SimTools v2 - Video Ride Player v2.2
Play video ride films reformatted or created by the Video Ride Creator.
  1. yobuddy
    51,753Coins
    It will be VLC, as I already have a working version built on it.
    But as I understand it thou, VLC still needs to support VR?
  2. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 324Coins
    2DOF, 6DOF
    VLC VR support plan seems existing and it will be with VLC 4.0 according to the latest post of VLC forms on May 07 2018.
  3. Shige Tanaka
    FREX
    Osaka Japan
    - 324Coins
    2DOF, 6DOF
    154,729Coins
    +11,213 / 57 / -2
  5. yobuddy
    51,753Coins
  6. LaserWars
    LaserWars New Member
    4DOF
    hello, I wish I could launch the movements of a simulator just for demonstration every x minutes. Is it possible to launch the player via a batch?
    During my tests it starts but the video is not loaded.
    If you even have a solution to just execute the movements recorded in the text file it interests me because the video is not useful to me.
  7. yobuddy
    51,753Coins
    Play the video with the Video Ride Player and minimize the video maybe?
    Take care,
  8. LaserWars
    4DOF
    Thanks for reply. Is à solution but there is no loop mode on player.
  9. yobuddy
    51,753Coins
    You can complete a race in Live for Speed, and then replay your race and it will loop over and over with motion, if that helps buddy.
    Take care,
  10. Pitchoun511
    Pitchoun511 Member Gold Contributor
    Perpignan
    387Coins
    Hi Guys, I really would like to play 360° videos with video ride player for the telemetry option. But actually, it seems that the player don't support this format.
    Do you think this option will be deployed?
    154,729Coins
    +11,213 / 57 / -2
    The option will eventuate, but it needs a sound basis for a compatible free player to build it on, and the sensible choice would be VLC, as it is open source and plays most file formats. But to be complete VLC needs VR support and thats not due until the 4.0 release: https://vrscout.com/news/vlc-media-player-vr-support/#
  12. Pitchoun511
    Perpignan
    387Coins
    Hi everybody, I'm always in search of a better experience for immersive 360 video. Today, I'd like to know if it's possible to drive a wind simulator with video ride player.
    If you find how to do to read 360° video with video ride player, I'm always waiting about a solution...
    Thank you!
  13. Errol
    Errol New Member
    - 61Coins
    3DOF, 6DOF
    VLC has VR support now but the video has to have it's metadata set to indicate it's a VR video.
  14. noorbeast
    154,729Coins
    +11,213 / 57 / -2
    That will give @yobuddy something to play with, as a foundation.
  15. Pitchoun511
    Perpignan
    387Coins
    Hi everybody,
    I work hard to make an experience player. since a few month, I'd like to play the simulation and a 360 video at the same time. I made my program with unity and Claudio silva's unity plugin. I'm nearly getting to have it functionnal.
    But when I try an expérience who worked fine on video ride player, it's more slow in my program that it's in video ride player. For exemple, one of my experience is a ride who run in 23 FPS. With Unity, I send one frame every 0.043s - 0.044s (23FPS) and it's more slow than in video ride player.
    Can you explain me if I made a mistake?
    Thank you.
  16. Franck TALBART
    Franck TALBART Franckarts
    - 309Coins
    Hey Team,
    I would like to launch the player from bash using a video filename as a parameter:
    Code:
     .\VideoRidePlayer.exe .\main.mp4
    The player is launched but it does not open the video. I would need that feature to embed the player in an Oculus project.
    Could you add this quick feature please?
    Thanks a lot for your advices.
  17. yobuddy
    51,753Coins
    Well, I tried making a lua script for VLC that simply collects the timestamp and sends it over UDP to simtools.
    Seems simple enough, and it would make VLC a native VR-360 video ride player.
    Got it all done, tested, and then loaded it in VLC only to learn VLC can't use outside library.
    So in short, We can't use UDP from VLC extensions. arg... lol
    Well unless VLC is compiled with the proper flags to allow an outside library to be loaded.
    But if we have to go thru that every time, it sort of make the extension scrips sort of pointless.
    As we could simply memory hook the needed timestamp I believe.
    Still a few things to try, But this one seemed too simple and strait forward.
    Take care,
  18. Gilberto Marques
    Gilberto Marques New Member
    - 547Coins
    Has anyone in 2024 almost 2025 been able to use the Video Ride Player on a VR headset or Rift?
  19. yobuddy
    51,753Coins
    The video ride player does not support VR unfortunately.
  20. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    anyone can show me some video rides with telemtry for tests?
    roler coasters or something.. i dont have nothing... tks
