SimTools v3 Public Beta
  1. Slawko
    Slawko New Member
    NI
    34Coins
    Yea Snail dont care just....
  2. Slawko
    Slawko New Member
    NI
    34Coins
    Just tried WT not getting any telemetry in SMT3 at all again :(
  3. cstdarknight
    cstdarknight Member
    265Coins
    FYI - I tried using extra2 (pitch) and extra3 (roll) out but didn't get any movement.
    • Does this thread help with anything for the ST3?
    • Still not sure what plane I should be using for testing. (Wyvern, from Slawko is paid content so I don't have access to it).
    154,837Coins
    +11,227 / 57 / -2
    SimTools v2 plugins are not compatible with v3.
  5. yobuddy
    51,773Coins
    Hi Guy's,
    The new War Thunder plugin has been posted. (with the same output order as the v2 plugin) :thumbs
    With the limited roster of vehicles we have, we were using the P-26A-34 M2. We could not get the usual roll and pitch to work, but we have a pretty limited number of vehicles to test with.
  6. cstdarknight
    cstdarknight Member
    265Coins
    Thank You for the hard work. I'll use that plane for testing, update the plugin and post what I find on my rig.
    Question: When you say you could not get the usual roll and pitch to work. What do you use on your sim to get it going? Roll2, pitch2?
  7. yobuddy
    51,773Coins
    I mean that the roll and pitch output seemed missing from the limited planes that I used. But this is a one-2-one of the v2 plugin, so if pitch and roll output is working in v2, then it should also work in v3.
    The only valid replacements for pitch and rill are listed as extra 1 thru 3 (just like the v2 plugin). Thou as you have seen, they are not perfect replacements. Surge however, I believe is working a ton better.
    Anyway, I have a feeling they may have removed the traditional roll and pitch output we used to have assess to in their last big update. Time will tell thou, As i know I have not scratched the surface of the vehicles available.
    Take care,
  8. Christian Anastasi
    Christian Anastasi New Member
    28Coins
    Hi Guys I still didn't manage to make F1 2024 work on sim tools V3... I copied the same settings that I had in F1 2023 and still didn't manage to make it work. If I start the game from Simtools I see the Data going into Sim Tools but the traction loss doesn't work properly it works a bit in the beginning than it stops. I linked Sim Tools to Simhub so I can use the the Traction loss and pugs at the same time.
    154,837Coins
    +11,227 / 57 / -2
    I don't have F1 2024, but just a check, when using 2 programs have you ensured there is a UDP pass on, rather than conflict, in how ports are configured?
  10. cstdarknight
    cstdarknight Member
    265Coins
    Thanks YoBuddy,
    Did some tests using the P-26A-34 M2 and premium plane XP-50. Good news is both had the same behavior.
    • Note: I removed my current plugin and installed the new one to get a "fresh" start for testing.
    • Roll and Pitch don't do anything on either.
    • Roll Degrees and Pitch elevator position don't do anything on either
    • It seems to work with Sway and Surge (the default settings) as they do respond but I think because it is sway it doesn't seem to simulate the "roll" feeling I.e. doing "scissors" is really weird. But it is better than no movement and I understand sway is not roll.
    • Surge also acts like "pitch" (but the directions are reverse from other game settings) which makes landing and takeoffs feel weird again better than no movement and I understand Surge is not pitch.
    • Note: I don't have ST2 to compare against so hopefully Slawko will be able to compare/confirm behavior between ST2 and ST3
  11. Slawko
    Slawko New Member
    NI
    34Coins
    Ive nothing in SMT3 sorry cant help... im getting nothing no telemetry at all
  12. Moe Colontonio
    New Jersey USA
    827Coins
    Any tips on getting MSFS 2024 working with ST3?
  13. yobuddy
    51,773Coins
    We have a mfs 2024 plugin ready for testing, but as most people know, the game was broken on release. Now that a patch has been issued for the game, we should be able to get to testing later today.
    Chat soon,
  14. yobuddy
    51,773Coins
    Plugin posted :thumbs
    • Winner Winner x 3
  15. upracerr
    upracerr New Member Gold Contributor
    Tuttlingen, Germany
    - 618Coins
    2DOF, 6DOF
    Hi, Thanks for your work.
    one question....is there an other plugin needed for the x-box platform(but forPC) buyed msfs? i had the issue, that i dont get any data from the x-box version. the steam version works fine. All both on St3
  16. yobuddy
    51,773Coins
    @upracerr,
    It could be the process name is different, could you tell me the process name of the x-box version?
  17. Hui Yu
    Hui Yu New Member
    40Coins
    Good day
    I encountered a problem when using simtools V3 professional version. After I opened the game with simtools v3, simtools did not detect the game. Do I need to make any settings after opening the game with simtools v3? The V2 version works perfectly for me, and I can observe the data in the tuning centering.
    Kind regards
  18. noorbeast
    154,837Coins
    +11,227 / 57 / -2
    The v3 Quick Start Guide is here: https://simtools.us/wp-content/uploads/2024/02/QuickStart-Guide-for-SimTools3.pdf
    And the User Manual: https://simtools.us/wp-content/uploads/2024/02/SimTools-v3.pdf
  19. Hui Yu
    Hui Yu New Member
    40Coins
    Good day
    Thank you very much, I have solved the problem, I didn't set the interface, I should have read the manual carefully.
    Kind regards
  20. Guyotine
    Guyotine New Member
    - 1Coins
    3DOF, SCN6
    Where can I downloaded the plugin for MS2024 for ST3? Thank's :)
