News SimTools 2.0 Question and Answer
Discussion in 'News' started by yobuddy, Feb 29, 2016.
Thread Status:
Not open for further replies.
  1. Thread
    Thread Member
    295Coins
    I see, thank you, then i should document my rig with pictures. I can do that, without the actual building process, because did not take pictures on the welding, etc.
  2. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    I had a doubt. I just got my license for SimTools V2.
    I have two computers interfaced with the simulator (one more powerful with Oculus Rift and one connected with monitor).
    The license can be activated on multiple computers, or I can register it once?
    If I had to format the PC, I would need a new license?o_O
    Thank you
    Mi è venuto un dubbio. Ho appena ricevuto la mia licenza per SimTools V2.
    Ho due PC che interfaccio con il simulatore (uno più potente con Oculus Rift ed uno connesso con il monitor).
    La licenza può essere attivata su più computer, o posso registrarla una sola volta?
    Se dovessi formattare il PC, avrei bisogno di una nuova licenza?o_O
    Grazie
    154,675Coins
    +11,209 / 57 / -2
    The license can be downloaded here and gives you the right to install one copy of SimTools 2.0 on either one computer you own/lease, or one dual computer setup you own/lease: https://www.xsimulator.net/community/attachments/simtools-2-0-eula-zip.33771/
  4. ilbiga
    Network Engineer
    103Coins
    Ok, I have read.
    Then, if I have to format the PC to make a clean installation everything needed for the simulator, I will have to apply for a new license? And in this case, I will be able to request a new license for DIY user, or I'll be forced to buy a "Pro"?
    Sorry for all these questions, but after all the work done, I would not make mistakes now that I'm almost to the finish line :p
    Ok, ho letto.
    Quindi se dovessi formattare il PC per un'installazione pulita di tutto il necessario per il simulatore, dovrò fare richiesta per una nuova licenza? Ed in tal caso, potrò richiedere una nuova licenza per DIY user, o sarò costretto ad acquistare una "Pro"?
    Chiedo scusa per tutte queste domande, ma dopo tutto il lavoro fatto, non vorrei fare errori adesso che sono quasi al traguardo:p
    154,675Coins
    +11,209 / 57 / -2
    No, if it is a clean install and the provisions of the License are still met that should be OK.
  6. ilbiga
    Network Engineer
    103Coins
    OK thanks a lot!!!
    Ok, grazie molte!!!
  7. yobuddy
    51,741Coins
    No, re-activations from the same unmodified PC don't count again your activation limit.
  8. ilbiga
    Network Engineer
    103Coins
    I apologize for the question, the license is tied to the operatve system or to 'hardaware of the Motherboard?
    I would like to eventually install dual Operative System (Win7 & Win10) in "dual boot" configuratione and use the same license.
    Thank you
    Chiedo scusa per la domanda: la licenza è legata al Sistema Operativo o all' hardaware della Motherboard?
    Vorrei eventualmente installare doppio sistema operativo (Win7 & Win10) in dual boot ed utilizzare la stessa licenza.
    Grazie
  9. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    hello , actually i have the exact same question about how is tied the licence. Also , what are the activation limits in number? is there a possibility to reset that number with an email?
    why is there a limitation of activation ? PCs crash sometimes...
    why not a desinstall procedure like de z1 software ? that woulk reduce the headaches .(i know i am not a programmer , just my 2 cents)
    thanks
  10. Bernd Manger
    Bernd Manger Active Member
    Measurement and control mechanic
    1,055Coins
    Hello, i have another question about licensing. Why my sim-pc has to be online if i want to start TimTools ? Ok, 1 time for the registration-procedure, but every time i want to start my sim ? I live in the country with a bad internet connection at "rush hour". So do i have to start my sim after schedule ? ;)
    With this restriction this so great update for me is unusable.:(
  11. Pit
    30,517Coins
    This issue is in the pipeline of development.
  12. Bernd Manger
    1,055Coins
    I am glad to hear this. Thanks !
  13. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,951Coins
    Just don't tell anyone guys :D:D:D:D:D ...
    Why do I have that hidden feeling about preparing a couple of PRO Licences to be as an upgrading winner gifts that goes to the top of the list most creative and well documented projects in the DIY section ? ...
    • Friendly Friendly x 2
  14. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Great work guys,
    I got everything working pretty easily with a bit of help from Nick.
    I have not had a ton of time tuning as I just got it all going a few hours ago. But the resolution is SOOOOO much better over 1.3. There are details and undulations that I have never felt on tracks I very familiar with. Really good job guys!
  15. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
  16. obobo
    obobo Active Member
    1,323Coins
    Yes it is true that the EULA should be available on simtools.us directly
  17. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    hi guys
    been using sim tools 1.3 for years now along with game dash and was just wondering if there was any eta on the release of game dash 2.0?
    Now that sim tools 2.0 has been released I would very much like to purchase a pro licence and upgrade for the benefits that the new software will give to my 2Dof with overstear, however if I do I wont have any dash output and as my dash uses 13 outputs from game dash it will seem like half a sim. I cant upgrade just to test the new software under a diy licence because I would have to remove simtools 1.3 completely to test.
    this is prob a question for the simtools 2.0 development team but after waiting nearly a year for simtools 2.0 to be released I realy cant wait to get it on my sim if I'm honest.
    lastly id like to thank everyone involved for the free use of sim tools for all this time, your sim software is epic.
    regards
    matt
  18. noorbeast
    154,675Coins
    +11,209 / 57 / -2
  19. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    Thanks for the prompt reply @noorbeast . maybe ill backup and give it a try when I get a free day. I would rather wait and upgrade all software at the same time motion and dash unless the release of game dash 2.0 is not in the near future.
    Also would u be able to confirm if game plugins for sim tools 2.0 send out the same dash info as plugins for 1.3?
    regards Matt
  20. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,978Coins
    I hadn't noticed this thread until now, I guess that's what I get for always being in a hurry!
    Edit: Apparently v.2 is now available, so I guess my question about beta testing is irrelevant. Hopefully I'll get started trying it out on my SIM Monday night!
    I'm super excited for vibe function and enough axes to run a G-seat (which I want to add) plus the motion SIM. I haven't yet started using SimTools as I'm waiting for 2.0 for proper Stewart Platform support!
    Thanks again for you hard work guys, I'll be buying the pro license for vibe etc. =D
Thread Status:
