simple 2 dof wiper sim
Discussion in 'DIY Motion Simulator Projects' started by Arunas, Apr 1, 2017.
  1. noorbeast
    154,729Coins
    +11,213 / 57 / -2
    Can you please post the full error details from the third photo, so @yobuddy can have a look at it.
  2. Arunas
    Arunas Member
    Lithuania
    2Coins
    Thank you @noorbeast .
    System.NullReferenceException: Object reference not set to an instance of an object.
    at SimTools_GameEngine.frm_GameEngine.LoadSavedSettings_Interface1()
    at SimTools_GameEngine.frm_GameEngine.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3131.0 built by: NET472REL1LAST
    SimTools_GameEngine
    Assembly Version: 0.2.2.5
    Win32 Version: 0.2.2.5
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    xaMCNTjcNSvjjeyLdDMmaBHUdxlt
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    Win32 Version: 4.7.3110.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Management
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Interface_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Interface_PluginAPI.DLL
    AxisAssignments_PluginAPI
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/AxisAssignments_PluginAPI.DLL
    enabled.
    For example:
    <configuration>
    </configuration>
  3. Arunas
    Arunas Member
    Lithuania
    2Coins
    I found problem. It was my local language problem because c/user/2 folders name Arunas.
      File size:
      641.2 KB
      719
  4. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    I at all,
    Same problem today o_O
    Any suggestion ??? :sos
  5. ilbiga
    Network Engineer
    103Coins
    When I start Dirt Rally I got this error:
    Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
    sono riportate in fondo al messaggio.
    ************** Testo dell'eccezione **************
    System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
    in SimTools_GameManager.Mod_ProfileManagement.‫‌‫‬‍‎‪‮‮‎‌‏‌‬‏‫‬‌‎‍‏‮(Object )
    in SimTools_GameManager.Mod_ProfileManagement.GameProfileChanged()
    in SimTools_GameManager.frm_GameManager.cb_GameSelection_SelectedIndexChanged(Object sender, EventArgs e)
    in System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
    in System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
    in System.Windows.Forms.ComboBox.set_SelectedItem(Object value)
    in SimTools_GameManager.frm_GameManager.‪‬‫‍‍‪‫‎‮‪‎‭‍‭‭‌‬‭‭‮‍‮‪‍‎‪‌‮(ComboBox , Object )
    in SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    in System.Windows.Forms.Timer.OnTick(EventArgs e)
    in System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Assembly caricati **************
    mscorlib
    Versione assembly: 4.0.0.0
    Versione Win32: 4.7.3190.0 built by: NET472REL1LAST_C
    Base di codice: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Versione assembly: 0.2.3.0
    Versione Win32: 0.2.3.0
    Base di codice: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    lGExrnZGAjiRTBZlJAdUYsgbbKoa
    Versione assembly: 0.0.0.0
    Versione assembly: 10.0.0.0
    Versione Win32: 14.7.3056.0 built by: NET472REL1
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    Versione Win32: 4.7.3056.0 built by: NET472REL1
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Versione assembly: 1.0.0.0
    Versione Win32: 1.0.0.0
    Base di codice: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    AssettoCorsaCompetizione_GamePlugin
    Versione assembly: 2.0.0.0
    Versione Win32: 2.0.0.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/AssettoCorsaCompetizione_GamePlugin.dll
    AssettoCorsa_GamePlugin
    Versione assembly: 2.0.7.0
    Versione Win32: 2.0.7.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/AssettoCorsa_GamePlugin.dll
    CityCarDriving_GamePlugin
    Versione assembly: 2.0.3.0
    Versione Win32: 2.0.3.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/CityCarDriving_GamePlugin.dll
    DCS_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/DCS_GamePlugin.dll
    Dirt3_GamePlugin
    Versione assembly: 2.0.0.1
    Versione Win32: 2.0.0.1
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/Dirt3_GamePlugin.dll
    DiRTRally_GamePlugin
    Versione assembly: 2.1.1.0
    Versione Win32: 2.1.1.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/DirtRally_GamePlugin.dll
    DirtShowdown_GamePlugin
    Versione assembly: 2.0.0.4
    Versione Win32: 2.0.0.4
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/DirtShowdown_GamePlugin.dll
    EliteDangerous64_GamePlugin
    Versione assembly: 2.0.2.0
    Versione Win32: 2.0.2.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/EliteDangerous64_GamePlugin.dll
    EuroTruckSimulator2_GamePlugin
    Versione assembly: 2.0.2.2
    Versione Win32: 2.0.2.2
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/EuroTruckSimulator2_GamePlugin.dll
    F12014_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/F12014_GamePlugin.dll
    F12015_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/F12015_GamePlugin.dll
    F1_2017_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/F1_2017_GamePlugin.dll
    Falcon4BMS_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/Falcon4BMS_GamePlugin.dll
    FSX_P3D_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/FSX_P3D_GamePlugin.dll
    GRID2_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/GRID2_GamePlugin.dll
    GRIDAutosport_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/GRIDAutosport_GamePlugin.dll
    GTR2_GamePlugin
    Versione assembly: 2.0.0.2
    Versione Win32: 2.0.0.2
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/GTR2_GamePlugin.dll
    LiveForSpeed_GamePlugin
    Versione assembly: 2.1.0.0
    Versione Win32: 2.1.0.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    LunarFlight_GamePlugin
    Versione assembly: 1.2.2.0
    Versione Win32: 1.2.2.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/LunarFlight_GamePlugin.dll
    NFSMostWanted2012_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/NFSMostWanted2012_GamePlugin.dll
    NoLimits2_GamePlugin
    Versione assembly: 2.0.1.17
    Versione Win32: 2.0.1.17
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/NoLimits2_GamePlugin.dll
    pCARS2_GamePlugin
    Versione assembly: 2.0.5.4
    Versione Win32: 2.0.5.4
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/pCARS2_GamePlugin.dll
    pCARS_GamePlugin
    Versione assembly: 2.0.1.0
    Versione Win32: 2.0.1.0
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/pCARS_GamePlugin.dll
    R3E_GamePlugin
    Versione assembly: 2.0.3.2
    Versione Win32: 2.0.3.2
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/R3E_GamePlugin.dll
    Race07_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/Race07_GamePlugin.dll
    rFactor2_GamePlugin
    Versione assembly: 2.0.0.3
    Versione Win32: 2.0.0.3
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/rFactor2_GamePlugin.dll
    XPlane_GamePlugin
    Base di codice: file:///C:/Users/Biga/AppData/Local/SimTools/GamePlugins/XPlane_GamePlugin.dll
    Microsoft.GeneratedCode
    mscorlib.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Debug JIT **************
    Per abilitare il debug JIT, è necessario impostare il valore
    jitDebugging nella sezione system.windows.forms del file di configurazione
    dell'applicazione o del computer (machine.config).
    L'applicazione inoltre deve essere compilata con il debug
    abilitato.
    Ad esempio:
    <configuration>
    </configuration>
    Quando il debug JIT è abilitato, tutte le eccezioni non gestite
    vengono inviate al debugger JIT registrato nel computer,
    anziché essere gestite da questa finestra di dialogo.
  6. Arunas
    Arunas Member
    Lithuania
    2Coins
    Hi
    check your c/user/2 folders name. My problem was 2 folder with my name Arunas and my local language Arūnas.
  7. Arunas
    Arunas Member
    Lithuania
    2Coins
    Like this picture. If yes i will show how to make one folder.
  8. ilbiga
    Network Engineer
    103Coins
    Thanks, but I have different problem. I don't have 2 folders with the same username.
    Since SimTools 2.2.5 simulator are ok, but during the update to 2.3 something went wrong :confused: and now I have this issue when I start various games (Same problem starting Dirt Rally and Assetto Corsa :think)
    154,729Coins
    +11,213 / 57 / -2
    First try switching to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    If the problem continues after that then:
    • Close all running software applications.
    • Go to Windows Start Menu -> Control Panel -> Add or Remove Programs or Program and Features.
    • On the left column click turn windows feature on or off
    • Select Microsoft .NET Framework 4 Extended.
    • Click Change/Uninstall, Remove or Repair.
    • Select the Repair option, click Next.
    • The wizard will perform a repair on the .NET Framework installation.
    • It is suggested to restart the Computer.
  10. ilbiga
    Network Engineer
    103Coins
