Question Sim tools network interface for SC-MBOX
Discussion in 'SimTools compatible interfaces' started by Blastertoad, Nov 21, 2023.
  1. Blastertoad
    Blastertoad Member
    372Coins
    3DOF, AC motor
    The system seems to be MBOX. If it is intigrated with servo driver it is MDBOX, if it is seperate interface from drivers it is SC-MBOX V1-3. Doesnt help the manufacture name is also inconsistent.
    After some testing movement seems smoothed, like the interface using time to play even though we are feeding it 0 time. During initial testing with network interface plugin movement was very snappy. Testing with LFS this is most noticable going over curb rumble strips. Sending commands via network interface plugin rumble is very aggressive and quick. Using MBOX Plugin rumble stip is nearly completely smoothed out.
    MBOX plugin is sending
    55 aa 00 00 14 01 00 00 ff ff ff ff 00 00 00 01 00 00 00 00 00 02 46 85 00 02 46 85 00 02 46 85 00 00 00 00 00 00
    Where Line value is "00 00 00 01" matching the Absoloute timing example value.
    When we where testing via network interface I was sending Line value of "00 00 00 9f" copied from relative timing example. I was also feading it a time value of "00 00 00 10".
    Can we try version of plugin sending static line of "00 00 00 9f"
  2. yobuddy
    51,681Coins
    Line is just a line counter thou, I can't see it changing anything?
    But we can try for sure.
    May I have a pic of exactly what your using with the network plugin?
  3. Blastertoad
    Blastertoad Member
    372Coins
    3DOF, AC motor
    Posted on page 1
    Here is a link to origional post
    https://www.xsimulator.net/community/threads/sim-tools-network-interface-for-sc-mbox.18287/#post-243294
    In hex interface input is:
    55 aa 00 00 14 01 00 00 ff ff ff ff 00 00 00 9f 00 00 00 10 00 <axis 18 bit> 00 <axis 18 bit> 00 <axis 18 bit> 12 34 56 78 ab cd
  4. Blastertoad
    Blastertoad Member
    372Coins
    3DOF, AC motor
    @yobuddy If line doesnt change anything then maybe we need to provide a time value. Could be if no value is provided it is using a default value and that is smoothing output.
  5. yobuddy
    51,681Coins
    Just a bit behind, but will catch up soon and make the needed changes.
  6. yobuddy
    51,681Coins
    I think we should implement the line output counter?
    But here is a test with the time set.
    (File Removed)
  7. yobuddy
    51,681Coins
    Here is a test with the line counter.
    (File Removed)
  8. Blastertoad
    Blastertoad Member
    372Coins
    3DOF, AC motor
    @yobuddy
    Plugin with time vallue bringss back the snappyness.
    Couldn't test line vaule plugin as output is deformed. Looks like 00 inserted in every second space
    5500aa00000000001400010000000000ff00ff00ff00ff00000000000100e4000000000000000a000000020046002620000002004600262000000200460026201200340056007800ab00cd00
  9. yobuddy
    51,681Coins
    Does this fix the line output plugin?
    (File Removed)
  10. Blastertoad
    Blastertoad Member
    372Coins
    3DOF, AC motor
    Yeah line seems to do nothing. But adding the time made a major difference.
  11. Blastertoad
    Blastertoad Member
    372Coins
    3DOF, AC motor
    @yobuddy Just in case you missed it. The interface version with speed set and line static works great. If there is nothing else you need to do house keeping wise with it I would say it's a valid release candidate.
  12. yobuddy
    51,681Coins
    Hi @Blastertoad,
    I'm just trying to figure out if the length is always suppose to be 100000 steps.
    Being that that axis are configure on the mbox, and doing this wrong would affect the total number of steps, I'm just trying to verify if we are always suppose to have 100000 steps for full range on an axes or not.
  13. Blastertoad
    Blastertoad Member
    372Coins
    3DOF, AC motor
    Since this is a comercial integrated solution it can be paired with different motors and encoders. I think just leaving it as a variable it give the user either the option to program interface hardware to have it map movement in range, or set value in interface plugin like I have to get desired range for the specific motors.
  14. yobuddy
    51,681Coins
    As far as I know, this is the only setting there is that could affect steps needed?
    Fn OC2=10 in mm, Lead Screw Calc (how much the rod advances for a full motor rotation)
    I'm not against it or anything, but I would hate to leave the door open to have people do things incorrectly, if there is a better way to do it. There may not be any 'same number used', but if they are not always the same number, I would think there would be a better way to find the number of steps needed is all?
  15. yobuddy
    51,681Coins
  16. M_SeV
    M_SeV New Member
    - 4Coins
    How should the Simtools panel look like? I don't understand very well
  17. velik0ff
    velik0ff New Member
    84Coins
    The IP should be set to what the FN020 - FN023 on the controller values are set.
    The port is on FN024 and FN025, both of these can be the same value.
    The number of axises should be set correctly on top left corner and if they are mixed or not aligned correctly you should select the correct axises in the dropdown at the bottom.
    Also with the max axis value, start low and test if you do not know the maximum value, if you set a value bigger than the maximum stroke of the actuators they would go from maximum to 0 to compensate for the extra length, so be careful with that.
