SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. yobuddy
    51,766Coins
    @Bacon2002,
    Is the ip addresses for both app's (GameVibe and the vibe output in GameManager) set too 127.0.0.1?
    Thanks man,
  2. Bacon2002
    Bacon2002 Member
    Underwriter
    28Coins
    SCN6, Motion platform
    yobuddy,
    Yes they are both set to 127.0.0.1
    Is that a mistake?
    Ta,
  3. yobuddy
    51,766Coins
    Nope, if they are both on the same PC this is correct!
    Just checking is all.
    Take care,
  4. Chipless
    Chipless Member
    152Coins
    So, after taking a break from troubleshooting Game Vibe, I decided to jump into it again (see issue documented via text and videos below). During my break, I came up with one additional idea to try: A Bluetooth Audio receiver. I figured that would eliminate any potential hardware problems. Long story short: The crackling still exists and is just as prevalent. Is anyone able to set up a sin wave tone with differing Hz for min and max, and slide the "Percent Used" slider around within the "Testing" section of the Vibe Creator window to see if they hear crackling as the slider is moved? I've tried everything up to this point I feel like (multiple different PCs, multiple different USB DACs, multiple different speakers, and multiple different cables). Even tried installing an SDK used for development of Game Vibe. It has to be an issue with the software and my version of Windows 10 Pro ver. 2004. I've kept Windows up-to-date over the time I've spent away from Game Vibe, but sadly no update fixed the issue. The only thing I can think of doing a fresh install of Windows, but then again, using the different PC still had the same issue...anyone able to replicate or have additional suggestions? I think I would donate a kidney for Game Vibe to work at this point haha.
  5. DragonZideutch
    DragonZideutch New Member Gold Contributor
    Matane, Québec, Canada
    - 218Coins
    Hi @yobuddy,
    Did somebody found a solution to this problem about gamevibe error message popup RI_vibrationID.cfg?
    I have latest gamevibe , game manager , game engine. Etc...
    Only Dirt 4 plugin does that. All other plugins works Well with gamevibe . Motion is fine for app plugins.
    Same picture as ERGUN OZIURT from this thread
  6. DragonZideutch
    - 218Coins
    Motion is fine for All plugins including dirt 4.
    Damn corrector error in previous message.
    Sorry ;(
  7. yobuddy
    51,766Coins
    I believe it to be an error in the plugin itself.
    I will fix it when I am upgrading the plugins for v3.
    Take care,
  8. DragonZideutch
    - 218Coins
    thank you for you fast reply,
    glad to be part of this place where i can fulfill my passion for racing and enjoying all these hardware projects created by so many enthusiasts of this hobby.
    i really like the way this website works and the friendship and knowledge of everybody that are not afraid to help and share.
    thanks for all your efforts.
  9. Escartiz
    Escartiz Member
    - 16Coins
    3DOF, DC motor
    Is there a way to use game vibe with a simtools diy license? I initially applied for the free version but never got a response so I ended up purchasing the DIY license not realizing vibe only works with the professional license. I installed sim hub to control the shakers and it seems to be working fine so not a big deal but I wanted to make sure if it's possible, that way I could erase simhub and stick with simtools software instead.
    154,783Coins
    +11,217 / 57 / -2
    No you can't, but you can upgrade from the DIY to Pro SimTools license by logging into SimTools.us. There you will find an upgrade path for a DIY license to Pro for $29.99.
  11. Escartiz
    Escartiz Member
    - 16Coins
    3DOF, DC motor
    wonderful, thank you :)
  12. Patte83
    Patte83 Member
    24Coins
    When i play msfs2020 with game vibe the Rpm sound is always on even im not flying.. How can i fix this please help :)
  13. Escartiz
    Escartiz Member
    - 16Coins
    3DOF, DC motor
    you need to edit the specific vibe under vibe creator and set the "when input data = 0%" to 0
  14. Patte83
    Patte83 Member
    24Coins
    ok thanks
  15. yobuddy
    51,766Coins
    You can also do it by setting the Low value in the Hi Low settings to say 500.
    Now any input below 500 will now be off
  16. Patte83
    Patte83 Member
    24Coins
    strange dont work sound kicks in when game starts. "msfs2020"
  17. yobuddy
    51,766Coins
    If you can see the rpm in the game, take note of that value, and set the Low value above that value.
    500 may be to low for a plane, try 2000 for a test.
  18. Patte83
    Patte83 Member
    24Coins
    ok will do :)
  19. Watchumacallit
    Watchumacallit BMET- Lead
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Sorry if this has been mentioned before but can I use a USB sound card for game vibe?
  20. yobuddy
    51,766Coins
    Yes! :thumbs
