  1. ho123
    ho123 New Member
    belgium
    198Coins
    Arduino, 6DOF
    very nice!! what is the power of jour motors
  2. wannabeaflyer2
    london uk
    8,349Coins
    Hi Speedy Thanks for the link , thats some serious enginering for a DIY project , so seriously sorry to hear about your misfortune and loosing the Sim , i dont think anyone can say how hard that must feel , but im guessing your nature wont let it stop you and you'll be back as they say, it may take time but once an inventor and your determination you'll make something happen .. Thanks for the Info Speedy very informative
  3. paulg100
    paulg100 Active Member
    Bristol UK
    1,373Coins
    3DOF, DC motor, 6DOF
    love how responsive your sim is in the last vid, presumably keeping the weight down is the key there.
  4. Zyadox
    Zyadox New Member
    196Coins
    Hello @SilentChill,
    Fantastic build thread. I've read it cover to cover a couple times now - but I wanted to check with you to see what kind of brushed dc motors you're using at what voltage. Your 6 PSUs must supply a lot of power.. Do you have a recommended vendor? Give the choice of going back, would you have selected different motors? I can see you're using struts to alleviate some of the weight on the platform.. Also, I may dodge MMs and Ard boards altogether in favor of JRK boards - I'm kind of worried I will go through the same problem as you did with faulty MM boards.
    @eaorobbie, am I correct in understanding that 6 JRKs are needed to drive each motor? I know that Sabertooths can drive multiple motors, but not JRKs, I
    believe..
  5. SilentChill
    20,596Coins
    I just bought the PSU's off ebay from the cheapest place. The motors I used as I got them for free I just needed to refurb them a little. I think more powerful motors would be better obviously but the ones I have work just fine with the struts on. The biggest problem I had was heat, the motors would work great with long arms on but the heat just got the better of them. I can play all day now and heat is not an issue. I have enough movement and it feels great :)
    I have no idea about JRK's as I have not used them I would say @bsft is the best person to ask about them :)
  6. bsft
    thanks @SilentChill , what motors are you using currently?
    Im not too sure about JRKS for a 6 DOF depending on the motors planned. And the weight they can carry all up. Yes you would need one JRK per motor.
    The JRKS will run 12v at 30 amps continuous with 45 amp spikes no problem. But that restricts it to a 200 watt motor , as the stall current is a lot higher.
  7. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    Hi to all,
    @SilentChill could you please share a screen shot of your setup on Game manager for DOFs.
    You mentioned that each Arduino Uno control two motors... which ones are they on your rig? are the motors fixed to the corner of the triangular based?
    Why did you not use two Arduino? SMC3 supports 3 dof, have a reason?
    Thanks in advance for your reply.
  8. gpau
    gpau Member
    550Coins
    Bellissimo, stupendo, molto interessante, per cui Quello che pensavo di FARLO in legno é possibile, Qualcuno mi ha data del folle. : sorriso
    Si possono Avere le Misure?
    Grazie
  9. gpau
    gpau Member
    550Coins
    E possibile avere i dati tecnici dei motori?
    Grazie
    152,718Coins
    +11,092 / 56 / -2
    Google Translate -
    Beautiful, wonderful, very interesting, so I thought I DO What wood is possible, someone has given me the crowds. : SorrisoSi can Have the measures? Thanks
    Google Translate -
    You can get the technical data of the motors? Thanks
    By all means post in your native language @gpau but please do also include an English translation via Google Translate. It saves other members time trying to work out who may need help and who is just posting a comment.
    We have bi-lingual speakers from many different language group so if Google Translate really messes it up they can help clarify what was intended.
    There is a specific section for native language based social interactions: http://www.xsimulator.net/community/#international-social-chats-and-conversations.155
  11. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Bellissimo, stupendo, molto interessante :grin:grin:grin
    Luigi :cheers
    • Funny Funny x 4
  12. Michael Hensen
    Michael Hensen Active Member
    C# Software Engineer
    Almere, Netherlands
    748Coins
    How well is the oculus working on the 6dof platform? especially the rapid movements.. Any differences in a non motion platform..
    I have a 2dof now but planning to go to 6dof, but want to keep using the oculus!
  13. noorbeast
    152,718Coins
    +11,092 / 56 / -2
    @SilentChill has shot a bunch of videos with his 6DOF and the Rift, they look awesome but you can judge for yourself how well they work together: https://www.youtube.com/user/silentchill/videos
  14. gpau
    gpau Member
    550Coins
    Please who can tell me what are these ?
  15. gpau
    gpau Member
    550Coins
    The arms blacks you see ?
  16. noorbeast
    152,718Coins
    +11,092 / 56 / -2
  17. gpau
    gpau Member
    550Coins
    I'm passing around the post of @SilentChill but I can not find the measures of the octagon , where I can find them.
    Thank you
  18. noorbeast
    152,718Coins
    +11,092 / 56 / -2
  19. SilentChill
    20,596Coins
    @gpau Each side of the Hex is 750mm from what I recall :)
  20. gpau
    gpau Member
    550Coins
    I imagined seeing the pictures that could be of 800/850 mm .
    I thought you have long arms to get them from 500 to 600 mm , they are good or are too long ?
    The inclination of the arms should be 45 ° or more is ?
    The supplier of the engines , makes configurations of Arduino boards , but it has refused to give me configuration support software / hardware with x - sim . He says I'm a fool and it is not possible that the engines are able to keep the weight and movement .
    We'll see .
    I think this will be the first project in the Swiss 6DOF .
    Thanks for the advice and information
