SimTools v3 Public Beta
  1. yobuddy
    51,767Coins
    Please try removing the plugin from SimTools v3. Restart SimTools and reinstall the plugin.
    The patching routine was updated on the 16th of last month and tested to be working.
    So please give it a try buddy :thumbs
  2. VFX Pro
    VFX Pro Member
    Los Angeles
    461Coins
    Motion platform, 6DOF
    @yobuddy Perhaps, this is already requested, when do you expect to have telemetry support for AC Rally and PMR?
  3. sam poole
    sam poole Active Member
    midlands
    38Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    ive just remembered someone made me a plugin a while ago for a phone app that streams telemetry data from a phones imu to pc
    its called sensor stream https://play.google.com/store/apps/details?id=de.lorenz_fenster.sensorstreamgps
    just seems a quick solution for now until you get round to doing it cheers
  4. yobuddy
    51,767Coins
    Plugin now available on the repo...
    (Thanks @value1 for you work on this plugin!)
  5. yobuddy
    51,767Coins
    @VFX Pro,
    I have not seen any information for telemetry on Project Motor Racing yet.
    If you have found such info, please send it my way buddy.
    Chat soon!
  6. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Hi Yobuddy,
    Any update on newest 'RCRider' plugin with esp32 board?
  7. lysa elec
    lysa elec LYSA ELEC
    16Coins
    I use the games on Steam but where must be placed the plugins each game
    for the moment under each game under steam/.../common/ games it doesn’t work
  8. sam poole
    midlands
    38Coins
    Close game engine and game manager then use the simtools plugin updater and just drag and drop
  9. lysa elec
    lysa elec LYSA ELEC
    16Coins
    Where is the update for the SimTool v3 plugins?
  10. yobuddy
    51,767Coins
    Simply install then thru the plugin manager directly in SimTools v3. There is no need to place them anywhere by hand.
    They get added to the repo directly in SimTools v3.
  11. lysa elec
    lysa elec LYSA ELEC
    16Coins
    The simulator starts from the SimTool v3 interface, but not from the Steam game directory.
  12. Racer54098
    Racer54098 New Member
    117Coins
    Is it possible to make profile switching automatic for Raceroom Racing Experience? (I couldn't find if this has been asked and answered).
    I would be a very valuable to feature.
  13. rocketfire302
    rocketfire302 Member
    134Coins
    SCN5, SimAxe
    ok so i have tried this a number of way but cannot get x-planes 12 to work under simtools plugin.
    first, the 6DOF works in simtools just fine and you can run the sliders and get the chair to move correctly.
    this indicates that the simtools is setup right.
    now when you run the plugin, and x-planes the chair jumps and vibrates terribly. i have all the right settings in x-planes that the plugin lists. i have the right UDP and port. However i think the plugin has issues.
    now, to test i have setup the same profile in DCS and walla the chair/virtual output work just fine and behaves like it should. moving back to X-planes just random vibrations and in Virtual output the output mimics the chair. i have tried to set the smoothing, the delay, etc. Nope still no good.
    I even changed the min/max settings and nope, still not go.
    given this does not seem to work, i can only guess its a buggy plugin for 3d rotation.
    my next test is to download x-planes 11 and see if it works.
    has anyone else experienced this?
  14. Fernando Sanchez
    Fernando Sanchez New Member
    22Coins
    2DOF, Motion platform
    About a year and a half ago, I had problems with iRacing after an update. It was fixed with a new plugin that was sent to me by email (the one that wasn't in the repo). Now I'm having the same problem again; it's not working. I've tried reinstalling the new plugins that are in the repo and even the one that was sent to me by email, but it still doesn't work (the other simulators work without problems). Has this happened to anyone else?
  15. noorbeast
    154,783Coins
    +11,217 / 57 / -2
    Has there been any iRacing updates, as historically those have been known to create breaking issues?
  16. Fernando Sanchez
    22Coins
    Yes, one just last week. It was working before the update, so I guess that's why.
  17. Joe Cortexian
    Joe Cortexian Active Member Gold Contributor
    1,688Coins
    TLDR: If SimTools3 gets blocked by "smart App Control" you might have to reinstall the Serial interface plugin.
    Recently I updated to Windows 11 so much fun. A new feature is "Smart App Comtrol". Normally this is turned off but sometimes just out of spite Windows turns it on. When you start SimTools3 Windows says "Smart app control is disabling some features" in about 2o prompt boxes. Ok turn it off restart etc etc. Don't get the warning anymore but it doesn't work AT ALL for any games.
    So when no games were working I looked at the interfaces. The serial interfaces were all gone. I have two and one network interface. Bizzarly it was fine with the UDP over the network one but the serial ones were completely blank. Not disabled just gone. It doesn't complain about SMCUtils or a serial terminal program I wrote but it seems very angry with SimTools3.
    As a workaround I would at least like to save that interface data away. I did a search here and didn't find any references wo Smart app so I assume no one else is seeing it or its a new feature of some recent update.
    Can you just set it up to allow that app like a firewall:
    Short answer: No, Windows Smart App Control does not let you manually whitelist or override blocked apps. If it blocks something, the only way to run it is if the app has a valid digital signature or if you disable Smart App Control entirely.
    EDIT: In the end the Serial plugin was gone. I uninstalled and reinstalled SimTools3 but don't know if that was necessary. I reinstalled the serial plugins and when I set the interface type to serial the data came back that I had originally set up.
  18. lysa elec
    lysa elec LYSA ELEC
    16Coins
    In the options menu, every time I check "open automatically with game launchers," the box is unchecked every time I restart my computer.
    What's happening?
  19. Gamesterz
    Gamesterz New Member
    gamer
    CT
    17Coins
    Hello all
    1st time trying to setup the 3DOF and simtool.
    1. theres an error updating the Default GUI? not sure why or what that is.
    2. In plugin manager I tried to select the d-mover for interface plugins, and then selected something else for the D mover and now all tabs show it on Simtools:pC and when I click on the Repo, all are blank, cant see the games etc. So right now I can't test anything and I can't seem to get this back to default?
  20. youth.newmarkt
    youth.newmarkt New Member
    16Coins
    Hi guys,
    on Windows 11 we have the same Error "Error updating Default GUI"
    - no Plugins, no Repos, all empty
    - can´t do anything, Output Test still works
    - when try to re-install, there ist "unable to extract simtools" even if open as admin
    Is Windows 11 or the newest updates the Problem ?
    Should i install Windows 10 ?
    thank you for any help
