SimTools v2 - Video Ride Creator v2.1
Create video ride films for the Video Ride Player
  1. bulutlu
    bulutlu New Member
    10Coins
    3DOF, AC motor
  2. yobuddy
    51,747Coins
    We want to capture/create telemetry for whatever we want to make telemetry for.
    This means we will have 6 inputs including: Roll, Pitch, Heave, Yaw, Sway, Surge.
    From this data the outputs you captured going to the motors will be recreated.
    You have just captured the wrong data is all I believe.
    Did you capture this from a game buddy?
  3. bulutlu
    bulutlu New Member
    10Coins
    3DOF, AC motor
    Actually, it's not wrong data since I am able to drive motors just fine by UDP broadcasting. Do you have a sample output of VRC Input then I could find out how to manipulate the regular output into my file.
    I captured it from a 3DOF motion base which came with several pre-loaded VR Videos. And now the captured telemetry file is doing the same file just like the original ride. Btw original system has telemetry files encrypted so that I captured motions from motor levels.
  4. yobuddy
    51,747Coins
    Yes, but this data is not what we are looking for.
    We would need to turn that data into roll, pitch, heave, yaw, sway, surge, somehow.
    Checkout Video Ride Recorder and make a short 3 minute video of you racing in some game.
    Then play the video created back with the video ride player and you can re-ride what you recorded.
    (it will also make a telemetry file for you to look at.)
    You can also open a video with the video ride creator and it will make a blank file.
    Then you can import data from a file for roll pitch heave etc..
    anyway, take care,
  5. Leandro Kemp
    Brasil
    - 10Coins
    It is possible to generate a telemetry in joystick plugin recorder and import in the video ride creator?
  6. yobuddy
    51,747Coins
  7. Mu-KwangKim
    South, Korea
    - 689Coins
    Can not I use the video player with another one?
    I want to adjust the brightness because it is very dark video.
  8. yobuddy
    51,747Coins
    I don't understand buddy.
    The video will play with any player I'm sure.
    But the telemetry file will only get used with the Video Ride Player.
  9. Mu-KwangKim
    South, Korea
    - 689Coins
    Sorry. I will ask again.
    Can not change the video player running on creator?
    The video player that runs automatically with creator does not have brightness control, so I want to use another player.
  10. yobuddy
    51,747Coins
    Hi Buddy, unfortunately you can't change the player that the creator uses.
    You would have to use a video editor to brighten the video before hand.
    Take care!
    154,711Coins
    +11,212 / 57 / -2
    If it is a compatibility issue then check required dependencies such as .NET 4 are properly installed and have not been corrupted: https://www.xsimulator.net/simtools-quickstart/#Requirements
  12. slipstream
    slipstream Airborne
    508Coins
    Could I use this to create turbulence and buffeting effects for a flight simulator?
  13. ali bakhtiyarzadeh
    ali bakhtiyarzadeh New Member
    - 49Coins
    Hi.i have a question, i make telemetry file for my video , i have a HTC VIVE and YawVr simulator , now i want use this telemetry file for my simulator , i open video for show with HTC ViVE with steam media player , now again for use in simulator i must again open video with Video Ride Player for run telemetry file with simtools , and my question , how can i run both together ? because when i first open Steam media player and again open Video rode player two program not play together more time one program run several millisecond fast or late and motion and video not correct together . i want when video opened with Steam Media player , telemetry file opened correctly or can i see video with HTC ViVe directly from Video Ride Player?
    sorry My English language is very bad .
    kind regards .
  14. yobuddy
    51,747Coins
    Hi @ali bakhtiyarzadeh,
    The short answer is we need a Video Ride Player that is compatible with VR 360 videos.
    We plan to do this with vlc 4.0.
    Once vlc 4.0 is officially out, the .net add-ons should get updated and give us a fighting chance of universal VR support.
    Take care,
  15. ali bakhtiyarzadeh
    - 49Coins
    So we can't do that right now ?
  16. KydDynoMyte
    RTP, NC
    40Coins
    Is it a 360°, 180°, or regular aspect ratio video?
  17. ali bakhtiyarzadeh
    - 49Coins
  18. noorbeast
    154,711Coins
    +11,212 / 57 / -2
    Correct.
  19. yobuddy
    51,747Coins
    Look at the offset in the upper right, this will allow you to sync the telemetry to the video file.
    Set it correctly and then save the file to keep the changes.
    Take care,
  20. Sam Neall
    Sam Neall Member
    84Coins
    This application is giving me an error. It worked before so maybe it needs an update to be compatible with a newer version of windows. Could you help me out?
    System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) ---> System.Runtime.InteropServices.COMException: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
    at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
    at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid)
    at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
    at System.Windows.Forms.AxHost.CreateInstance()
    at System.Windows.Forms.AxHost.GetOcxCreate()
    at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
    at System.Windows.Forms.AxHost.CreateHandle()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.AxHost.EndInit()
    at VideoRideCreator.frmPlayer.InitializeComponent()
    at VideoRideCreator.frmPlayer..ctor()
    --- End of inner exception stack trace ---
    at VideoRideCreator.My.MyProject.MyForms.Create__Instance__[T](T Instance)
    at VideoRideCreator.frmMain.pnl_Close_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    VideoRideCreator
    Assembly Version: 0.2.1.0
    Win32 Version: 0.2.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/VideoRideCreator/VideoRideCreator.exe
    ciqscyGSQjQUQejDxPhWCOSaRKI
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Windows.Forms.DataVisualization
    Win32 Version: 4.8.4200.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    AxInterop.WMPLib
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/VideoRideCreator/AxInterop.WMPLib.DLL
    Interop.WMPLib
    CodeBase: file:///C:/Program%20Files%20(x86)/VideoRideCreator/Interop.WMPLib.DLL
    System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    enabled.
    For example:
    <configuration>
    </configuration>
