SimTools interface driver for YawVR
Discussion in 'Commercial Simulators and Peripherie' started by Marc Fdx, Feb 20, 2021.
  1. m6248
    m6248 New Member Gold Contributor
    6Coins
    After having reverse engineered the Yaw Game Engine and doing a lot of logging in the Yaw VR Interface plugin I finally have found the culprit. The interface failed on parsing the Yaw data as it was expecting a U value in the data which was not present. I'm not sure if this was changed over time or if this feature has ever even worked but now I can finally see the XYZ gizmo and it follows the Yaw VR chair movement.
    @noorbeast I am tagging you in this as I cannot seem to tag Marc fdx
    To fix the interface, I changed this line in the TransferYawData_Thread of YawVR.vb
    Batt = 1 'GetValueFromString(strMessage, "U[")
    instead of trying to parse a value that is never found, I set Batt to be 1 for now
    154,520Coins
    +11,184 / 57 / -2
    @Marc Fdx has not been around since January, life gets busy like that sometimes.
    I will flag it for @yobuddy, as the SimTools dev.
  3. m6248
    6Coins
    Small follow up. According to a Yaw VR developer on discord, the U value is only sent by the Yaw 1. Which is why it broke when using it on the Yaw 2. But as far as I can tell, the battery level is never used in the plugin so I guess parsing it can be removed altogether.
  4. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    3DOF, Motion platform
    Wow, great work figuring this out!!
    I wouldn't even be able to figure out what I am looking at, so hat of to you :)
