SimTools v2 - Game Dash v2.3
Format and Send Game Dash data to a device/program.
  1. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    333Coins
    Thanks mate
  2. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Hello everyone, is there any installation instruction for the Game Dash? I want to use it for the first time
    Best
    Milton
  3. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    is there setup instruction for the Game Dash on how to make work with iRacing?
    154,849Coins
    +11,229 / 57 / -2
  5. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    154,849Coins
    +11,229 / 57 / -2
    Game Dash can control many different types of hardware from real world gauges to LEDs to wind simulation and tactile vibration motors. Game Dash is highly configurable and you need to learn how to use it for whatever hardware you intend running and thus far you have not even explained what that hardware is.
    If you can give some detail about what you are trying to do then perhaps some other members can help out.
  7. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thank you noorbeast i was wondering if i can use it on a monitor to Display the data with no external gauges just a computer monitor is that posible?
  8. Historiker
    Michigan USA
    9,212Coins
    154,849Coins
    +11,229 / 57 / -2
    It used to be possible with Webdash for SimTools 1.3, which is still listed for download, but I have checked with @yobuddy and @RaceRay and it looks like it should have been depreciated and taken down.
    So best to look at alternatives as @Historiker suggested.
  10. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    154,849Coins
    +11,229 / 57 / -2
  12. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thanks noorbeast, I notice that the link you provided me is for creating plugins what I was thinking to used is an API for Game Dash.
    FYI:
    API stands for Application Programming Interface. (API) is a set of programming instructions and standards for accessing a software application like Simtool Game Dash.
    I still would like to display Speed, RPM, Oil pressure, Temp, Fuel level, Tire pressure, Lap time, Position on the race, etc... on a computer monitor
    Let me know if GameDash has an API or maybe can display all that ?
    Thanks.
  13. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    The SimTools dev @yobuddy has been adding to the linked API doc as and when he can, for example:
    GameDash - Dash Board Support
    _Enable_DashBoard = False - Set to ‘True’ to enable the Dashboard Output System.
    (Basic Dash Support should include - SPEED, RPM and GEAR)
    Once enabled, you may assign up to 20 Dash output variables.
    ~ Examples~
    Assign the dash output variable as follows:
    Dash_1_Output = "Speed," & OUTPUT_VALUE_HERE.
    Dash_2_Output = "Rpm," & OUTPUT_VALUE_HERE
  14. john thornewill
    john thornewill New Member
    232Coins
    DC motor
    Hi - I recently had to reinstall Sim Tools on my C Drive to get it to work with Elite Dangerous, so I reinstalled Game Dash at the same time - it works with Assetto Corsa just fine, but it won't recognise Project Cars 2 is running at all. Has anyone got any ideas? Sim Tools works fine with PC2 so shared memory is enabled fine - is there anything else I can try???
  15. yobuddy
    51,781Coins
    SimTools won't detect the game running or Game Dash buddy?
    Game Patched with the newest plugin for the game?
    Take care,
  16. john thornewill
    232Coins
    DC motor
    Hiya... I forgot to say this was all working ok before I had to reinstall Sim Tools... I can try repatching PC 2 though anyway... Sim Tools is recognising PC2, but Game Dash doesn't... I've checked that Game Manager has the game dash option switched on too...
  17. yobuddy
    51,781Coins
    is the game listed in Game Dash?
  18. yobuddy
    51,781Coins
  19. john thornewill
    232Coins
    DC motor
    Yes... it's listed and I've set up the output options the same as assetto corsa which works...
  20. yobuddy
    51,781Coins
    may I have a screen shot of the game manager / profile editor / more page?
