SCN5 / SCN6 Hardware Thread
Discussion in 'SimTools compatible interfaces' started by egoexpress, Sep 29, 2008.
Thread Status:
Not open for further replies.
  1. Fahim
    Fahim Member
    553Coins
    Re: SCN5 Hardware Thread
    These are the adaptors I have. Thanks.
  2. ClaireVv
    ClaireVv New Member
    My name is Claire and I'm the Assistant Marketing Manager at VirtualVillage.com. Thanks for the mention of the PC USB Signal Convertor http://www.virtualvillage.com/pc-usb-to-rs232-rs485-uart-ttl-signal-converter.html. We also stock other adapters and convertor computer components starting at $3.99 http://www.virtualvillage.com/computer-adapters-and-cables.
    To say thank you for the mention, I'd like to pass on a 20% off discount code. The code is VVN392R. Type in the code when prompted in checkout and the discount will be applied.
    If you have any further questions, comments or if there is anything I can help with, please don't hesitate to get in contact with me. Go to VirtualVillage.com http://www.virtualvillage.com to find more inexpensive accessories and adapters and cables http://www.virtualvillage.com/computer-adapters-and-cables.
    Claire Bartels
    claire.bartels@virtualvillage.com
  3. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    Can everyone help me to talk with EGOEXPRESS, i cannot find his e-mail.
    I want ask for him regarding the cables for SCN-5 actuator. I cannot find it in Brazil. Maybe he can sale some pairs for me.
    Apreciate the kindly
    With best regards
    Leandro Tercette
    mol3r0@hotmail.com
  4. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Leandro,
    The cables are very easy to make. You can purchase the connectors and pins from Digikey.com. I can send you the part numbers if you want to go that route.
    ....Mike
  5. Fahim
    Fahim Member
    553Coins
    Egoexpress makes this cables very well. If you are uncertain just PM him. He made me a set. All I had to do is plug and play :)
  6. sn4il
    sn4il New Member
    2Coins
    Has any1 tried to use two SCN5's per each side? What would be the correct way to connect them together and trick X-sim to controll them both identically? I'm about to order four SCN5's for my project and want to make sure it could be done.
    Thnx
    sn4il
  7. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    What would be the reason for that config?
    As for the trick, all you need is to have the same control math for both actuators on each side...
  8. sn4il
    sn4il New Member
    2Coins
    Simply, the reason is my weight (260 lbs) plus I want to move entire chair together with the wheel and pedals.
    Do I need four usb to rs485 or I could use one per two SCN5's?
    Are SCN5's talking back to converters or they just receiving data?
    I've been busy on the mechanical part of my sim and did not read spec sheets on SCN5's yet.
    Thnx
  9. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    4 converters...
    To properly id each actuator on x-Sim.
  10. sn4il
    sn4il New Member
    2Coins
    Are You sure about this?
    This is what I found on the x-sim wiki:
    If you only own a single RS485 converter or USB device and like to try more than one SCN5, you are able to connect all SCN5 to the same bus system parallel. Before you do so, you have to change the device ID for each SCN5, so it will not response on a command of another SCN5. There are 16 device ID's possible to connect to one RS485 bus system. The SCN5 are delivered all with factory default values and device ID 0. This means you have to change a second SCN5 to a higher device ID number.
    It looks like it could be done the way I was thinking.
    I'm not sure about loosing updates as per this sentence (also from x-sim wiki):
    If you use more than one SCN5 on one comport the update rate will be devided by the number of scn5 connected. So if you have one SCN5 connected and reach 150 outputs/second (normal) and you attach a second one, you only have 75 output/second left.
    Is this correct assuming they operate same axis?
    Can any1 confirm that please?
    thnx
    sn4il
  11. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    For obvious reason, I haven't seem people using this sort of configuration.
    You could try and report back.
    This topic is supposed to help people convert their Frex to x-Sim, maybe you could create a topic for your own questions.
    Cheers,
    Me
  12. sn4il
    sn4il New Member
    2Coins
    Hmm.. I thought it was SCN5 general hardware thread. Did not find any info about Frex entering this.
    Sorry
    sn4il
  13. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    You are right!
    My mistake, I thought I was replying to other topic. :rofl:
    Sorry!
    Maybe, I need to unsubscribe this topic, lol... :?
    Cheers,
    Me
  14. Ender
    Ender New Member
    Hello ,
    Following the 38 pages and as a complete noob , I'm still really confused.
    I bought 2 of these :
    http://cgi.ebay.fr/ws/eBayISAPI.dll?Vie ... 0413855073
    http://cgi.ebay.fr/ws/eBayISAPI.dll?Vie ... 0370302162
    For 2 x 100mm SCN5 100mm.
    I really don't have any electrical skills , I really don't understand what I should do next. I saw some soldering steps to do but those schemes aren't self-explanatory for a complete noob like me. Could anyone point me the exact steps to do or maybe a plug-n-play converter from SCN5 actuators cables to PC ?
    I will also need a switch and a AC/DC converter right ? How am I supposed to connect all these things together without soldering skills :((((
    Thanks for your help.
  15. Ender
    Ender New Member
    Well , then if I buy this adaptor x 2 ( http://www.robotshop.ca/devantech-usb-r ... rface.html ) for my 2 SCN5 , I willl now just have to power the 2 actuators with 1 or 2 PSU right ? No more wirings or else ?
  16. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    You would still need to wire them. The wiring diagrams were also shown in the first 38 pages.
  17. Nelson
    Nelson New Member
    Good people, I wonder if anyone knows the name of the company that makes these actuators SCN5, that because I live in Brazil and is difficult to import from Canada to Brazil, I am grateful if someone can help me.
  18. bvillersjr
    Ohio, USA
    438Coins
    The actuators are made by Dyadic in Japan.
  19. tmeidinger
    tmeidinger New Member
    - 29Coins
    3DOF, SCN5
  20. RaceRay
    23,892Coins
    Think it works, but why do you want to spent the whole money when there are cheaper and proofed interfaces out there?
    René
Thread Status:
