SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    2DOF, SCN6, Motion platform
  2. yobuddy
    51,776Coins
    @PIM1,
    I'll take a look buddy.
  3. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
  4. deemjackson
    deemjackson New Member
    cambridge
    99Coins
    Quick question, is it possible to differentiate between the front and rear of the car? For example with road detail?
  5. yobuddy
    51,776Coins
    road detail uses the heave of the car to make sound.
    So 3D is not possible with road detail.
    You would need to use chassis mode in 3D to achieve that buddy.
    Take care,
  6. deemjackson
    cambridge
    99Coins
    Ive just done a clean install of windows and cant get gamevibe to launch. ive tried installing every version of DX I can find and .net 3.5 and still no joy :(
    System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
    at GameVibe.frm_SoundCardSettings..ctor()
    --- End of inner exception stack trace ---
    at GameVibe.My.MyProject.MyForms.Create__Instance__[T](T Instance)
    at GameVibe.frm_GameVibe.frm_GameVibe_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
    GameVibe
    Assembly Version: 0.1.6.0
    Win32 Version: 0.1.6.0
    CodeBase: file:///C:/Program%20Files%20(x86)/GameVibe/GameVibe.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    GameVibe_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/GameVibe/GameVibe_PluginAPI.DLL
    XAudio2_GameVibePlugin
    CodeBase: file:///C:/Users/danma/AppData/Local/GameVibe/AudioPlugins/XAudio2_GameVibePlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  7. yobuddy
    51,776Coins
  8. deemjackson
    cambridge
    99Coins
  9. yobuddy
    51,776Coins
    Since your on windows 10, do you have .net 3.5 enabled?
    Take care,
  10. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    Hi I still cannot get gamevibe to hook up. I have deleted it and re installed but no joy. Had the last one working fine.
    Don't know what to do ?
  11. deemjackson
    cambridge
    99Coins
    Yep, as far as I can tell ive tried everything suggested in this thread, and anywhere else I can find. :(
  12. yobuddy
    51,776Coins
    @deemjackson,
    The problem you are facing is this buddy "Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0"
    You can find games also have this problem on win 10 machines.
    https://answers.microsoft.com/en-us...tion-has/9a3b00a6-fac3-4166-89e7-31d98aa80186
    I'm guessing you rebooted after installing the Direct-x files I pointed you too?
    If you are still having problems, you could install the slimdx files found here: (you want the .net 4.0 x68 version)
    The developer sdk should also work.
    https://slimdx.org/download.php
    they should give you what you need also.
    But all others with this problem simply installed this: (what I originally pointed you too)
    https://www.microsoft.com/en-us/download/details.aspx?id=8109
    Is windows all up to date?
    Take care,
  13. yobuddy
    51,776Coins
    @PIM1,
    We setup a new test machine to help track the PCars problem.
    (Please give me a few to see what is happening.)
    Will you test GameVibe with another title and confirm you are just having a problems with this title please buddy?
    thx man!
  14. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    Hi yes of course and sorry I have only seen this message.
  15. yobuddy
    51,776Coins
    thx @PIM1,
    Wow, does PCars2 takes forever to install thru steam, lol.
    Chat soon!
  16. greatg67
    greatg67 Member Gold Contributor
    509Coins
  17. yobuddy
    51,776Coins
    It's a web installer, so there is nothing to put anywhere buddy.
    You just click download, on the next page uncheck everything, and there is a button on the lower right of the page to continue.
    Take care!
  18. topcox
    topcox New Member Gold Contributor
    - 7Coins
    Hello
    I have the following problem:
    The installation of Game Vibe worked. I am working on a 2nd PC.
    The connection to the 1st PC also works perfectly.
    I get data from the game (P3D) in Tuning Center.
    Creating a vibe also works in the Vibe creation and I also have an output of the sound in the bass shaker. During the game, however, no sound is output to the bass shakers.
    I have 2 bass shakers and configured quadrophony.
    Olaf
  19. yobuddy
    51,776Coins
    What game Olaf?
    And did you set some Hi/Low values for the game you want to play?
    Take care,
  20. topcox
    - 7Coins
    In the flight simulation P3DV4.2
    Yes, I set Hi and Low values for (RPM in this case).
    Another special feature: I can not use the squaresound in Vibe creation ?!
    Olaf
