SimHawk's motion simulator
Discussion in 'DIY Motion Simulator Projects' started by SimHawk, Oct 3, 2007.
  1. yobuddy
    51,747Coins
    @SimHawk - I called StcValve today and asked if they had a distributor in Norway.
    While they do not have a distributor in your local area,
    they said you could call them direct and place an order with them or email them an order and they would be happy to ship to you!
    The list price on their sight for the 4V230C-1/4 valve is ($64.35 USD) about 45.43 Euros,
    so I got a little break from my local distributer but still not a bad price, anyway hope it helps.
    The number I called was 650-856 8833 or you could always email them at Sales@StcValve.com
    Good luck!
  2. SimHawk
    SimHawk Member
    Engineer
    Norway
    Some progress made yesterday. I bought aluminium for the frame and ordered cylinders from SMC, 160mm stroke 32mm bore.
    I also received a fresnel lens from here: http://www.3dlens.com/shop/large-fresnel-lens-f550.php
    I am not sure how that would be with the motion sim, but the effect of it in front of my LCD was pretty amazing. Cinema feeling in front of your LCD. In addition to the increased size of the image the eyes focuses behind the physical screen and that adds to the sim feeling. Cheap addon to your sim! :D Even my wife was impressed! That says a lot. :razz:
    @yobuddy - Thank you for the tip, I e-mailed StcValve yesterday. Still waiting for answer. I have checked several local vendors and the cheapest 5/3 valve I've found so far is around $180. I hope STC Valve can ship to me.
  3. SimHawk
    SimHawk Member
    Engineer
    Norway
    Todays progress:
    I got my Velleman card. I soldered the components in place and connected it to the PC. Then fired up profiler and selected the correct interface. Answered NO on use joystick as analog input and now it works! :D The LED's work... I have no simulator yet. The cylinders are on its way so all I am missing now is the valves to complete my simulator. If anyone know how to get some cheap 5/3 valves I'd be happy. Still no answer from STC Valves in the US. :(
  4. yobuddy
    51,747Coins
    Calling them would only take a minute, 650-856 8833
  5. egoexpress
    422Coins
    Talking to somebody with an american slang is not that easy for an european guy ;)
  6. yobuddy
    51,747Coins
    Ill call them for you if you want SimHawk.
    I know it can be hard to find decent valves at a good price.
    It took me quite awhile so don’t get discouraged.
  7. SimHawk
    SimHawk Member
    Engineer
    Norway
    @ yobuddy
    Thank you, I have sent another e-mail to stc and one to Fremont Industrial Supply as well. If I do not hear from them I'd be glad if you could help. I have a contact in NYC that could order them for me and forward them to me if it is a problem with shipping to Norway. I'll let you know.
    Edit:
    I got a reply from Fremont Ind. Supply, they do not ship out of US. Guess I have to get my contact in NYC to order it for me.
  8. SimHawk
    SimHawk Member
    Engineer
    Norway
    Yesterday I started fabricating the frame. In the evening I realized that the frame was too wide to get trough my door! I have to decrease the width to 78cm to be able to move it around inside. What is the dimensions of other frex/SimForceGT frames?
    I also received the cylinders, but wrong stroke length, returned them and waiting for new ones.
  9. SimHawk
    SimHawk Member
    Engineer
    Norway
  10. yobuddy
    51,747Coins
    your pivit point looks great!
    can I ask you where you got your rubber mount?
  11. SimHawk
    SimHawk Member
    Engineer
    Norway
    @yobuddy - The rubber mount is an engine mount that I got from a local car spare parts shop for $7
    I got my cylinders yesterday and tested the force it developed. I have no doubt it will be enough for the sim! Now I have to wait a few weeks for my valves. As a wait for that I have to finish my frame and mount pots, seatbelts and so on.
  12. SimHawk
    SimHawk Member
    Engineer
    Norway
  13. egoexpress
    422Coins
    Until you have servo valves, you should decrease the pressure a little :)
    Where are you going to connect the pots?
  14. RaceRay
    23,892Coins
    Man, you are totally crazy. Don´t you know, why the automotiveindustrie uses muppets, better known as dummys? :D Such dumps could be deathly for you neck. If you want to be a human dummy, please use HANS (Head And Neck Support), so we can be sure you will survive and be able to show us the further progress of your excellent working simulator ;-)
    Why did you move only two times on your chair, compressor empty, or did it hurts too much?
    Keep on going - well done alternative for the Pain Chair by evanF ;-)
    Even if i write some laughy emoti´s:
    Please be careful with very high pressures. It´s not worth to play with your health.
  15. SimHawk
    SimHawk Member
    Engineer
    Norway
    Yes, the HANS device has saved a lot of drivers. It was not that violent. BTW. I had the end-air damper on the cylinders on max damping to avoid destruction of the cylinder. And I only did it a few times. But it was fun and inspired my further work! 8)
  16. tronicgr
    tronicgr
    I agree you are crazy! :eek:
    Even I placed a dummy weight on my simulator for the first tests!!!
    Thanos
  17. SimHawk
    SimHawk Member
    Engineer
    Norway
    No pain - no gain! 8)
  18. SimHawk
    SimHawk Member
    Engineer
    Norway
    They are already mounted. Here are some pictures:
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    As you can see I use a rubber band so there are always tension on the levers to eliminate dead zones. If it works during racing - nobody knows yet.
  19. riton
    riton Active Member
    1,006Coins
    How pots has climbed you? One on each actuator?
    Your simu works properly with the position of pot?
  20. SimHawk
    SimHawk Member
    Engineer
    Norway
    I am not sure if I understand your question. I have mounted one pot on each cylinder and it works well with the force profiler. I have not tested it with the sim actuallu running a game yet.
