value1
rFactor2 Plugin 2.0.4.0
SimTools game plugin for rFactor2
  1. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    The game is not open source, and I doubt game devs will change anything for this purpose. I am not familiar with Simtools plugins, but it is no more than 1-2 lines of code to check if game is paused based on value of some fields. If needed, I can figure out and suggest exact best way for rF2, but it can be done in multiple ways.
    154,699Coins
    +11,210 / 57 / -2
    I was not suggesting having the RF2 devs fix the issue is the only way, just that it is the ideal way. Have you contacted the devs and asked?
  3. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    I contacted devs of multiple racing games for their data fixes over the last 3 years. Guess how many fixes I got? - 0.0 . That route is hopeless :(
  4. value1
    14,294Coins
    I'll have a look at the plugin when time allows me. :)
  5. Nick Moxley
    17,057Coins
    Kunos fix stuff all the time based on user input and beta testers. :thumbs:thumbs
  6. franckk06
    franckk06 New Member
    france
    213Coins
    bonjour,
    est ce quelqu'un pourrait me donner des points pour le plug in de rfactor 2, je ne suis pas très actif car je ne suis pas aussi connaisseur que vous dans le domaine du diy, merci
    154,699Coins
    +11,210 / 57 / -2
  8. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Hi @value1 ,
    I hope you are doing fine. I am providing a feedback to a mod dev, and with his cars I do not get surge punch on upshift (it works on majority of other content). Could you share how exaclty do you calculate surge component from the rF2 telemetry, as mod developer would like to know what telemetry to investigate?
    Cheers!
    154,699Coins
    +11,210 / 57 / -2
    Have you tried a lower Max value than Min in the Tuning Center: https://www.xsimulator.net/community/faq/snappy-gear-change-motion.121/
  10. Gadget999
    12,341Coins
    i dont seem to be able to download the rfactor 2 plugin
    i have an older version but i cant seem to get any motion
    any suggestions ?
    i have the pro version of simtools - is it possible it has not updated correctly
    can somebody share the plugin pls
    154,699Coins
    +11,210 / 57 / -2
    Plugins should not be shared, we already have mechanisms in place for plugin access: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    So when you say you are unable to download the plugin please supply more details as to what the issue is, as I just tested the Rfactors 2 plugin download and it works fine.
  12. Gadget999
    12,341Coins
    Maybe i am looking in the wrong place
    It tells me the plugin in not available for download :-(
  13. noorbeast
    154,699Coins
    +11,210 / 57 / -2
    You need to use 250 of your coins here to purchase a weeks access to all plugins: https://www.xsimulator.net/community/shop/
  14. Gadget999
    12,341Coins
  15. Smollett
    Smollett New Member
    Russia
    86Coins
    SOS. Problem detected. When the SimTols plugin is enabled, in rFactor2, it is not possible to create your own dedicated server. He falls right there. With the plugin disabled, everything works well, but without SimTools. Urgent help needed.)
  16. noorbeast
    154,699Coins
    +11,210 / 57 / -2
    I don't have an answer but by any chance does setting up a server create a possible port conflict?
  17. Smollett
    Smollett New Member
    Russia
    86Coins
    most likely this is a port conflict. What to do about it? I do not have a router, all ports are open.
  18. noorbeast
    154,699Coins
    +11,210 / 57 / -2
    There are exceptions, like Codemaster, but most games only output to one IP : Port address.
    Perhaps try something like the Sim Racing Proxy Server: http://www.eksimracing.com/srps/
    Maybe @yobuddy, @value1, or other members have some more ideas.
  19. Smollett
    Smollett New Member
    Russia
    86Coins
    already. thank.
  20. Smollett
    Smollett New Member
    Russia
    86Coins
    he does not respond
