SimTools v2 - Game Dash v2.3
Format and Send Game Dash data to a device/program.
  1. yobuddy
    51,781Coins
    I can't figure out why you need the 'MATH * 1' command?
    I can't see how it does anything?
  2. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    It doesn’t, but thats how the tutorial had it so I just kept it there. I will either remove it use it to scale the fan output. I have to play around with it now that it is working.
  3. yobuddy
    51,781Coins
    Roger, just thought I was missing something...:thumbs
  4. VirtualObsession
    VirtualObsession Member Gold Contributor
    IT developer
    Hertfordshire, UK
    280Coins
    My Windows PC absolutely refuses to allow me to download and execute this zip file. Chrome and Edge download the file, but the virus scanner immediately deletes it. So I tried a less paranoid browser. It downloads. But once I unpack the executable, the OS marks it for immediate deletion. I'm assuming this is not a virus packed executable. Does anyone else have this problem?
  5. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    Nope. All you have to do is shuttoff anti virus. Example: actually, w10 uses defender. So, disable the 3 levels, install simtools, enter on "EXCLUDE" and put programs you choose, for exclude verifications.
    154,849Coins
    +11,229 / 57 / -2
    It is a false positive because of the way SimTools works: https://www.xsimulator.net/communit...r-as-trojan-win32-rundas-b.10708/#post-138738
    SimTools itself has been submitted to a range of anti virus vendors and has been cleared, like with Windows Defender, but you did not say what you are using.
  7. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Thanks for the replies. I just found out I can't use Dash anyway, as I have the DIY version of SimTools.
    154,849Coins
    +11,229 / 57 / -2
  9. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Yes, I should have bought the Pro license originally, but bought the DIY version a few hours ago. I'll live without Dash. Thanks.:(
  10. Blame73
    Blame73 Well-Known Member
    8,316Coins
    Maybe @yobuddy could help you with that should you wanted to upgrade to the pro license without paying the full price
  11. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
  12. yobuddy
    51,781Coins
    :thumbs
  13. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Every time I start Game Dash or change the Output Type I get the following Unhandled Exception. It's a Windows 10 Home PC. I get no error on my Windows 10 Pro PC. Any ideas?
    Code:
    System.NullReferenceException: Object reference not set to an instance of an object.
       at GameDash.frm_GameDash.SetOutputType_InterfacePages()
       at GameDash.frm_GameDash.Form1_Load(Object sender, EventArgs e)
       at System.EventHandler.Invoke(Object sender, EventArgs e)
       at System.Windows.Forms.Form.OnLoad(EventArgs e)
       at System.Windows.Forms.Form.OnCreateControl()
       at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
       at System.Windows.Forms.Control.CreateControl()
       at System.Windows.Forms.Control.WmShowWindow(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.ContainerControl.WndProc(Message& m)
       at System.Windows.Forms.Form.WmShowWindow(Message& m)
       at System.Windows.Forms.Form.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.7.2633.0 built by: NET471REL1LAST_C
    GameDash
        Assembly Version: 0.2.1.0
        Win32 Version: 0.2.1.0
        CodeBase: file:///C:/Program%20Files%20(x86)/GameDash/GameDash.exe
    RtGtiDQhLXHFePPQjGRlBgSWyfR
        Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 14.7.2556.0 built by: NET471REL1
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
        Win32 Version: 4.7.2556.0 built by: NET471REL1
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
        Win32 Version: 4.7.2612.0 built by: NET471REL1LAST_B
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    GameDash_PluginAPI
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/GameDash/GameDash_PluginAPI.DLL
    enabled.
    For example:
    <configuration>
    </configuration>
  14. yobuddy
    51,781Coins
    I would suggesting uninstalling GameDash.
    (be sure to answer yes to the (remove old settings and files popup.)
    And then reinstall it.
    Did you enable .net 3.5 in win10?
  15. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Simply uninstalling and reinstalling GameDash appears to have resolved that issue. Thanks:thumbs
  16. yobuddy
    51,781Coins
    Excellent man!
    Take care,
  17. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    333Coins
    I have a problem with Pcars2 and simwind, the dashes display the values but the fans are not spinning. All other racegames work fine.
    There's a more detailed description in the dedicated topic:
    https://www.xsimulator.net/communit...ut-from-gamedash-in-pcars2.11857/#post-154098
    I have diagnosed the problem further and narrowed it down to either a Pcars2 plug-in or gamedash related bug.
    The temporary fix is to close gamedash while Pcars 2 is running and launch gamedash again. This will result in spinning fans.
    Took me quite a while to figuer this out. Perhaps it's also related that i only use simwind and no other outputs or motion.
    @yobuddy can you have a look a this ?
    Thx
  18. yobuddy
    51,781Coins
    @HoiHman
    This was fixed in SimTools v2.2.5.
    If your are running v2.2, then just install v2.2.5 over the top.
    Let me know how it goes buddy.
  19. HoiHman
    Mechanic
    The Netherlands
    333Coins
    Looks like the bug is still present then mate, since i did a fresh install 2.2.5 early this week.
    I never even ran 2.2 before.
    I double checked, but as you can see above i am running 2.2.5
    Henk
  20. yobuddy
    51,781Coins
    I'll test it out soon
