Sim with 360-degree Pitch,Yaw,Roll & also Heave,Surge,Sway
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by barman, Apr 11, 2010.
  1. simmo
    simmo New Member
    Australia
    272Coins
    Don't get me wrong, i'd like to be able to use one as well, though unfortunately don't have the room.
    how fast will it be ale to rotate ?
  2. Alejandro Luevano
    Alejandro Luevano New Member
    646Coins
    Motion platform
    As fast as the game requires it but remember that all three axis will be moving at the same time so all you feel will be a very smooth ride and about the size I am working on a very compact module that will fit in an area of about 5'×5'×6' so it will fit easily on your game room.
  3. Alejandro Luevano
    646Coins
    Motion platform
    You will be able to be in a alien spaceship and do all the maneuvers that you've seen on star wars and all SciFi movies.
  4. SeatTime
    I can do that now, there is no upside down in space.
  5. Alejandro Luevano
    646Coins
    Motion platform
    Very funny what if you have to go into a planet on your way to the center of galaxy and you do all kinds of evasive maneuvers when a fleet of fighter jets try to shoot you down because you are invading their planet?
  6. BlazinH
    16,689Coins
    What if?
    Even though you didn’t start this thread the original questions were, “My question for the more experienced sim-builders is this: why isn’t everyone doing this? What makes this hard/expensive/impossible to do?” This tread was started almost 5 years ago and these questions have been answered here and in other threads; the idea is not new. But so far, all you have tried to do is convince those of us that know better (the more experienced sim-builders) that this is a good idea for a simulator. Well, it just isn’t going to happen so best you just accept that.
    However, the concept is not impossible even though it is a bad one for a so-called “simulator”. But if you really want to build it then fricken build it then! We will be glad to help you where we can but you have yet to post a thread on how you intend to do so and what you would like help with. So get busy or zip it!
  7. SeatTime
    I'm not being funny, just stating a fact. You may not think it, but we are just trying to help. I have a feeling that this thread will just fade away over time like many similar others. Less talk, more action and we may take you seriously.
  8. Alejandro Luevano
    646Coins
    Motion platform
    Let's do it! OK I was trying to buy slip rings for the joints but they asked me for my company name, do I need to have a company to buy what I need to build my Sim?
  9. BlazinH
    16,689Coins
    If a particular company that you are buying from requires that you be a company too then yes, otherwise no. If one does, find a supplier that doesn’t. Try ebay. They have what you need in slip rings and I’ve never been required to provide a company name from any sellers there. :)
  10. Alejandro Luevano
    646Coins
    Motion platform
    Thanks I'll try eBay one more think do you know a company that makes aluminum chasis? And the sphere where can I get it. I asked a company in the UK but it was too expensive if I can't find it I wi have to build it myself.
    153,884Coins
    +11,154 / 57 / -2
    You would almost certainly need to fabricate the parts, it would be unlikely there is suppliers that match exactly what you want to do.
  12. Alejandro Luevano
    646Coins
    Motion platform
    Thanks body that's what I was thinking I have an aluminum supplier close to my house I am going to check what they have I wanted to use 1in. aluminum sheet but it has to be water jet cut I will use pipe instead.
  13. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    The closest I have seen (and been in) to what you are describing is this:
    And this thing was built from the ground up to play one game, and one game only.
    I'm not an experienced sim builder by any means, but given what you are suggesting it would be HEAPS cheaper to go out, buy an old R360 and restore it, rather than build one.
    I'm only doing a 2Dof - I consider myself to be quite technical and can fabricate if I need too - and even it's a challenge!! ;)
  14. Alejandro Luevano
    646Coins
    Motion platform
    Thanks body I been contacting the owner.
  15. Archie
    Wollongong, NSW, AU
    3,797Coins
  16. Alejandro Luevano
    646Coins
    Motion platform
    I got it the only thing that this Sega 360 is missing is rotational control.
  17. BlazinH
    16,689Coins
  18. value1
    14,240Coins
    Once you own one, we can make it work with SimTools :D
  19. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Had to come back to make sure this one died out.
  20. apointner
    apointner Siddhartha
    N 48° 9'0.88" E 12° 5'45.84"
    764Coins
