value1
rFactor2 Plugin 2.0.4.0
SimTools game plugin for rFactor2
  1. Historiker
    Michigan USA
    9,212Coins
  2. vell001
    vell001 New Member
    559Coins
    I want to download this plugin ,and I have 207 coins ,how to download it without real maney ;)
  3. bsft
    problem solved
  4. Blame73
    Blame73 Well-Known Member
    8,316Coins
    buy the weekly download pack for 250 coins.
    Davide
  5. Blame73
    8,316Coins
    ooops you beat me by a few seconds :thumbs
  6. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    work in rfactor build 906 version of x64?
  7. value1
    14,294Coins
    Yes, the plugin works with build 906 in 32 and 64 bit mode.
    And for the first time even, the telemetry data start together with the simulation :thumbs
    Obviously ISI finally have fixed this bug.
  8. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    Hi I have 266 coins, because I can not download the plugin? What else do I need conditions?
    Thanks, SL2
  9. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    Forgiveness, is already solved. Not remember changing my virtual coins for bonus weekly download.
    Thanks, SL2
  10. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    Ate Que seja Finalizado TODO O Processo de atualizações e correções o game é normal que haja uma ou outra falha.
    Adquiri mas o jogo, Como não tenho Uma Conta internacional, Estou impossibilito meu projeto.
    Parabéns Pelo Trabalho
  11. BlazinH
    16,703Coins
    Hi, I’ve got a problem. I am running build 798 of rFactor2 and can’t get changing tuning numbers. Game dash crashes on games start also. I am using the latest plugin. Game patched and game engine buttons turn blue on startup. Tuning center shows rFactor2 selected but with 0 in all top boxes and 32767 in all boxes at bottom unless I reset them. But nothing changes when the game is running. Tried running things as administrator also to no avail. Plugins went into the Programfiles(x86)/rFactor2/plugins folder. There are plugin folders in both the 32 and 64 bit game versions folders also but couldn’t patch to them. Anyone have any ideas as to what the problem is or what to try next? Thanks.
  12. eaorobbie
    20,506Coins
    You should be using the latest build, I can confirm it works spot on now, Motion starts with game no delay anymore.
  13. BlazinH
    16,703Coins
    Yes the motion delay is quite annoying and I planned on downloading the latest build anyway along with some of the newer cars and tracks that I don’t have yet. If that fixes the problem then all is good but I still wonder why I can’t get changing tuning numbers using my current build though. Thanks @eaorobbie and nice to see you back on the site more often!
  14. BlazinH
    16,703Coins
    Okay, I updated to build 910 but the same conditions exist. Game Dash still crashes on game start just like before and still no changing tuning numbers. However, I have another issue now where I get an error that says, "The program could not start because MSVCR100.dll is missing from your computer". I noticed also that simtools_rfactor2.dll is now in the bin32 folder as well and if I delete it from that folder then the error goes away. But either way no changing turning numbers. It appears that .dll is from 2010 visual c++ redistributable so do you thing reinstalling the redistributable package from Microsoft will fix the problem @value1 or should I try something else? If you think so do I need the 32bit or 64bit version. I have window7 64bit but I have been using the 32bit rfactor2. Thanks.
  15. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    I would start with that first.
    Somewhere inside RF2 folder is a subfolder called "Tools" or "Support" and containt VC++ Package installation needed for RF2 to work and DirectX files also.
    Try installing all of those stuff and see what will happen.
  16. BlazinH
    16,703Coins
    Thanks for that info! I'll give it a try again when I can.
  17. BlazinH
    16,703Coins
    UPDATE: The problem was caused by attempting to run 32bit rFactor2 on a 64bit OS with the simtools 32bit plugin. No problems running 64bit rFactor2 with the 64bit plugin. Apparently a 64bit OS uses a different .dll than MSVCR100.dll because I only get a missing file error when the 32bit plugin tries to start.
  18. PatrickPro
    PatrickPro New Member
    294Coins
    2DOF, SCN5, SCN6, 6DOF
    I start to use simtool with LFS, Dirt3, Assetto Corsa : all is working.
    Then i tried the demo of Rfactor2 build 930 and nothing move on my simulator....
    The game is well detected by simtool, but nothing move...
    Someone have an idea?
    Patrick
  19. prodigy
    Croatia
    6,698Coins
    Try caputring Min/Max values with tuning center, I think they are not set good by default.
  20. PatrickPro
    294Coins
    Many Thanks, the solution works a well!!!
