Shift Unleashed 2
Discussion in 'Off Topic - All other stuff here' started by bleco, Feb 24, 2011.
  1. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I'm running a triple screen configuration. If you are only running single screen, most modern high end cards will run with all eye candy enabled with no issues.
  2. Fahim
    Fahim Member
    553Coins
    Mike,
    are graphics in this game better than f1 2010?
  3. benefie
    benefie New Member
    Germany, Hamburg
    1Coins
    too bad, thats almost never the case, mostly bad programming
    i would say, they're pretty much on the same level. in my opinion the performance of the shift1 engine has been slightly improved. a lot of eye candy, way too much objects and advertisement of speedhunters on the side of the tracks.
    the feel of the cars is too arcarde for me, but their goal to simulate the action of racing is really well done. even though the ai is still crap
  4. bsft
    Thats right, usually bad programming can cause issues with graphics, especially if it is a cracked game of a new release. Best buy it. Then again, I run 1 screen and do not have that many games that run under 30fps, with the exception of Metro 2033, and Crysis.
    As for your comment on graphics engines, game writers try to improve on their current engine. This makes it look better mainly for console players as they cannot ramp up the graphics unlike PC players. Anyway, lets game on!
  5. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    How can a cracked exe be responsible of ingame bad performance ??
    I am pretty sure it's more a gpu driver issue and/or bad game coding ... Exactly the same happened with Shift 1 ... ATI users mainly ... This title is NVIDIA proof ... Issues were fixed with gpu drivers updates and game patch v1.2 ...
    Bleco
  6. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    HI,
    I am going to check this game out too... Now the big one: Will it work with x-sim? I guess the injector from Shift 1 will not work, as it is a different game.
    I just got a GTX 295 multi gpu second hand, i hope it works, as it sucks with IRacing, my old GTX 260 worked better... But i still need to fiddle with some drivers as the card(s) itself should be fast enough.
    Maybe i will buy another one and go quad-sli :uups:
    Cheers
  7. splendiddd
    CCTV security
    Netherlands
    813Coins
    Same problem here with the Frex wheel...pritty much undrivable now...grrrr :thbd:
    Also the game runs like crap, very low fps, glad i tested it first before i bought it :(
    i7 860
    4 gb ddr3 ram
    GTX 295 multi-gpu
    Asus sli pro mobo
    850 watt corsair psu
    TH2Go
    3840x1024
  8. bleco
    Montréal, Canada
    258Coins
    ... the question is more ' who will take the time to create a good injector file for it' ... :)
    Hope someone does ... I can provide the game to whoever wants to work on it ... :cheers:
    Bleco
  9. splendiddd
    CCTV security
    Netherlands
    813Coins
    Yeah....still the game still needs some work.
    However i managed to make it work....sort of.
    The steering lag can be solved, just put ALL the sensitivity sliders to 100% in the advanced control panel. Especially the steering sensitivity. Not the speed sensitivity though... Also steering lock needs to be reduced to own flavor.
    Thanks to some advanced gfx settings (nvidia) putting aliasing off in the game and on in the control panel the fps is a lot better now, however everything but shadows on max and with a resolution of 3840x1024 i still only get 30 to 35 fps, when in other games i get 60 easy.
    Hope the motion will work soon. I love the helmet cam btw...
    Cheers
  10. bleco
    Montréal, Canada
    258Coins
    Yeah I like the Helmet cam also ... Driver seat position is better then the main cockpit view...
    Bleco
  11. bsft
    Shift 1 gave me issues as a cracked download but worked as a store bought copy, even before the patch update. Perhaps I was lucky. I have always run NVIDIA cards though.
    Who knows anymore, lets just game on! ;D
  12. bleco
    Montréal, Canada
    258Coins
    Alright so I spent some time playing Shift 2 ... a lot of bugs as usual ... and default wheel config is very bad ... Also graphics cannot be set very high to get a good fps ... ...
    However after tweaking it a little, it became a very interresting game ... surprisingly! I am enjoying it much more now ... It won't be long for interresting mods to be available and vendor feedback about poor performances...
    To set the wheel correctly:
    On the wheel:
    Degrees of rotation = 900
    In Game:
    Steering sensivity = 25
    Deadzone = 0
    Speed sensivity = 0
    Wheel lock = 50
    Feels good to me ... much better then Shift 1 even with lattest release of tyre set mod ...
    I am also getting good fps with my HD5870 and 1 monitor @1920x1080 with these low graphic settings in graphicsconfig.xml file located in yourdocuments\Shift unleashed 2
    Set the resolution according to your monitor settings and refresh rate...
    <data class=GraphicConfigData id=0xEA8080>
    <prop name=Name data= />
    <prop name=Mode adapter=0 width=1920 height=1080 antialias=0 refresh=60 />
    <prop name=Vsync vsync=1 />
    <prop name=AntiAlias antialias=0 />
    <prop name=Windowed windowed=0 />
    <prop name=TextureFilter texturefilter=5 />
    <prop name=TextureResolution textureresolution=2 />
    <prop name=Brightness brightness=10 />
    <prop name=CarDetailLevel cardetaillevel=2 />
    <prop name=TrackDetailLevel trackdetaillevel=2 />
    <prop name=ShadowDetailLevel shadowdetaillevel=3 />
    <prop name=MotionblurLevel motionblurLevel=0 />
    <prop name=EffectsDetailLevel effectsdetaillevel=2 />
    <prop name=EnvmapDetailLevel envmapdetaillevel=3 />
    Another very good addition is a camera mod that adjust the driver seat position the same way as the helmet cam and replaces the standard cockpit view ... it's much better then the default cockpit view and available here (must be logged):
    http://www.racedepartment.com/downloads ... le&id=4385
    *** it was probably not tested a lot so don't forget to backup your file *** It also cannot be used with the other no blur and shaky wheel mod as it doesn't come as an injector file ...***
    If I play this game more I will probably start modding it so I might create injector files for it and for others ...
    Now hope they fix the graphics low performance issues soon (amd or EA or both!) ... it runs poorly even with only 1 monitor at max settings on a hd5870 ...
    After that it won't be that bad! And the drag event looks cool also if it can come to PC as well!
    Bleco
  13. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Thanks for the report Mike/Bleco
  14. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Is there someone who`s trying to get this game work with x-sim/force injector ?
    It might be the same way - like with first one.
  15. Fahim
    Fahim Member
    553Coins
  16. bleco
    Montréal, Canada
    258Coins
    Not sure to follow you ... What's the point? These are juste a couple of file editing mods and as nothing to do with memory scanning for motion data ...
    And yes Shift 2 is modable the same exact way as Shift 1 ... Already a couple of mods are available but none of them present or futur will help us to get motion out of Shift 2 ...
    Cheers
    Bleco
  17. bvillersjr
    Ohio, USA
    438Coins
    There has however been talk about the improved telemetry and an API used for multiplayer use that would no doubt have to send telemetry? I haven't looked yet, but these at least show some promise of the data being found or being found somewhere that won't change with the first patch.
  18. bleco
    Montréal, Canada
    258Coins
  19. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    I don`t have this game yet but someone can try those old values for Force Injector from previous Shift. Since this is the same Game Engine (improved) then everything might work like it was before.
    Who had motion with first one ???
  20. Baurus
    Baurus New Member
    161Coins
    A question.
    X-sim will be compatible with shift 2 ???
    Thanks for answers.
    Baurus
