(Resolved - user error) Yaw issue with DCS plugin and G-Seat
Discussion in 'Digital Combat Simulators (DCS)' started by RiftFlyer, May 7, 2016.
  1. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
    I need to test it further before I send it to @value1. It will be up to him to decide to make it available as it is his plugin with only a little added code from me.
  2. RiftFlyer
    1,711Coins
    DC motor
    @Adrianstealth Have you tried adding filters on your roll axis (smoothing or washout)?
  3. RacingMat
    21,066Coins
  4. Historiker
    Michigan USA
    9,214Coins
    Because I have not posted it :grin
  5. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Riftflyer
    Yes tried both but onto like results nothing stop the erratic flip back at 180 degrees except a dull dead zone or
    Effects become unclean/jumbled
    So not using roll until its suitable for rocker seat style setups
  6. RiftFlyer
    1,711Coins
    DC motor
    I think I've managed to resolve the roll 'issue' with the reset after 180 degrees.
    I've found the turn needle variable for several aircraft and it may work as a good substitute for roll. It outputs a force based on rate of rotation and it seems to be continuous throughout a full 360 degree roll maneuver. I'm still working on a function to return it for some of the more complex aircraft. Unfortunately some of the modern glass cockpit jets don't use this old analogue instrument but I'm hopeful I can find an equivalent in their code.
    If successful both turn and slip forces for extra1 and extra2 respectively may provide improved motion for both G-seats and Seat movers and possibly will allow for yaw and roll to be avoided altogether thereby avoiding the issue with them resetting.
  7. RiftFlyer
    1,711Coins
    DC motor
    After some testing it has been found the turn needle is not usable. It oscillates too much on return to centre and is too sensitive.
    I have adapted the export.lua to return a new extra value which is the rate of change of the bank angle over time. This will output a force based on roll rate and not roll angle. I hope this will be useful for people who don't like the way roll switches sides at 180 degrees.
    Currently testing and I will release this new plugin if testing is successful.
