SimTools v2 - Video Ride Creator v2.1
Create video ride films for the Video Ride Player
  1. Rudyanto Sudarman
    Rudyanto Sudarman Anoqtion
    Robotic Engineer
    Jakarta
    107Coins
    Hi, Nite Too Meet you all.
    I just started join this community.
    I am interest to video creator . I just download and try input the video... but why the program always force to close? or i need install the plug in player first?
    thanks
    154,729Coins
    +11,213 / 57 / -2
    Can I check, are you running the Pro version of SimTools or the demo version? I ask because the demo version does not support additional functionality of SimTools, it only allows the use of Live For Speed to test motion, a licensed version is needed for extended functionality: https://simtools.us/license/
  3. yobuddy
    51,753Coins
    Can you play the video you trying to load with windows media player?
  4. Jaysonchou111
    Jaysonchou111 New Member
    188Coins
    This post looks very technical, but unfortunately, my English realy not well that I can hardly understand it.
  5. Edaurdo
    Edaurdo Member
    Buenos Aires, Argentina
    190Coins
    @yobuddy , Thank you very much for the information!
    What is the maximum duration of the videos that can be processed
  6. yobuddy
    51,753Coins
    I opened a 3 hour movie without any problems.
    3 hour's longer than anything I would expect to be produced with the tool.
    Take care,
  7. Edaurdo
    Edaurdo Member
    190Coins
    Thank you very much! Very soon I will be testing
  8. mysimnet17
    mysimnet17 New Member
    australia
    210Coins
    BUZZ BUZZ ... :)
    so last time it was a couple of weeks back in November 2017 , is VRC Input available in downloads yet ?
  9. yobuddy
    51,753Coins
    @mysimnet17
    I have VRC Input and a lot more updates coming next week.
    We have spent all summer working on not only updates to most of the apps, but also a very nice SimTools manual! (with detailed pictures for everything)
    It's been a lot of work and we are excited to get these updates and the new manual out!
    Here is a preview of what's to come with SimTools v2.3.
    - Jrk interface now supports G2 devices
    - New Revamped Memory Mapped Interface
    - New Advanced Axis Assignments plugin
    - New Anti-Rollover filter (Axis Assignments plugin)
    - New Linear vs. Rotational output options (Axis Assignments plugin)
    - Revamped output for both GameDash and GameVibe
    - Xml offset files now supported by the SimTools PluginUpdater
    - Game Manger Profiling completely reworked
    - Smoothing per DOF now carries double the weight
    - Main Profiling % Smoothing now carries double the weight
    - AMC1280USB Interface Plugin Update for new firmware v3.0 compatibility.
    - GameManger game patching text corrections made.
    - Tuning Centers Max/Min values now do not reset when the Min/Max option “Off” (red) is selected for an input.
    - (a) & (b) Axis Outputs drop down options, in Game Engine’s ‘Output Testing’, now uses your Axis Limiting settings.
    Anyway, we are almost there guy's. :thumbs
    Hang tight and we will start posting new stuff very soon.
  10. mysimnet17
    australia
    210Coins
    @yobuddy , New Linear vs. Rotational output options is that for a sim that can spin 360 degrees , like mine ?
  11. yobuddy
    51,753Coins
    Rotational output type can be selected in order to make a rotational setup have a linear output.
    Think of a lever connected to a motor that can spin 360deg. (with us using 180deg of it for the axis). When we use this to lift a simulator, the first time it moves 25% it lifts the sim further than it would if we moved it 25% more, and so on.
    Take a look at my horrible drawing below, you can see that every time is moves the same amount, it actually lifts the sim up less and less.
    So this option is here to make the amount it actually lifts the sim correctly when using a rotational lever system. And achieve a much improved ride from your simulator.
    In-fact it makes a rotational powered sim go from twitchy to buttery smooth quite nicely.
    Take care,
  12. Sandra
    Sandra New Member
    - 60Coins
    hi you have the plugin no blue contrôle ?
    and logiciel VRC ? think you
  13. yobuddy
    51,753Coins
    I don't understand buddy?
    But if you have installed the Video Ride Player plugin be sure to patch/activate it.
    Take care,
  14. Sandra
    Sandra New Member
    - 60Coins
    Hi Video friend Rider works fine I have the signal for the simulator, but I have no signal with video creator is this normal? how to enter information with a jostick thank you
  15. yobuddy
    51,753Coins
    Yes, you just making a video here.
    The only way to ride it with simtools is thru the Video Ride Player.
    VRC Input (and source code) will be release in the next few hours.
    With it you can draw your telemetry to the video while playing it slowly.
    But more so, anyone can make any input device they want for editing data.
    I hope to see lots of creative telemetry input devices.
  16. Sandra
    Sandra New Member
    - 60Coins
    OK thank you very much for your explanations! Is there a link to find videos with telemetry programmed to see the work and have examples for my future project thank you I will do it right here
  17. bulutlu
    bulutlu New Member
    10Coins
    3DOF, AC motor
    Here is the sample telemetry information for my 3DOF system with 6 relays.
    I have captured this information with 50 ms intervals from existing rides on the system. So that there are 20 lines for each second. And I m able to replay these instructions over UDP broadcasting.
    I need to create new telemetry files from scratch for new movies in the same format.
    Would this Video Ride Creator app solve my problem? if so, then what would be the best input method while creating the telemetry file.
    21.0468,0,124,246,0,221,92,0,85,176,0,0
    21.0972,0,174,242,1,11,198,0,139,62,0,0
    21.1479,0,217,202,1,54,158,0,189,58,0,0
    21.1987,0,253,126,1,101,8,0,232,18,0,0
    21.2493,1,29,160,1,143,224,1,22,124,0,0
    21.2997,1,51,12,1,183,38,1,65,84,0,0
    21.3505,1,83,46,1,225,254,1,111,190,0,0
    21.4010,1,97,118,1,254,142,1,147,114,0,0
    21.4517,1,118,226,2,44,248,1,172,112,0,0
    21.5023,1,126,6,2,59,64,1,183,38,0,0
    21.5529,1,126,6,2,59,64,1,186,184,0,0
    21.6081,1,186,184,1,247,106,1,201,0,0,0
    21.6586,1,126,6,2,59,64,1,183,38,0,0
    21.7092,1,126,6,2,59,64,1,179,148,0,0
    21.7596,1,126,6,2,59,64,1,183,38,0,0
    21.8104,1,126,6,2,59,64,1,183,38,0,0
    21.8610,1,126,6,2,59,64,1,183,38,0,0
    21.9116,1,126,6,2,62,210,1,179,148,0,0
    21.9622,1,122,116,2,59,64,1,183,38,0,0
  18. bulutlu
    bulutlu New Member
    10Coins
    3DOF, AC motor
    by the way, frankly saying I could not get the point of the plugin/patch? do I need to use it to patch the video or the video player?
  19. yobuddy
    51,753Coins
    I can't figure out why you have 12 data points for each line?
    What we need is the 6, roll, pitch, heave, yaw, sway and surge.
    Do you mean from a game or something?
    Chat soon,
  20. yobuddy
    51,753Coins
