Bug Simtools v3 issues
Discussion in 'SimTools DIY Version' started by FLORIN ROMANIA, Dec 17, 2023.
  1. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    810Coins
    I also tried with CMD hasn't changed anything
  2. FLORIN ROMANIA
    România
    810Coins
    Y did everything y could, I'm willing, if you want to do by Team Viewer
  3. FLORIN ROMANIA
    România
    810Coins
    Maybe you can figure out what's wrong
  4. yobuddy
    51,664Coins
    Did the repair tool find anything, fix anything, maybe ask you to reboot the PC?
    I can't tell you what has stopped it from working, so its really hard to say at this point.
    All my PC's are still registering just fine, so it makes me think simtools is getting blocked by something on your PC? I would try installing AVG free antivirus and then restarting the pc, and then trying to register again.
  5. FLORIN ROMANIA
    România
    810Coins
    Repair tool found something and repaired after which I reboot the pc but no change. I will install AVG as well, then I will try to reinstall simtools. If that still doesn't work, can you help me through Team Veiw?
  6. FLORIN ROMANIA
    România
    810Coins
    Greeting. I ran AVG, repaired. Net framework, I also tried with Command prompt app. .,In vain. , nothing works. Please help me, I repeat, I am willing to help me via Teamviewer
  7. yobuddy
    51,664Coins
    Have you checked to see if the Windows Management Instrument (WMI) service has started?
    It's the only other thing I can think of at this point.
    I'm fairly certain this is a system pacific problem, as I have not been able to replicate it on any of my test machines, and have never seen it before. but my Windows Management Instrument has started, so please check it.
  8. CASHFUNNEL
    CASHFUNNEL New Member
    30Coins
    I wish there was some closure on this issue as I have the exact same problem.
  9. yobuddy
    51,664Coins
  10. CASHFUNNEL
    30Coins
    Any chance that running a 32 bit application on my 64 bit system is the problem?
  11. yobuddy
    51,664Coins
    That's what everyone is doing thou. There is actually a ton of apps that run in 32 bit mode, so I don't see that as the problem.
    Do you have another pc to install v3 on for a test?
    Chat soon,
  12. CASHFUNNEL
    30Coins
    It’s weird because it’s the only app that doesn’t work.
  13. CASHFUNNEL
    30Coins
    No it’s the only computer I have
  14. CASHFUNNEL
    30Coins
  15. yobuddy
    51,664Coins
  16. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Hello, i start testing the simtool v3 and works but dropping my fps a lot, anyone with this problem? With v2 dont happens
