SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. topcox
    topcox New Member Gold Contributor
    - 7Coins
    correction !
    Squaresound works, but only up to a very low volume in the Vibe Creator.
    Olaf
  2. yobuddy
    51,776Coins
    They are all just sound files, so they should all work. (white noise may be a bit of an exception).
    My guess is the frequency is out of range and you get nothing?
  3. topcox
    - 7Coins
    Thank you very much for your efforts!
    But if the sounds are output from the Vibe Creator, would they have to be within the usable range of the game?
    Maybe the HI/LOW config is not readable ?
    Olaf
  4. yobuddy
    51,776Coins
    I was talking about the sqr sound you said did not work.
    It seems like the strongest sound for me thou.
    Do you use the comma or a period as a decimal separator buddy?
  5. topcox
    - 7Coins
    Sqr-Sound is okay!
    I use point now as decimal seperator.Before i used comma.Nothing has changed.
    Should Gamevibe startet as admin?
    Olaf
  6. yobuddy
    51,776Coins
    Please try this buddy,
  7. topcox
    - 7Coins
    Also no change.
    Is there a way to check if the values from the tuning center enable the sound file in Game Vibes?
    Since I get values from the game (P3DV4.2), it could well be that one
    Problem with the audio settings is.
    However, when creating the vibes in the creator, the output works fine.
    I use the Asus Xonar DGX 5.1.
    Today also i have istalled Simtools 2.3.
    Olaf
  8. yobuddy
    51,776Coins
    If you use Simtools 2.3, then both GameDash and GameVibe must be the new versions also.
    Next, Try GameVibe with Live fore Speed to make sure its not just a particular game your having problems with.
    Chat soon,
  9. topcox
    - 7Coins
    The versions are all up to date.
    Even with LFS I get despite data in the tuning center no sound output.
    For some reason, the incoming data does not produce sound ...
  10. yobuddy
    51,776Coins
    Hi @topcox,
    Please open a new thread and we can look over you settings there buddy.
    (PM me the link man)
    Take care,
  11. topcox
    - 7Coins
    Wilco!
    Olaf
  12. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    2DOF, SCN6, Motion platform
    Hi I can confirm that Assetto Corsa is working with game vibe perfectly but still nothing with project cars 2 ? any help would be great thanks
  13. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,447Coins
    AC motor, 6DOF
    Couple of questions.
    On the test screen. When turning on I see the letters SQR.
    Your not sending out square waves on the audio channel are you?
    What audio frequency range is outputted for the different effects?
    The transducers are low freq devices I thought..
  14. yobuddy
    51,776Coins
    I think it's a bug, hope to knock it out this weekend.
    One thing that seems to be causing problems also,is there are a few plugin for PCars2,and I have even seen some people with more than 1 plugin for the game loaded at the same time.
    Take care,
  15. yobuddy
    51,776Coins
    There is a few test screens, not sure which one you are on buddy.
    But yes its a low frequency square wave.
    Depending on the test screen you are on, you can set what sound type you want for output.
    Take care,
  16. deemjackson
    deemjackson New Member
    cambridge
    99Coins
    Would anyone know if it's possible to output a certain audio sound from assetto corsa to Gamevibe?
    It would be great to have the rumble strip sound as a separate option. The 'Surfaces' Audio is pretty much only the rumble strips - how could I get that sound to my transducer?
    Many thanks
    D
  17. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    Hi Thanks so much, looking forward to it ;-)
  18. yobuddy
    51,776Coins
    Tune in 'Chassis' in GameVibe, you will get this from the transducers.
    Take care,
  19. Neo_One
    Neo_One Member Gold Contributor
    Obersulm
    198Coins
    2DOF, AC motor, Arduino
    have vibe installed today after the program opens an error message got this time attached as a TXT can someone help me there please?
  20. yobuddy
    51,776Coins
