SimTools v3 Public Beta
  1. pikky
    pikky Member Gold Contributor
    24Coins
    No need to run as Administrator.
  2. pethconi73
    pethconi73 ProSimu T1000 3M
    real estate
    hillegom, holland
    - 95Coins
    Hi pikky, I always run Simtools as Armin…. But still nothing…..
    154,849Coins
    +11,229 / 57 / -2
    What "simtools clip" do you mean, can you supply a link to that clip?
  4. pethconi73
    real estate
    hillegom, holland
    - 95Coins
  5. agustin121212
    agustin121212 Agustín de argentina
    Mecánico
    Argentina
    149Coins
    Hi, the new interface is great! Is there a complete tutorial for axis configuration?
    154,849Coins
    +11,229 / 57 / -2
    To be clear, you can only install v3 plugins not v2 plugins.
    So what is the plugin and where did you get it from?
  7. pethconi73
    real estate
    hillegom, holland
    - 95Coins
    I know, the newer Assetto EVO plugin, is only available for V3, it’s been shared couple off messages up….
  8. Racer54098
    Racer54098 New Member
    117Coins
    Motion platform, 4DOF
    I've been using SimTools for almost five years now. Beta v3 has been in use since its release in the fall of 2022. In the beginning, I was happy with the beta.
    But my problem drives me crazy. This will be last attempt to solve this matter, I'm so frustrated with this. The text is a bit long, but I kindly ask you to read and help if you can.
    My configuration:
    • Windows 11
    • SteamVR + Vive tracker
    • Fanatec DD1 + Fanatec App
    • Simucube Active Pedals (only 1 y old) + Simucube Tuner
    • SimHub
    • QubicManager
    • Crewchief
    • Games: AMS2, RRRE, LMU, RBR rally
    My sim has industrial‑grade linear actuators powered by high‑torque servo motors (commercial sim platform, I don't want to reveal the name of the brand here.)
    I've driven over 1000 hours (only VR), mostly without problems. For the last two years now, I have been suffering from a problem that is difficult to solve, which occurs often, but not always.
    Problem: The motion simulator device seems to get some motion value signal peaks or something like that. When I'm driving on an almost flat track, and I'm just turning the car slightly, there's a signal spike on the axle on the other side, and it clicks the motor. The clicking sound is so annoying that it interferes with driving. The same when turning in the other direction, but not always the same way. This happens even though I drive slowly, straight and turn calmly. It's as if something interprets that a small turn requires a big signal for a moment(?). Even when driving a lot faster a long, flat corner, no potholes (in a gravel rally), then there may be a big axel motor click in the middle of the bend, but there has been no jump in the car's movement.
    Sometimes I can play for many hours without any problems. It can happen that the driving works perfectly, the simulator chassis moves silently and sensitively. Then another day you can't even drive on a flat road when the axle motors get a signal that it should jerk a little. Sometimes for example Raceroom or AMS2 doesn't work, I switch to RBR rallying, and with that it works ok. On the day of writing, the rally could not be driven because the clicking can be heard, even when the platform was barely moving.
    All this with the same SimTools profiles and the same cars/tracks.
    I have been able to get different cars to work in a really elegant way on my simulator platform by tuning min/max values. On a bad day min/max values need to be raised to minimize the clicking. However, I stopped adjusting it, because it doesn't make any sense that one day the min/max values are great and the other day the axles rattle with the same values. I just stop racing and try another day.
    There is always a chance that my simulator platform isn’t working properly. There is just no indication of it. There are no errors in the logs, no disconnects. At its best, the device works wonderfully. And I don't understand how the device works sometimes well, sometimes badly. You would think that the poor operation would increase over time, and soon the device would not work at all. It just hasn't happened.
    Tried so far:
    • Adjusts min/max profiles to make them better. When there is so much room in the mix/max profiles that the device almost stops moving, that doesn't help either. Then the device moves weakly, but there are clicks, e.g. even at slow speeds.
    • Make sway min/max higher
    • I have stabilized my sim weight is evenly distributed. My seat and peripherals are positioned so, that my seat stays level, when I shutdown.
    • I've been looking at Virtual Output, but I can't find out that anything strange is happening.
    • I've exit and reopened SimTools, and reconnected to the game.
    • I've tried to start only the simulator game (steering wheel and pedals) and connect to it with SimTools. In other words, all other utility software is turned off. I've suspected that telemetry-related utilities would be harmful, but apparently that's not the case either.
    • I have replaced the USB cable.
    • I've tried to examine USB signals with USB utilities.
    • Could some other device be the cause of the malfunction? It doesn't seem like it.
    • If I reduce USB devices? It doesn't help.
    • If I put the motion sim in a different port? It doesn't help.
    • I've been driving without an antivirus sw.
    • Once I decided to boot the computer as soon as I heard the first click. It helped that time, I could drive hours after it with out noises. I thought it could always help. But no.
    • Roll rate and Pitch rate are one thing that I have tested a lot. I'm still not quite sure how to set them up. For example, when I take Capture, I get values of +85/-85. I have then tried setting them to a low value, e.g. 1 or 2. It doesn't help. I thought, that when I set them to zero, the problem was solved. But no...
    Q: If you set the roll rate and pitch rate +0/-0, are they completely off? Anyways, if it's off, it doesn't help either.
    SimTools is the cause of the problem?
    Is it possible that SimTools is the cause of the problem? Could it be possible that plugins don't always connect well to the game? There is a conflict with the game, and it does not receive a steady signal? (I ask a maybe stupid questions, please bare with me)
    Could USB traffic be to blame? If so, what would be the best way to explore it further? However, why would the problem of USB traffic always show up in the same way? That is, when the car turns a little, a click is heard. Or when you brake a little, you may hear a click. You would think that there would be a clicking sound when the car is stationary, or it just goes straigh, or in every other situation. And why not always?
    I hope you will ask me something that I didn't remember to tell, or what I haven't noticed to test.
    PS: How could I test on another computer that I can use all the plugins? The license is tied to the main device's SimTools. I think I tested it once with a laptop and LFS, but it didn't resolve my issue. It didn’t work any differently.
    Thank you for your help in advance!
    Here are examples of my min/max values and axis setup:
  9. pethconi73
    real estate
    hillegom, holland
    - 95Coins
    this is for verion V3 correct? since i cant get it implemented in simtools3....
    154,849Coins
    +11,229 / 57 / -2
    There could be lots of reasons, but could this be intermittent EMI electrical interference, it is common with this type of actuator.
  11. pethconi73
    real estate
    hillegom, holland
    - 95Coins
    Hi, but the rest works fine, but then i can choose form the banners in the plugin manager. Like ACC, or Wreckfest 2, Lemans Ultimate and those all are working in simtools
  12. Racer54098
    117Coins
    Thank you for you comment. I would kindly ask for a little more help.
    Could you explain a bit more what you mean by "this type of actuator"? I have a three motor (no screw, long stroke), three axel system . The whole system is powered with one power cable.
    Do you think EMI interference could be coming from power outlet? I think I already tried using a USB cable with a ferrite ring.
    If EMI interference caused this, wouldn't it be more random? I mean when this issue happens, first, there is no movement, because I'm driving on flat surface, but then for some reason one of the axis makes a sudden movement and I don't know why. As if a slight unevenness in the surface causes excessive movement. But then every turn also. And maybe next day this might not happen at all. So weird.
    Can you help with these:
    • Can you explain how roll rate and pitch rate work? I haven't found any info how they are supposed to work. Is +0/-0 if totally off?
    • And small values = small effect? And what does it do? AI explained large roll rate effect like this: "Strong, sharp, aggressive impulses every time roll changes". Correct?
    • How can I analyse if the excessive movement originates from SimTools or not?
    • How can I use Virtual Output to analyse this more? I can't tell if blue dots swinging back and fort are moving normally or too fast. If I see the roll signal reacting too fast, what can I do? Sometimes the dots are swinging quite fast, but it doesn't make sudden movements.
  13. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    Servos for the actuators and the Simucube are all possible sources of interference, depending on the cables being shielded or not, and how the cables are run.
    As I said there could be lots of reasons, but I suggested that one because of the described intermittent nature of the problem.
    There can be many other possibilities, from the plugins to some games, for example CodeMaster games are known to finicky so RBR is not a great testing choice. Plugins for games can also be a culprit. Random outputs can also result from different hardware/software running on a computer.
  14. lxyl
    lxyl New Member
    46Coins
    Please fix this @yobuddy! It's kind of annoying!
    Or maybe is 2026-03-29 v5 iracing plugin still working?
    Could someone please share your old v5 iracing plugin in C:\Users\*username*\AppData\Local\SimTools3\GamePlugins\27_GamePlugin.dll with me?
    Thanks a lot!
  15. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    643Coins
    2DOF, 3DOF
    Hello everyone,
    Do you plan to create a plugin for this game?
    Thank you.
  16. pikky
    24Coins
    Hi everyone, I am using SimTools v3 with a DIY motion rig (Arduino + AASD-15A). My other games work perfectly, but iRacing (Web/Direct version) has an intermittent motion issue. The motion works when I go on track, but it frequently stops working/freezes mid-race, then sometimes comes back or drops entirely. Game Launch Method: I leave SimTools v3 on standby (main screen) and launch the game manually via iRacingUI.exe (to avoid the "Use iRacingUI.exe to launch" error). Other games never drop, so EMI / hardware disconnection is ruled out. ⁠irSdkEnableMemMapSharing=1⁠ is enabled in ⁠app.ini⁠. Not running SimHub to avoid telemetry conflicts. Why is the iRacing telemetry stream unstable or dropping out randomly on SimTools v3? Any advice on how to fix this? Thank you!​
  17. MAH1241
    MAH1241 New Member
    25Coins
    3DOF, DC motor, SimAxe, Arduino, Motion platform, 4DOF
    Can you run Motion and Wind on the same com port with 1 Arduino ??
    I was hoping that the Dashboard Engine and the Motion Engine would combine the strings and pass them in one packet on one com port to the Arduino Uno, but that appears to not be the case
    I have my Arduino on Com5 which controls my 2 front motors and also controls my wind.
    Motion works great with [A<Axis1a>][B<Axis1b>] outputting on Com5 with 10mS update
    I have configured the speed Sp1 dashboard to output 3 digits to represent speed, which works well.
    MAP 0 150 0 999 (this translates 0-150km/h to 0-999 which my sketch uses)
    ROUND 0 (this makes it an integer)
    PAD 3 0 (this pads it to a 3 digit number filled with 000 for example 008)
    In the dashboard output interface on Com5 I have S<Sp1> with 10mS update, which translates to S008, or S230, or S812 etc..
    If I disable the motion the fans track the speed really well, but when you have motion and wind enabled, wind does not work. I assume this is because it is expecting a dedicated Com port.
    So then I disabled dashboard output and went back to motion thinking I could use <Sp1> token in the motion string like [A<Axis1a>][B<Axis1b>]S<Sp1> but it looks like that token does not pass to the motion engine. I then tried [A<Axis1a>][B<Axis1b>]S500 as a test and that works so the serial output is working with mixed motion and wind.
    So the question is has anyone successful been able to have motion and wind on 1 com port ?
  18. MAH1241
    MAH1241 New Member
    25Coins
    Here is an update, i installed VSPE - and set up 2 virtual com ports Com20 and Com21 - with motion on 20 and wind on 21, then combined the streams and outputed the results to the physical port Com5. While this works the virtualization is way too slow and not really usable.
    Any ideas from anyone?
  19. The-Soulless
    The-Soulless New Member
    47Coins
    Hello everyone,
    I am in desperate need of some help with the beamng plugin voor simtools V3. I am getting good motion input in other games except for beamng. All the values are irregular and jittery, and my sim just goes crazy and doesn't respond to any movement from the vehicle. Is beamng not supported anymore with newer updates? My game version is V38.6.
    Hope there is some solution out there cause I'm going crazy.
    Thanks!
