Showroom Sim Project - Kevin Stage 2 [SOLD]
Discussion in 'DIY Motion Simulator Projects' started by -kevin-, May 22, 2012.
  1. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    2DOF, 3DOF, DC motor, SimforceGT, 4DOF
    Re: Blue Sim racing - 2DOF Viper Motor K8055+Sabertooth 2x12
    Hello riton
    I saw the video of youtube configurations for dynamic speed is good
    It seems the same problem to me because I was told not to connect the GND sabertooh K8055 and instead goes offline ... did you see wiring connected?
  2. riton
    riton Active Member
    1,006Coins
    Yes i have the GND between VM110 and Saber.
    if i understand, i try to disconect the output GND VM110 to the input GND SABER??
    Ok, but
    if i disconect the GND between VM110 and Saber, there are a motor vibration ....
    I think is not correct
  3. -kevin-
    128Coins
    Do not disconnect the gnd! using the engines behave badly if you take it ... I wanted to know if it was connected ok you said it
    then try to reverse the axes and see if he does it again
    or tries to put the minimum at 20% and the maximum A80%
    unfortunately with the translations online ... well you never know
  4. riton
    riton Active Member
    1,006Coins
    Ok for the GND!! ;D
    where?
    i don't understand where is minimum at 20% and the maximum A80%
  5. -kevin-
    128Coins
    It does not excuse myself clear
    redo the setting of the potentiometer setting to 20% and minimum and then press the up or copy and paste these values​​:
    3758096383 (max)
    2885681151 (min)
    yet I remember it was to me and so I just reversed the board and went well
    Hello to tomorrow
    EDIT:
    I remembered when I'm not mistaken this was the problem falls entirely
    I hope it goes well for you
    Hello
  6. furlo88
    furlo88 Member
    - 10Coins
    grazie -Kevin- ti ringrazio moltissimo !!!! complimenti anche per i video ,devi averla configurata proprio bene !!! si muove da dio ! :D fatto tutto da solo per la configurazione ???
  7. riton
    riton Active Member
    1,006Coins
    thank you,
    I checked, it is set to 0, if I change the setting does not change.
    everyone confirms to me?
    in dynamic speed:
    to position -100% , -100% = 0v = full speed in the negative position
    for the position 100%, 100% = 5V = full speed in the positive position.
    ( if I change the value to -80% or -20%, and ditto for positive 80% or 20%, there is no visible effects,
    What is the interest to 50% positive and negative? )
    it's good?
    to stop, I must put the value mid-range = 2.5V and adjust if the motor moves in stop.
    this is ok?
    Now I want to understand the PID ...
    it must check the boxes P, I, D to toggle the value?
    The settings seem to do anything at all ....
  8. -kevin-
    128Coins
    Hello riton
    I am sorry that you have not solved the problem
    and just what you say at least as I understand from the translation
    Unfortunately I can not remember how I solved the problem but to me he did it with only one engine is not correct your motion and I think I reversed axes, or I readjusted the max and min, but as I said I do not remember :?
    To you he does it with both axes?
    I send you a pm with my setup let me know if you solve dynamic speed
  9. -kevin-
    128Coins
    Ciao caiubbo ;D
    E si magari.....se devo ancora leggere il manuale di x-sim :D appena ho tempo però devo impararlo per creare da solo i profili adesso li ho scaricati già fatti ho modificato solo alcune cose comunque ho letto e riletto post su post e ho fatto una settimana di test finchè non ho trovato il giusto setup l'output ho seguito la guida di caiubbo velocità dinamica e anche li ho smanettato per il resto mi sono arrangiato a discapito di alcuni potenziometri che ho rotto :D
    ma chi se ne frega..... costavano 3 euro.... adesso ho preso quelli di precisione e la sim funziona alla grande
    And maybe you ..... I have yet to read the manual x-sim: D But I just have time to learn to create own profiles now I've downloaded already made, however, I changed some minor things I read and reread post of post and I did a test week until I found the right setup the output I followed the guide caiubbo dynamic speed and also I've tinkered for the rest I arranged at the expense of a few pots that I broke: D
    but who cares ..... cost 3 euros .... now taken as precision and sim works great
  10. furlo88
    furlo88 Member
    - 10Coins
    ah ok ! io sto ancora aspettando di avere tutti i componenti , poi inizierò anche io i test. anche perchè devo imparare ad usare i programmi ho una certa dimestichezza con il PC ma non con l' inglese :lol:
    ah ok! I'm still waiting to have all the components, then even I will start testing. Also because I have to learn to use the programs I have some familiarity with the PC but not with the 'English: lol:
  11. -kevin-
    128Coins
    Beato tè che hai dimestichezza con i software... io neanche quello :D
    Non vedo l'ora di vedere i tuoi progressi non appena riesci posta qualche video o foto ;)
    Blessed tea that you are comfortable with software ... I am not even that :D
    I can not wait to see your progress as soon as you can post some videos or photos ;)
  12. adbgg
    adbgg Member
    132Coins
    Nice post, and interesting solution this combination K8055 + Sabertooth.
    Hope you enjoy your home-made-simulator.
    Regards
  13. furlo88
    furlo88 Member
    - 10Coins
    Oggi mi è arrivato l' alimentatore !! 12V 30A ... chissa se alla fine riesce a dare veramente 30 A quando serve :D sono andato alla fiera dell elettronica a Malpensa , chiedendo un alimentatore così e tutti mi chiedevano se fossi pazzo 8) ...
    comunque ora ho praticamente quasi tutto mi manca la K8055 .
    ah poi volevo chiederti ma se io dal motorino ho solo un filo che esce e poi va bhe si sdoppia in altri 4 , io l ho aperto e ho attaccato un altro filo ,adesso gira , ma mi chiedevo se quella fosse la velocità massima , alla fine è collegato diretto con l' alimentatore ... però boh non capisco :uups:
    e comunque mi piacerebbe poi riuscire a fare una bella guida come la tua con tanto di ringraziamenti , diciamo che la tua guida è la mia strada madre :cheers:
    Today I received the 'power! 12V 30A ... who knows if in the end can really give 30 A when needed: D I went to the fair of electronics Malpensa, asking for a power like that and everyone was asking me if I was crazy 8) ...
    Anyway, now I have pretty much everything I lack the K8055.
    ah but then I wanted to ask if I've only scooter from a wire that comes out and goes well, then splits into 4 more, I have the open and I attacked another thread, now runs, but I wondered if that was the maximum speed, the end is connected directly with the 'power ... But I do not understand boh: uups:
    and anyway I'd then be able to make a good guide like yours with lots of thanks, let's say that your guide is my mother road: cheers:
  14. -kevin-
    128Coins
    Se hai preso i motorini della panda come i miei devi collegare il verde e marrone che sono la velocità massima se invece sono altri devi provare a dare la corrente diretta provare quale e l'alta velocità o la bassa ovviamente colleghi solo i fili dell'alta velocità ;)
    Ti consiglio sempre di fare le cose con calma... se no butti via soldi... al limite vedi i motori di quale macchina sono e vedi se trovi qualcosa sui collegamenti oppure chiedi a qualche elettrauto vicino casa tua
    If you took the scooters of the panda as my need to connect the green and brown are the maximum speed but if there is more you try to prove that the direct current and high speed or low wires is the only course colleagues speed;)
    I advise you to always make things easy ... If not throw away money ... limit to see what machines are the engines and see if you find something on the links or ask some near your home electrics
  15. -kevin-
    128Coins
    thanks adbgg :thbup:
    You were a great help to me with your guide :clap: that I read and reread many times and I do not know thanks to you and started my adventure in building sim with this hardware configuration indeed I see my main post because I did a lot quickly and i did not put a lot of things including the thanks for you
    but I will make it :yes:
    The solution K8055 + Sabertooth I find it very good and cheap but also functional for this type of project ;)
  16. adbgg
    adbgg Member
    132Coins
    Hi Kevin,
    No problem. And thansk for your thanks concerning my job (laugh).
    I've just discovered your post few days ago. It is very well done (better than mine), and you give many advice and information.
    Yes, you are right, this solution is very cheap and functional for this kind of project.
    Today, we are lot of people to use this combination (K8055 + Sabertooth), and there are a lot of information about here (X-sim), and an other french forum (Racingfr).
    So it is really great !
    Regards.
    Adbgg
  17. furlo88
    furlo88 Member
    - 10Coins
    Re: Blue Sim racing - 2DOF Wiper Motors K8055+Sabertooth 2x12
    ciao a tutti ieri mi è arrivata la K8055 e mi sono messo subito all' opera !. sta sera se riesco posto le foto , grazie a -Kevin- ho fatto i collegamenti per ora ho attaccato solo un motore e solo un potenziometro tanto per vedere che tutto funzioni. Poi ho iniziato a pacioccare con X-sim e come tutti i programmi all' inizio ti senti spaesato , quello che so è che dal menù interface setting ho visto che il potenziometro funziona correttamente , nel senso che quando giro il valore si sposta , e impostandogli nell' uscita il valore che decido il motore gira in un senso , nell altro oppure è fermo :) . bhe non è molto ma sono già contento , già che ci sono volevo chiedervi oltre ad X-SIM che altri programmi usate voi ? Kevin puoi fare una mini guida in italiano XD no eh ? forse chiedo troppo , comunque dopo torno al lavoro e vedo cosa riesco a combinare
    Hello everyone Yesterday I got the K8055 and I immediately started to 'work!. tonight if I can post my images, thanks to Kevin-I-did the links for now I have only attacked a motor and a potentiometer only just to see that everything works. Then I started to mess with X-sim and like all programs at 'the beginning you feel lost, I know is that from the setting menu interface I saw that the pot is working correctly, meaning that when the value moves around, and impostandogli in 'output the value that decide the motor rotates in one direction, in another, or is stationary :). well, not much but they are already happy that there are already more than I wanted to ask you to X-SIM and other programs you use? Kevin can make a mini guide in Italian XD no eh? Perhaps I ask too much, however after I return to work and see what I can combine
  18. furlo88
    furlo88 Member
    - 10Coins
  19. -kevin-
    128Coins
    Hello Adbgg
    Thank you a thousand times and I really appreciate your work your guide was very important for me so thank you and the least!! :cheers:
    I gave an eye on the French forum and well done you will soon come to find ;)
    Blessed are you who have forums that you should not always translate here in Italy we are always the last ..... :D
  20. -kevin-
    128Coins
    @Furlo88
    Sono contento per tè che stai a smanettare :clap: appena ho più tempo finisco il mio post della configurazione di x-sim e metto a disposizione anche i profili da scaricare di diversi giochi....cosa vuoi di più dalla vita? :D
    I'm glad you're hacking away tea :clap: I just finish my longer post on the configuration of x-sim and put the profiles also available to download various games .... what more do you want from life? :D
    oh I forgot I put 2 more videos of youtube have a look NoLimits Simulator ;)
