radist07's rig
Discussion in 'DIY Motion Simulator Projects' started by radist07, Mar 11, 2023.
  1. noorbeast
    154,576Coins
    +11,190 / 57 / -2
  2. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I changed the Language to English and everything worked!!!! Thank you so much for helping me fix the problem
    154,576Coins
    +11,190 / 57 / -2
    Great to know!
    SimTools v3, which is currently in open Beta testing, is believed to resolve this particular Windows related bug.
  4. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Let's hope that the version improvement will work
  5. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Good day! I found another problem, sometimes one of the motors stops working. when I reboot the arduino, everything starts working again.Where can I look for the cause of the failure
    154,576Coins
    +11,190 / 57 / -2
    That can be a combination of hardware issues and SimTools settings.
    I suspect it is triggered by a USB disconnect: https://www.xsimulator.net/community/faq/simtools-usb-issues-can-cause-crashes.313/
    You can try lowering the profile to around 96%, and see if that lessons the disconnects.
  7. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I also forgot to say, this motor has a heated driver.The settings on all motors are the same.Maybe the problem is in the driver?
    154,576Coins
    +11,190 / 57 / -2
    If there is just one heated driver that may be an issue, is that the case?
  9. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Yes, only one driver heats up, and the motor stops working
    154,576Coins
    +11,190 / 57 / -2
    That would suggest investigation is required, to determine a cause. Do the drivers have heatsinks/fans to assist with cooling?
  11. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    IBT-2 drivers, with radiators. It is heated only by motor No. 2, motor No. 1 and No. 3 have cold radiators.
