Showroom Sim Project - Kevin Stage 2 [SOLD]
Discussion in 'DIY Motion Simulator Projects' started by -kevin-, May 22, 2012.
  1. bsft
    use JRKS instead and then REALLY feel motion
  2. BlazinH
    16,704Coins
    I don’t want to war with you @bsft :) but I have seen you mention this several times but without any explanations! I am curious why you say the dirt3 plugin for x-sim software doesn’t work right because it appears to work fine and without issues for me, at least any that I am aware of!
    And while I know the guru’s building SimTools have been working their tails off before and since its release, and with much appreciation; there appears to be no urgency yet in implementing dash support for any Codemaster titles! This is disappointing, to me anyway, since I prefer using speed output to run my wind generators for extra effect! But you haven’t heard me except maybe once on this because I have been “patiently” waiting for this to be addressed ever since SimTools dash support was released!
    Isn’t it okay to want both? :p
    • Disagree Disagree x 1
  3. bsft
    whatever
  4. BlazinH
    16,704Coins
    What a great answer and said with such intelligence! Lol.
  5. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    2DOF, 3DOF, DC motor, SimforceGT, 4DOF
    Ti ringrazio Ernesto e ti do il benvenuto :cheers
    Il sim non lo vendo più per vari motivi... comunque mi puoi contattare qui kevinhilde@gmail.com e ne parliamo ;)
    Thank you Ernesto and I welcome you: cheers
    The sim can not sell more for various reasons, however, you can contact me here kevinhilde@gmail.com and we'll talk;)
    • Friendly Friendly x 2
  6. GoRacing
    GoRacing Member
    96Coins
    DC motor
    Italiano
    Nooooooooooo :(:(:(:(:(:( ok ti ho mandato una mail spero che cambi idea.
    English
    Nooooooooooo :(:(:(:(:(:( ok I sent you an email I hope you change your mind.
  7. eaorobbie
    20,508Coins
    You want K8055 you will need to use the other software, truly sorry for the inconvenience.
  8. GoRacing
    GoRacing Member
    96Coins
    DC motor
    No problem eaorobbie
    Yes, I have read all of the draft kevin and I really like it and I know who uses the software xsim, because it is not good?
  9. bsft
    If you like xsim software , use it . But you need to go to the other site for support.
  10. GoRacing
    GoRacing Member
    96Coins
    DC motor
    Hello BSFT
    Kevin explained everything and I thank him very:cheers:cheers .Sono sorry that no longer sells sim:( but he explained to me his reasons .... However, I have decided that I will build the structure equal to its detailed photos and thanks to that I was sent will not be difficult costruirlo.Quello I'm missing is the support for the hardware and software that kevin can not help me because his work does not have enough tempo.Nel case I decide to simtools + arduino give me a hand in the hardware configuration and software?:sos
    Thanks in advance Ernesto
  11. bsft
    @GoRacing , no problem. We just do not support the K8055 here, the arduino is a better board and codes from @RufusDufus and @prilad are the better choice in proper working codes.
    However, I will mention that if you are not familiar with coding, then the JRK is the next step up as it needs no code. Choice is yours of course.
    I am not familiar with arduino , so best you start a new thread with details of your planned build and others can assist there.
    Regards, David.
  12. GoRacing
    GoRacing Member
    96Coins
    DC motor
    @ BSFT Thanks for the support I will start to read the various posts to learn about Arduino jrk and then ask for help if you do not understand.
    Edit: Simtools is easy to use?
  13. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  14. GoRacing
    GoRacing Member
    96Coins
    DC motor
    @insanegr thanks for the link but I had already read some of the manual simtools just that for me and very difficult to understand because I'm not good with software and electronics and how to learn the alphabet for the first volta.Del rest and how you need to read and read up to learn
  15. JL Rivera
    JL Rivera New Member
    Northridge, CA
    613Coins
    Nice rig! Definitely gave me some ideas. Thank you!
  16. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    you are welcome and as we are in someone else s thread open a new one and ask what you want.
    if you want my advise to get familiar with simulation get a arduino with two rc servo and start up , make a little scale prototype, start testing and you will learn a lot of things till you make it move properly.
    believe me its the cheapest and funniest "first stage" thing you can make
  17. GoRacing
    GoRacing Member
    96Coins
    DC motor
    @insanegr Good idea to build a small prototype before starting to build my simulator would learn to do without danni.Mi can pass the link to a step by step guide?
    thanks
  18. eaorobbie
    20,508Coins
    Good news K8055 support being investigated, as we speak.
  19. -kevin-
    128Coins
    Now that's good news...:cheers
  20. eaorobbie
    20,508Coins
    First app is just a test app, will be posting information shortly, actually based the code from @-kevin- post.
    This will only run one motor as a test and I recommend removing the pot from the motor connection as I might have it going backward, this will be detailed shortly.
    Teaser pic -
    We are close, I just need it confirmed working and I can add motor 2 control and interface it with SimTools.
    Been a lot fun, easy to code for.
    Beta announcement Coming Soon.
