Rift CV1 - pixelation:(
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Martyn, Apr 6, 2017.
  1. BlazinH
    16,700Coins
    The screen door effect on DLP projectors and televisions (what I currently use) was really bad in the beginning too. Really, really bad when you used a projector with a very large screen. This was latter resolved though by adding what is called wobbleization. When an image is projected with wobbleization there is a slight shifting in the light projecting mirror which then projects light over the black grid lines too that were caused by the mirror being laser cut into over 2 million micro mirrors. Unfortunately that kind of tech won't work on led /lcd etc. type screens but they will solve the issue some day.
  2. Bastiuscha
    Bastiuscha Active Member
    750Coins
    After many hours playtime, i don't see the pixels/screendoor much. Of course, i want it still better. But the 110 degrees display and the cable, disturbing me much more, a the moment.
  3. Andrew M
    Andrew M P_H_O_3_N_I_X Gold Contributor
    IT Chief Programmer / CTO
    Warsaw, Poland
    593Coins
    We are all still waiting for a 4K gen. of VR,[ but then GPU would need to be upgraded as well - now my CV1 is toasting a 1080 with SS 2.0 on DCS, ProjectCars, only AssettoCorsa is holding 90 FPS all the time ].
    so untill 4K arrives you can only use SuperSampling - which improves a lot, [ if not enough performance then nvidia ATW and ASW by CTRL + 1-4 ].
    When I had a DK2 I also had mounted a ScreenMatte protection for a display [ must dissassemble the HMD ] -> it was also a big improvement with SS, but haven`t tried this on CV1.
    I actually even tested a PS VR which has much worse resolution [ something around 1080P, but offers almost unnoticable SDE - so the problem seems to be this AMOLED display [ with diamond pixels ].
    If I would have a free money then would try something which is called: Pimax 8K [ strange marketing name, because they use 2 * 4K screens ]...
    But personally I won`t sell my CV1 [ only exception is to change for a better 4K option ] because it gives the IMMERSION - you need, and honestly I can no longer play on flat monitors, or TV - especially on flight sims like a DCS - I just am so addicted to that feel of freedom that only VR offers [ trackIR is not as good as VR - so even with issues like SDE is OK, I also don`t see this after some time - or see only if want to see ] !
  4. Bastiuscha
    750Coins
    Yes i heared about the pimax 8k, but the display is supposedly not so good.
  5. Fluke
    Fluke Member
    Stafford, United Kingdom
    812Coins
    another one to keep an eye on is the DPVR E3 (or Depoon E3) that is supposed to have a far better screen than the Rift or Vive and 120 field of view. I almost bought it pre-order from GeekGear, but am now waiting for the reviews before I jump on it.
    BTW - I have a Rift and dont notice the screen door when I get stuck into a flight or racing sim.
  6. Andrew M
    Warsaw, Poland
    593Coins
    They used some LED displays, [ but still another small step to the 4K future ] at least their first model, called 4K had a LEDs, but also lack of positional tracking and HDMI in version 1.4 [ so in practice - no real 4K option - those guys didn`t thought about it really... incredible :) ]
  7. Bastiuscha
    750Coins
    Hm, i heared, that the pimax 8k is LCD 60hz. Yes the 4k version, i already know. This one had perceptible latency:
  8. Bastiuscha
    750Coins
    I'm in the same position, but i wait... i'm sure, in the next time, we will have a lot of new hardware. And 120degrees... sounds not like, the future. :)
