SimTools v3 Public Beta
  1. Pims578
    Pims578 New Member Gold Contributor
    45Coins
    3DOF, SCN6, Motion platform
    ok thanks i will look
  2. Pims578
    45Coins
    indeed the problem comes from the min max values but I do not know at all how to adjust the values
  3. yobuddy
    51,780Coins
    The smc3 sketch has some shutdown triggers built in, maybe they are getting tripped?
    Maybe turn on axis limiting, and set it for 90% on each axis, then see if you still have problems.
    Have you tuned the max/min file for your sim?
    The plugin is sending the same data that is in v2 is all.
    Chat soon,
  4. yobuddy
    51,780Coins
    Here are the steps for v2.
    V3 works the same way, so I hope this helps.
    https://www.xsimulator.net/tuning-centre/
    Let me know how it goes buddy.
  5. VFX Pro
    VFX Pro Member
    Los Angeles
    472Coins
    Motion platform, 6DOF
    Where did you get the plugin for prosimu? I can't configure my axis for my P7MP. Under Axis plugins I don't see prosimu.
  6. VFX Pro
    VFX Pro Member
    Los Angeles
    472Coins
    Are the numerical values for axis/min-max/etc... are 100% identical between 2.x and 3.x so I can easily migrate my current settings?
  7. Graham Botha
    Graham Botha New Member
    Database Administrator
    South Africa
    24Coins
    3DOF, SCN6
    Hi all,
    Are there any plugins for AMS2 and Project Cars 2 on the way for SimTools 3?
    Thanks in advance :)
  8. yobuddy
    51,780Coins
    Project Cars 2 is next on the list.
  9. Graham Botha
    South Africa
    24Coins
    3DOF, SCN6
    Thank you so much :)
    Really looking forward to migrating to SimTools3 for all my sims.
  10. yobuddy
    51,780Coins
    3 new game plugins posted to the repo! ;)
    Let me know if you have any troubles.
    Take care!
  11. yobuddy
    51,780Coins
    More games plugins loaded... :thumbs
  12. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    738Coins
    Thanks for all the support and updates. Is the beta stable enough to start using for a new user? Or should I hold off for now.
  13. yobuddy
    51,780Coins
    Sure, let me know if you have any problems buddy!
    We are getting a lot more game plugins added to the repo, so there should be lot's to play.
    Take care!
  14. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Ok I have come to a solution. I finished the belt tensioner and it works on 2 profiles. The problem occurs when one device is not connected. Then sim tools v3 shuts down. In addition, you can't set max min for b axis separately. There is an option of only ascending or only descending, but in my case it caused the retractor to start rotating all the time AND I had to turn off the emergency. Maybe someone can explain to him how it works. In addition, when you give the axis test the seat jumps abruptly, there is no soft start. I also noticed that uploading the plugin from scratch. It deletes all previous max and min for the game. In my case, I have to re-upload the plugin every time before turning on the rbr, then the quality of movement is sort of fuller. This happens in both versions of simtools, I can live with it. That's it for this time. My problem with the belt tensioner was due to a faulty usb slot of the internal card which I bought to avoid messing with external hubs. So the issue is a curiosity
  15. yobuddy
    51,780Coins
    You telling a device to startup that's not there?
    Where buddy, I believe you can.
    Don't understand buddy.
    Soft start may be added here, but working on plugins for the moment.
    Only if you delete the plugin from SimTools, and then install the new one.
    If you update the one in place (without removing it) it will not remove max min files.
    Also there are max/min update options on the options page.
    Chat soon,
  16. yobuddy
    51,780Coins
    Yes, in the advanced axis plugin.
  17. Krzysztof Dej
    Poland
    1,100Coins
    Connected to electricity if not sim tools crashes for me. Yes I must delete and install to have rbr working super. In sim tools 2 I just u patch and patch again. I don't see where I can set a axis and b axis min? Can u show? When I set for a axis b axis was the same. Best regards
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @yobuddy just tested AMS2 the forces seem messed up
    simtools surge is in game sway
    simtools sway is in game heave
    simtools heave is in game surge
    pitch and roll are correct
    or at least thats how it seems to me, might be worth a look :thumbs
    thanks for the plugins update, great timing for Christmas Hols:cheers
  19. richdelta9
    8,820Coins
    I just pushed an update for AMS2. Let me know if it's working for you. Thanks for the feedback!
  20. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @richdelta9 thank you all working as it should now:cheers
