite understand the correspondence between the terminals... Could you share the wiring diagram you used? thanks !!
  8. Gadget999
    12,331Coins
    If i remember correctly It uses a pwm pin and 2 direction pins
  9. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
  10. Gadget999
    12,331Coins
    the motor driver has a positive and a negative connection - the battery connects there
  11. absyfadhel1
    bahrain
    556Coins
    so the power positive and negative come from psu to battery , and from battery to motor controller?
  12. Gadget999
    12,331Coins
    No
    Wire the battery to the motor controller
    Then attach wires from the power supply to the battery - just like a battery charger
  13. absyfadhel1
    bahrain
    556Coins
    oh ok Thanks alot bro.
  14. luu trung
    luu trung Member
    172Coins
    how can your device move like that?
    -with asseto cosa compention?
  15. noorbeast
    154,750Coins
    +11,196 / 57 / -2
  16. Doga Darko
    Doga Darko New Member
    TR
    141Coins
    Would you provide me a link for buying them there is a lot of cheap copy of them.
    Can't find the seller on Ali express
    JIE BO technology rf amplifier store.
    Thnx
