SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. RobertH
    RobertH Member Gold Contributor
    The Netherlands
    1Coins
    2DOF, SCN5
    Did you used the GameVibe – Vibe Creator?
    I noticed that some sounds didnt produce any vibrations.
    Your sound system must be setup to create low frequencies too (down to 5Hz).
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    yeap.. buddy rs.. im using simvibe bout 2 years... and 8 transducers... i made my own amplifier... see my rig: i prefer gamevibe, for simple and auto vibe direct on simtoools... simvibe works on simcommander4... more and more programs...
  3. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hello everyone and excuse me the probably "stupid" question: is it worth changing the simulator by adding amplifiers and bodyshakers and using SimVibe? Currently I have simply connected the low-frequency channel to a pair of bodyshakers ...
    Does the implementation of SimVibe significantly improve the experience?
    Thank you :cheers
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Do you mean Game Vibe as Simvibe is supported on a different website?
    If you mean Game Vibe then yes it’s Awesome makes a big difference to just using Game sounds to activate body shakers !!
  5. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    If you mean simvibe then I can’t answer that as I’ve never used it.
  6. ilbiga
    Network Engineer
    103Coins
    Yes, I apologize for the mistake;
    I meant exactly "Game Vibe" (as a complement of TimTools), as the title of this thread.
    Thank you
  7. paulopsx2
    brasil
    649Coins
    im still have problems. gamevibe dont works. ip correclty. test sound ok on all transducers, recent plugins download, movements and dash are ok, tunning center working,.. but no vibes.
  8. Wanegain
    Wanegain Active Member
    Bruxelles
    2,021Coins
    Same issue here... I tried to set on different sound cards, I can setup all the config, tuning center is working but not vibes in any games (AC, Pcars, KRP, DiRT Rally, NoLimits...). Tested with and without admin, still no vibes...
  9. Ringorumble
    Ringorumble Active Member
    190Coins
    Start it when you on track
  10. paulopsx2
    brasil
    649Coins
    me too..
  11. paulopsx2
    brasil
    649Coins
    i try this... dont work
  12. Wanegain
    Bruxelles
    2,021Coins
    I will try.
    I have the "bip" when the game is starting, like something is wrong with Simtools... Is it possible to know why there is this bip ?
  13. pimpi84
    pimpi84 New Member Gold Contributor
    Italia
    - 117Coins
    Hi all!!.
    I just discovered yesterday that GameVibe was released finally, and of course I immediately started playing around with it.
    Note: I am on PS4, so I am using @vthinsel 's great UDP plugins (pcars and AC).
    I noticed that Pcars UDP plugin passes only RPM as GameVibe data, and actually it works wonderfully with shakers.
    Assetto corsa UDP plugin instead does not pass anything.
    I thought that GameVibe was based on data already available at Simtools, and therefore it wouldn't need any additional plugin modifications to work.
    Or maybe in order to operate correctly (e.g. to have chassis vibrations mapped) it is needed to somehow touch the plugin code?
    Thank you very much. Great improvement from immersion point of view!!!!!!!
  14. noorbeast
    154,675Coins
    +11,207 / 57 / -2
    Game Vive requires existing plugins to be updated to support it.
  15. Ringorumble
    190Coins
    Isnt it the "cant connect to Com Port " for any of your interface "beep" ?
  16. yobuddy
    51,738Coins
    Yes, if an interface fails to startup, you get a Beep beep.
  17. Wanegain
    Bruxelles
    2,021Coins
    Ok I see, nothing to see with GameVibe... :(
  18. riton
    riton Active Member
    1,006Coins
    no one seems to make Game Vibe work with Assetto Corsa.
    same problem for me.
  19. jcgsa40
    jcgsa40 New Member
    New York
    - 55Coins
    I cannot run Game Vibe. It always shows the message
    "An error occurred creating the form. See Exception.InnerException for details. The error is: Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified."
    When I start the application, it shows this message, but allows me to click on "Continue". If I continue, the application opens, but if I click on Sound Card Setup or Vibe Creator, it freezes.
    I have already tried installing DirectX SDK from Microsoft, SlimDX SDK and even reinstalling Windows 10, but cannot fix it.
    Does anybody have any suggestions? Thank you.
  20. Nick Moxley
    17,057Coins
    I guess me and @Historiker are the only lucky ones. lol
