SimTools v3 Public Beta
  1. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, still not activated all updates are made if anyone can help thank you.
  2. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    Hallo Bruno, did you contact Rich or Youbuddy?
  3. yobuddy
    51,734Coins
    Hi Guys,
    Yes, this was needed, sorry for any problems it caused.
    Please go to the registration page and click activate buddy.
    Same, please go to the registration page and click activate buddy.
    See here:
    https://www.xsimulator.net/community/threads/simtools-v3-public-beta.17329/page-3#post-231894
    Thanks guys,
  4. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I have connected rich but still no license to activate it asks me for $29 while my v2 license is valid.
  5. richdelta9
    8,840Coins
    I gave you three options and yes one was to upgrade from DIY to Pro for $29.99. One of the options was also to wait for an update to fix the registration issue, which is available at https://simtools.us/downloads-links/. Please try to register again. It should work on previously activated v2 machines.
  6. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    I ask you a question that has nothing to do with the topic you are talking about... the rfactor 2 plug-in or some other of those that are not published on the simtools v3 page, you have to wait for them to be added or you can use it those of version v2.
  7. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, thank you for the activation I installed the plugins for f1 22 but when I launch the game via simtools c f1 2021 who launches ?
  8. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    The same thing happens to me, something has the plugins... you have to play the plugins and then open the f122 game.
  9. bruno1210
    bruno1210 schumi06
    103Coins
    I launch f1 22 with simtools but f1 2021 launches instead !
  10. yobuddy
    51,734Coins
    Pushed an update to the f122 plugin that should fix it.
    Make sure to update the plugin if your options are on manual game plugin updates.
    (little down arrow in the top left of the f122 game banner)
  11. yobuddy
    51,734Coins
    Update Pushed...
    The 'E-Stop button' now doubles as a 'Start button' that allows us to launch games :thumbs
    Added – you can now launch a game from any sub-menu page of any game plugin
    Changed - SimTools now starts and stops on the page you are on (making editing profiles a lot easier)
  12. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I updated f1 22 with the little arrow and the simtools update but still f1 2021 is starting.
  13. levers
    levers Active Member Gold Contributor
    1,032Coins
    Hi Yobuddy, a simple change UI wise but I've immediately found this useful for setting up min/max settings. Thanks:thumbs
  14. yobuddy
    51,734Coins
    Please remove the plugin from simtools (with the little trash can while hovering over the banner).
    Restart simtools and then reinstall the plugin from the repo, and it should be fixed for you.
  15. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I test it thank you.
  16. bruno1210
    bruno1210 schumi06
    103Coins
    For f1 22 what are the settings 20777 or 4123 and format 2018 or 2022 thank you
  17. yobuddy
    51,734Coins
    It patches it correctly with no need to change anything, or set anything manually in the game.
    It uses port 4123 and 2018 format.
  18. bruno1210
    bruno1210 schumi06
    103Coins
    Format 2022 ? shame
  19. levers
    1,032Coins
    Hi Yobuddy,
    I'm having issues with the integrated GameVibe in V3. I set up the parameters yesterday with ACC based on the settings from V2.5 and I managed to finally get it work. However, pressing test when setting each output in 'Vibration Editor' didn't show any sign that it was activated, I had to just try to move the slider. Also, there was no save button as far as I can see on that page as there is in V2. Going to the volume page there is a save there so I pressed that but again no acknowledgment the settings had been saved. The volume sliders didn't seem to do anything so I set the volumes in the 'Vibration Editor' page.
    I then moved on to DR2 and it crashed as soon as the game launched. I removed the Vibe settings for it and the game ran fine. Now ACC has lost the Vibe settings as well and trying it again it crashes. I've even had to remove the sound card in Interface Settings to get it to not crash V3.
    Am I missing something? Hopefully you can advise me, thanks
  20. yobuddy
    51,734Coins
    w00t!
    Yes, I will fix it up when i finish skinning.
    Yes, its set and forget (no save button needed)
    That's just the save as default (default settings for any new profiles for this game.
    Or save as global, default profile for any newly installed game plugins.
    The vibration editor lets you create the sounds.
    The volume page is the mixer for the game.
    So if you set rpm to 50 and and collisions at 100, the end output would favor collisions 2 to 1.
    Or collisions will be twice as strong.
    I'm guessing somehow you were able to turn on the sound tester and it stayed on and caused errors.
    But i will have to do some hunting to be sure.
    Maybe if you get a crash log you can post it here, it may tell me something.
    Hope the above helps.
    I'm almost done with 'start with windows' and 'auto game launch' detection.
    I will go over game vibe as soon as I'm done here buddy.
    Chat soon!
