SIMHUB MOTION FOR SMC3
Discussion in 'Commercial Simulators and Peripherie' started by Silyn, Jun 6, 2024.
  1. nzteddy2020
    nzteddy2020 New Member
    Retired software developer
    New Zealand
    22Coins
  2. Mill2077
    Mill2077 New Member
    76Coins
    I have a 2dof seat mover
    How do I configure it so it simulates g forces rather than car suspension. I want seat to move forward when I brake hard, …
  3. Misanthrop
    Misanthrop Active Member
    928Coins
    You have to adjust the Surge(to Pitch) Value
  4. Mill2077
    Mill2077 New Member
    76Coins
    it worked, thank you so much! Was looking for this for the last few months
  5. Mill2077
    Mill2077 New Member
    76Coins
    Does anyone know how to configure a soft start?
    Every time I turn on my 2dof it violently snaps into neutral position
  6. Misanthrop
    928Coins
    How do you turn it on? change the value "Disable motion at startup", so you have to push on "enable motion" after you turned it on. It´s the best way.
  7. Silyn
    Silyn Member
    52Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Axis resolution is auto detected for dofreality and default to 10 with smc3 generic, but if you choose generic serial, it's there.
    Use the controller configuration area when you set up each actuator and make sure Up is Up correctly. That's the only way it can be wrong on manual mode.
    https://discord.com/invite/nBBMuX7 simhub discord
  8. Silyn
    Silyn Member
    52Coins
    Simhub has added more layouts fyi
  9. Misanthrop
    928Coins
    Not what he wants to have.
