prilad
Richard Burns Rally (SSE) plugin 2.0.0.0
SimTools game plugin for Richard Burns Rally (SSE version)
  1. noorbeast
    154,729Coins
    +11,213 / 57 / -2
    I am guessing what you mean is that audio driven transducers work, which they will because that is seperate from the plugin, but perhaps what @vin100lorant may be asking is the possibility of implementing GameVibe support in the plugin.
    With respect to the latter I suspect it is not really worth doing right now, as SimTools V3 is in closed Alpha testing already and all plugins will need to be updated for it. If changes are to be considered for plugins then during the v3 plugin upgrade would seems a sensible time for plugin devs to consider that.
  2. vin100lorant
    vin100lorant New Member Gold Contributor
    Professeur Electrotechnique
    Beynes
    191Coins
    Thank you for your answers to all of you. Indeed, I was talking about the GameVibe plugin. There is no problem I will wait for version 3 of simtools, hoping that the RBR plugin will be more complete.
  3. John Szpyt
    John Szpyt New Member
    17Coins
    SimAxe
    Does anyone here know if SSE plugin works with the current version of RBR from Rallysimfans on Sim Commander 4.0 and up for support of Accuforce DD, G-Seat, Simvibe, ect?
  4. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    same question here!
  5. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
  6. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    484Coins
    In general, Simtools works fine with RSF-plugin version of RBR. I have been using Simtools 3 with serial-if.
  7. wormx
    wormx New Member
    115Coins
    Hello, I launched RBR via the rallySimFans launcher. On Simtool I captured the values during a practice and saved them. My 2dof seat mover moves but not on the bumpy ground (and moves very slightly on bends, much less than on Assetto Corsa when I turn or take a curb). I almost have to hit a tree for the seat to really move.
    I tried to increase the % of forces in simtools but that doesn't solve the problem (I play at 60% force on Assetto, here I tried 80% for RBR but it doesn't move any more on the movements which were already not moving). I forgot to configure a setting?
  8. Krzysztof Dej
    Poland
    1,100Coins
    Try check enable telemetry on simfans launcher or decrease values in max min simtools I have if I remember correct like 5
  9. estanislaolopez
    estanislaolopez Member
    Argentina
    80Coins
    2DOF, DC motor, SimforceGT
    This plugin work in all version of Sim Tools? I download one (V3) and didnt work in my ST version
    154,729Coins
    +11,213 / 57 / -2
    No, you can't use the RBR v3 plugin with v2.
