Richard Burns Rally motion?
Discussion in 'Force-Sender & Plugins' started by tronicgr, Jun 12, 2008.
  1. njracer
    njracer Member
    2Coins
    hey, any new progress on the rbr g-force data?
  2. oleroc
    oleroc New Member
    1Coins
    Eh....
    I actually have a program that extracts all motion data from RBR and sends it to an IP adress...
    /me
  3. FAG
    FAG New Member
    Perm/Russia
    413Coins
    With source code or as is ?
  4. oleroc
    oleroc New Member
    1Coins
    Its just an executable visual basic .exe
    It works fine, and sends the motion data in the same format as LFS does.
  5. tronicgr
    tronicgr
    Hi oleroc,
    Then can we have it? It should be compatible with profiler by using the existing LFS profile!
    :thbup:
    Regards, Thanos
  6. oleroc
    oleroc New Member
    1Coins
    Sure, by PM.
  7. egoexpress
    Thanks for the app.
    But I havent been able to run it so far. I am getting a mswinsck error popup in XP.
    Could you provide this file perhaps?
    Regards
    Christian
  8. tronicgr
    tronicgr
    I was able to run it ok on my home computer that had visual basic 6 installed.
    I guess that it needs a few VB libraries along to work.
    No time to test it with RBR on profiler yet through...
    Thanos
  9. egoexpress
    I've found the library and your app is runing now.
    MSWINSCK.zip
    Paste it to C:\\WINDOWS\SYSTEM
    But RBR is not detected by the app so far. Probably it does not work with RBR demo.
    Btw, what about license and terms of use?
    There was no info included in the archive.
    Regards
  10. oleroc
    oleroc New Member
    1Coins
    I have never tried it with the demo.
    As soon as I fire up RBR v1.02 (SSE) the app picks it up right away.
    See http://www.bhmotorsports.com for addons to RBR.
    Terms:
    I would appreciate it if the app would remain within the user group of x-sim.
    Please do not post it to other forums, and use it only for personal fun.
    /om
  11. Ringorumble
    Ringorumble Active Member
    190Coins
    Works here with 1.2, you have to set the port in the VB app to 4123 and activate the lfs plugin
  12. Runxax
    Runxax New Member
    Is possible an similar VB program to extract data motion from FS9.1?
    Best regards
    Rui
  13. Ringorumble
    190Coins
    Thanls oleroc for the VB Prog, works great and me having alot of fun with it !
  14. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Any chance we could get a step by step on how to make this all work. I've tried everything and keep getting error codes. O.S vista. Thanks
  15. egoexpress
    @Hobbs77
    1. Start RBR app from oleroc and change port number to 4123
    2. Open RBR
    3. Start Force-Sender and select LFS plugin. Then press the send button.
    4. Start Force-Profiler and check if you get game data into the math table.
    Btw, generally it helps alot to tell us the which error codes you are getting....
  16. Hobbs77
    Connecticut, USA
    875Coins
    2DOF, SCN5
    How , where do you start it? I keep getting failed to start because dx8vb.dll was not found.
  17. egoexpress
  18. Hobbs77
    Connecticut, USA
    875Coins
    2DOF, SCN5
    When I start the RBR app from oleroc. also get error code 0x8002801c when I try to run MSWINSCK.OCX
  19. Hobbs77
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Is any of this because I'm running Vista Home Pre.
  20. egoexpress
    http://www.youtube.com/watch?v=W-KnZVYik6Q
