SimTools v3 Assetto Corsa Rally Plugin
Discussion in 'SimTools Plugins' started by yobuddy, Nov 19, 2025.
  1. Titobial
    Titobial Member
    Zaragoza
    107Coins
    2DOF, AC motor, Arduino, Motion platform
    Well, I already have version 3 with the assetto corsa rally plugin working fully! And it's going fine, fine! Thank you all very much for your part, for making all this possible. The truth is that this new version is more intuitive, more optimized and therefore, you can see much more precision and response... a marvel! Thank you very much!
  2. =EZE=
    =EZE= New Member
    - 68Coins
    I confirm what Nailson Roveta wrote in the Tuning section.
    I also had no response in the movements, except with the Roll.
    Now I tried to set the settings I had in Assetto Corsa and it works very well.
    My values vary between 2 and -2. I use Heave, Roll, Pitch, Surge.
  3. Titobial
    Titobial Member
    Zaragoza
    107Coins
    The truth is that the plugin doesn't give me the correct forces and effects either... Where mark picht is roll or sway or arise... In the end I tinkered and adjusted it as I went. It's a little frustrating and tedious, but I went effect by effect and in the end I'm adjusting and fine-tuning it... I guess I won't be the only one with this problem. Luck!
