  1. noorbeast
    152,529Coins
    +11,085 / 56 / -2
    Just the motor would make a lot more sense, do you have a link to the motor specifications?
  2. Jamburglar
    Jamburglar Member Gold Contributor
    Controls Engineer / Software Engineer
    Michigan
    186Coins
    It's a internal motor made at work. I need to dig up the specs. It's part of a column Electric power steering unit. The gearing isn't part of the normal unit. That was scrap for some other projects. Sorry for my ignorance. Ive always struggled with motors. Still learning. :)
  3. Patric
    Patric Too poor to buy a plane.
    Aerospace Engineering
    Munich
    227Coins
    Hey Craig,
    would you be willing to share your initial sketchup model? I'd like to write a new plugin for the Flightgear flight sim and need a decent 6DOF visualization.
    Cheers Patric
  4. MagicEdge
    MagicEdge Active Member Gold Contributor
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Craig, Thank you for time study of center of rotation. Clearly seen now for design of platform. trongr? to be commended.
  5. SilentChill
    20,594Coins
    @SeatTime to be commended for his excellent work and me being able to copy him ;) I couldn't visualise this without.
  6. loco_339
    loco_339 New Member
    Belgium
    101Coins
    @SilentChill , big up for your massive 6DOF project. Impressive. Maybe a source of inspiration for later projects!
  7. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    This is serious Sh#$@^T you build man, wow i'm impressed.
    No half work, great gear, specialy with the VR set.
    Don't you getting nauseous using the forces of your rig and the use of a VR set? :confused:
    anyway great stuff :thumbs
  8. Blame73
    Blame73 Well-Known Member
    8,305Coins
    It works the opposite way: motion helps in tricking the brain in believing that what the eyes see is real and add to the immersion.
    I get nausea if I use VR without motion.
    The more accurate is the motion the better the experience.
  9. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Hey @SilentChill, so your motors draw 13.5A according to the spec, Why 2 MMs per motor?
    Also what guage wire are you using. Thanks
  10. SilentChill
    20,594Coins
    I just over powered it so it just generates less heat and does not have to work as hard. The motors are rated at 13.5amps but it is easily pulling 20amps+ constantly, that's why I have had to drill holes and put fans on my motors and also use the gas struts as they would just overheat.
  11. BondeX
    EE
    Michigan, USA
    1,501Coins
    Thanks @SilentChill, one last thing. Your power supplies, do they have any heat sinks on them underneath those blue LED fans? Is that the only way to cool them?
  12. SilentChill
    20,594Coins
    The psu's have 2 fans 1 blowing air in and 1 sucking the air out seems to do the trick nicely they never get hot.
  13. BondeX
    EE
    Michigan, USA
    1,501Coins
    Did you have to drill the holes yourself?
  14. SilentChill
    20,594Coins
    Yeas lots of them ;)
  15. phisado
    phisado New Member
    bangkok
    302Coins
  16. GusBiz
    GusBiz New Member
    Sales IT
    Melbourne, Australia
    486Coins
    DC motor, AC motor, Arduino, Motion platform, 6DOF
    Thank you for the inspiration it was your video on youtube that inspired me to begin the 6DOF element of my simulator.
    Did you consider doing the structure in metal?
  17. lrogerorrit
    lrogerorrit New Member
    Student
    Barcelona Spain
    144Coins
    @SilentChill Amazing work :thumbs . Im finishing year 10 (school) and I've decided to do a motion simulator like yours. I have a question, how many gas springs do you use for each motor. Where do you put them, are they attached to the motors - platform? Thanks
  18. SilentChill
    20,594Coins
    Pictures are in the thread somewhere
  19. lrogerorrit
    Student
    Barcelona Spain
    144Coins
    @SilentChill Yes, Yes I saw them but I still have those doubts, thats why I asked.
  20. SilentChill
    20,594Coins
    I just use 3 struts, 1 at each corner between the arms
