1. We have a few rules which you need to read and accept before posting anything here! Following these rules will keep the forum clean and your stay pleasant. Do not follow these rules can lead to permanent exclusion from this website: Read the forum rules.
  6. Do not share user accounts! Any account that is shared by another person will be blocked and closed. This means: we will close not only the account that is shared, but also the main account of the user who uses another person's account. We have the ability to detect account sharing, so please do not try to cheat the system. This action will take place on 04/18/2023. Read all forum rules.
SCN5 Racing Rig Schritt 2
Discussion in 'DIY Motion Simulator Projects' started by Henning Piez, Aug 29, 2010.
  1. Silly(c)One
    Silly(c)One New Member
    ex-Web & Industrial Dev/Sysadmin
    Brussels, Belgium
    327Coins
  2. Deaks
    Deaks New Member
    Freelance Editor
    Bristol UK
    388Coins
    Hi Silly(c)One
    Thanks for the link, I just ordered 2 pairs :D
    Deaks
  3. rolandcube
    rolandcube New Member
    Hi Henning,
    I want to compliment you for the beautiful sim that you've built, :thbup:
    I started by buying SCN5 actuators to build my own sim.
    I have a question about the profiles you used
    Do you have a list of the sizes of the profiling, it would be building my sim a lot easier when i have the correct dimensions of the profiles.
    Which profiles do you use the 40mm or 45mm
    What is the total length of the frame. I mean what is length of the two outer profiles
    Gr. Pascal
  4. bberger
    bberger Member
    306Coins
    Lieber Henning, ich muss etwas gestehen...
    ich bin schwer verliebt in dein Rig! Hättest du evtl. noch ein paar Detailbilder zum Gelenk unter dem Sitz auf Lager?
    LG
    Bernhard
  5. ATSP
    ATSP Member
    Krefeld
    351Coins
    2DOF, Joyrider
    @bberger
    Detail Bilder unterm Sitz ,sind ein paar Seiten zurück;-)
    @Henning
    Jetzt haste ja auch ein Dach das Du nicht Nass wirst wenn es regnet;-)
    SEhr geile Arbeit!
    Nice clean work!
  6. bberger
    bberger Member
    306Coins
    Leider kann ich da drauf nicht viel erkennen. Mich würde vorallem das Gelenk interessieren und da ist entweder zuviel Schatten oder ein anderes Teil davor.
    Ich dachte vielleicht hat er noch ein paar Bilder ohne Sitz herumliegen :(
  7. ATSP
    ATSP Member
    Krefeld
    351Coins
    2DOF, Joyrider
    vieleicht verstehe ich Dich auch falsch ,aber meinst Du nicht das?
  8. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Sorry Admins, mich treibt diese Seite zur Weißglut. Zum mehrten Male habe ich jetzt über 20min an einem Beitrag geschrieben, und beim Senden war ich dann ausgelogged und der Beitrag und meine Arbeit für die Katz!
    Also jetzt zum Thema:
    To Pascal:
    First to the used Profiles: They are all System 8, that means a slot that opening is 8mm wide. Profiles were mostly 40*40, and some 80*40 and 120*40.
    Total length is 202cm.
    Zum Universal Joint. Mein selbst gebauter war super, allerdings war der Verschleiß der Lagerbuchsen zu groß. Hier könnte man die Buchsen nicht verwenden und statt dessen Kugellager (Inliner haben ganz gute Masse) verwenden. Ich habe ein Gelenk vom Landrover Discovery bei Ebay bestellt für knappe 15 Euro und mir Adapterbuchsen vom Kumpel drehen lassen die mit den Profilen verschraubt werden.
    Bilder:
    Demnächst wird der Sim noch mit Platten teils verkleidet, ein Gurtstraffer kommt noch, am Wheel wird noch was gemacht und am Seitenkasten wird auch noch was gemacht.
  9. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    PS:
    Ich hatte das im VR Racing Forum angeboten und paar haben schon das Angebot angenommen. Wer in der Nähe von Stuttgart ist, oder die Reise nicht scheut weil er Neugierig ist, oder Hilfe braucht, der ist gerne auf eine Probefahrt eingeladen. Ich hätte damals als ich in der Planung war, gerne vorher eine Probefahrt irgendwo gemacht.
    I said it in another German board, and some folks came and took the chance for my offer: Who is in the area of Stuttgart, or is willing to make this journey, can make a testdrive on my sim. It might help you in you planing or decision of building an own sim
  10. rolandcube
    Thanks for responding,
    It is shame that you so much time spent in describing your project, and then everything to lose.
    But if you still have a copy of data, you can send it by email. ;)
    I would like a ride in your sim but Stuttgart => Hoogerheide (Netherlands) is 600km is a bit too far
    Gr. Pascal
  11. litronic
    litronic New Member
    Pascal,
    You can buy the profiles also in the Netherlands, i have built a rig about two years ago with the same profiles.
    I will search for the invoice to get the supplier details.
  12. rolandcube
    Ok thanks, i now there are more suppliers in the Netherlands, thats not the real problem.
    the difficulty is the exact size of aluminum profiles :(
    So I can order the correct size of the profiles.
    Gr. Pascal
  13. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Die nächste große Operation ist beendet, und Sobald das Kabel für den Aktuator aus den USA angekommen ist, beginnt die Betaphase. Wenn das dann alles läuft, sollte ich wirklich zum Amt und ein Gewerbe anmelden :D
    Aktuator SCN6, Drehlager und Rolllager
    Der Traction Loss Unterbau fertig
    Mein altes Rig in luftigen Höhen
    Hochzeit beendet
  14. BartS
    BartS Member
    417Coins
    This looks like a very intresting upgrade to a great sim setup already.
    I cant wait for the video.
    Will you have enough power with scn5s to shif the weight?
  15. bsft
    thats impressive! Hope it goes well.
  16. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    I have wait for the cable for the actuator. One parcel got lost on the way from the US; so I have to wait a little longer for the second. The sim is moving extremly easy. You can push it with your index finger and then you have to stop it again, because it would roll and roll and roll. It should work with an SCN5, but I have a 29kg SCN6 with 200mm travel. So I can mount it more in the center of the sim. It has enough force, and due to the lever reduction, I got more travel out of it. (test and calculated at the back where the slider plates are 15cm in each direction)
  17. Deleted member 4120
    Deleted member 4120
    Hi Henning,
    WOW dein Rig wird immer besser :)
    Gruß
    Alexander
  18. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Du bist ja auch noch hier :) Bist du noch aktiv in Sachen Iracing oder Rigbau?
  19. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Schnell mal ein Video um die Mechanische Bewegung, noch ohne SCN6 zu zeigen:
  20. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
