value1
rFactor2 Plugin 2.0.4.0
SimTools game plugin for rFactor2
  1. MrSmurgle
    MrSmurgle CTO @ gagarin.is
    CTO & Software developer @ gagarin.is
    Reykjavík, Iceland
    351Coins
    I am not sure if this helps the developer of the plugin but I get this error every time I exit rFactor and the Game Manager crashes. I have a vanilla rFactor2/SimTools setup but added the rFactor2 plugin and Game Dash.
    System.NullReferenceException: Object reference not set to an instance of an object.
    at rFactor2_Plugin.Plugin.ShutDownCommands()
    at SimTools_GameManager.Mod_Lib.GameStoped()
    at SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
    Assembly Version: 0.1.2.0
    Win32 Version: 0.1.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 12.0.20806.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    Win32 Version: 4.0.30319.34107 built by: FX45W81RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/PluginAPI.DLL
    LiveForSpeed_Plugin
    CodeBase: file:///C:/Users/Sammi/AppData/Local/SimTools/GamePlugins/LiveForSpeed_Plugin.dll
    rFactor2_Plugin
    Assembly Version: 3.0.3.5
    Win32 Version: 3.0.3.5
    CodeBase: file:///C:/Users/Sammi/AppData/Local/SimTools/GamePlugins/rFactor2_Plugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
  2. value1
    14,294Coins
  3. yobuddy
    51,746Coins
  4. value1
    14,294Coins
  5. MrSmurgle
    Reykjavík, Iceland
    351Coins
    I have two questions regarding this brilliant plugin.
    - Can the ShiftUp & ShiftDown properties be used as shift indicators? What are these properties for?
    - What can be the problem if the plugin does not seem to work at all? On my home computer the plugin icon ( top left corner ) does not show up at all - and hence no data gets reported in Game Dash.
    Best
  6. value1
    14,294Coins
    Did you patch the game at home?
    Yes, the ShiftUp turns on when the RPM are above the MaxRPM. That's the way, the shift light is defined in rFactor2.
    The ShiftDown goes on, when the RPM is below 20% of MaxRPM. This is just my definition
  7. MrSmurgle
    Reykjavík, Iceland
    351Coins
    Yes I did patch and got a "success" message. I really have no idea what could be wrong. I even uninstalled everything and installed again ( the game, the plugins and Game Dash ). I can't image what I am doing wrong because it isn't exactly rocket science to install it :) I will try to patch again.
    Great to know that I can use these two properties for my shift lights. However, I guess it would be super useful for those that are using LEDs to create an RPM indicator if your plugin would output "mEngineMaxRPM". I saw the following code in the example rFactor2 InternalsPlugin so the game must be reporting it.
    // Vehicle status
    fprintf( fo, "Gear=%d RPM=%.1f RevLimit=%.1f\n", info.mGear, info.mEngineRPM, info.mEngineMaxRPM );
    fprintf( fo, "Water=%.1f Oil=%.1f\n", info.mEngineWaterTemp, info.mEngineOilTemp );
    fprintf( fo, "ClutchRPM=%.1f\n", info.mClutchRPM );
    I am not sure what mClutchRPM does but it sounds useful. I also thought that it would be useful if our Arduinos could know which car is being driven. Then we could have the Arduino customize its output based on the car.
    fprintf( fo, "Vehicle=%s\n", info.mVehicleName );
    I wish I knew C++ because then I would be happy to help you with the plugin. But unfortunately I am really bad at C++!
  8. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Question about 64bit.
    I'm now testing the 64bit unstable version of rfactor 2, is there a 64bit update planned ?
  9. Rinus janssens
    Holland
    2,153Coins
    SCN5
    With the release of Build 770 this week rFactor 2 goes definitely 64bit.
    Is a 64bit plugin to be expected or are you guys working on such a plugin ?
  10. value1
    14,294Coins
    I will see if I have some time at the weekend
  11. Rinus janssens
    Holland
    2,153Coins
    SCN5
    Nice one, I can't wait :cheers:grin:thumbs
  12. domsai
    domsai New Member
    - 61Coins
    2DOF, SCN5
    Cool, hope at the weekend
  13. value1
    14,294Coins
    • Winner Winner x 3
  14. value1
    14,294Coins
    Done :)
  15. Rinus janssens
    Holland
    2,153Coins
    SCN5
    Very nice work and fast.
    I will give it a go today gna gna gna
  16. Rinus janssens
    Holland
    2,153Coins
    SCN5
    First of all great work for releasing this plugin so fast :cheers
    I have a little trouble with unwanted movement of the simulator.
    When parked in the garage the seat has unwanted movement. (same as in the early days of Simtools). Every few seconds the seat shakes a bit. when a car drive into me will parkes in the garage the seat moves (very realistic, but very unwanted :grin )
    The movement becomes worse and more often when I select and view another driver.
  17. value1
    14,294Coins
  18. Rinus janssens
    Holland
    2,153Coins
    SCN5
  19. Rinus janssens
    Holland
    2,153Coins
    SCN5
    The plugin works like a charm, keep up the great work
  20. Crowdpleazer
    Crowdpleazer New Member
    Torres Novas
    300Coins
    works with x64 rf2 version??
