News SimTools v2.2 is out!
Discussion in 'News' started by yobuddy, Dec 22, 2017.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    ok.. just for some guys... today, i update to 2.2, 2.1 game manager, and elite dangerous just sttop working. so.. if you make a actualization, be prepar to put new plugins too.
  2. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    I changed the Simtools version, from 1.3 to 2.2.
    Usualy, does the Min/Max are the same or this setting must be différent between the 2 versions ?
    154,819Coins
    +11,226 / 57 / -2
    It is best to redo motion profile settings, as SimTools 2 can have better performance.
  4. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    Ok .
    Thanks ;)
  5. vsp19
    vsp19 keep Sim-Racing Gold Contributor
    170Coins
    2DOF, 3DOF, SCN6
    HelloI want to run 7 Frex HyperAxis with SimTools.
    But every HyperrAxis needs its own comport for connection
    because the Frex 485Motion box has one output for each HyperAxis
    and these outputs each require a comport assignment
    Does anybody have a solution ?
    My motion rig has as a platform movers
    4 HyperAxis for the platform
    1 HyperAxis for Traction loss
    1 HyperAxis for belt tensioning
    1 HyperAxis for Sway Air GForces
  6. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    can you not run 12 actuators with simtools v2.2?
  7. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Theoretically yes and that's why I've tried this for a whole day.
    Unfortunately, I did not get it.
    I got the HyperAxis dividend in Port 0 and 1 in Dywidag-Toll,
    but it does not work in SimTools.
    The HyperAxis each require their own comport
  8. yobuddy
    51,770Coins
    Did you set one of your HyperAxis to an ID of 1?
    And they are both connected to the same port?
  9. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Hello @yobuddy
    Yes I set one of your HyperAxis to an ID of 1 and the other to 0?
    it works now with Digitus 485
  10. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,946Coins
    Hi @yobuddy - I've been exploring v2.25 today. One big thing I was hoping to be able to do was pin the virtual axis inside the Rift VR so I could inspect it while flying. It doesn't work though. Oculus won't grab it. Is there something about the Game Engine window that is different to a normal window that might be preventing this?
  11. yobuddy
    51,770Coins
    No, not that I know of buddy.
  12. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    hi im using sx-4000 with scn6 and im getting error one of your interface requires game engine to be restarted
  13. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    ok somehow got past the error now trying to configure in game engine any simple guide for noobs
  14. noorbeast
    154,819Coins
    +11,226 / 57 / -2
    First make sure your sim moves the correctly, the DIR boxes in Axis Assignments determine which way and axis/force moves: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Then take your time and follow the steps to creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  15. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    thank you though i have been using sim commander for a while i had no idea what i was doing and getting any kind of response from them is still a nightmare but the sim tools guide is really great it makes sure you understand the basic concept
    sorry one more question in axis assingments axis 1a is left and 2a is right correct?
    and when highlighted the axis moves up and non highlighted axis moves down or the opposite direction correct?
    thanks for all the quick response
  16. noorbeast
    154,819Coins
    +11,226 / 57 / -2
    As mentioned the DIR boxes in Axis Assignments determine which way each axis/force moves, not the Interface Settings 1a and 2a (but they do determine which motor is assigned to which designation), and your rig motion should follow this convention: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
