SimTools v3 Public Beta
  1. yobuddy
    51,776Coins
    Unfortunately v2 plugins are only for SimTools v2.
    There is someone looking into updating the wreckfest plugin, but I have not heard anything yet.
    Take care!
  2. Arta Yasa
    Arta Yasa Member
    968Coins
    Okee sirr, so do u have tutorial to make a plugin for v3 sir??
    154,837Coins
    +11,227 / 57 / -2
  4. Richard Eaton
    Richard Eaton Member
    241Coins
    So I have updated as per your advise, however it seems the issue is with VR, if I load in standard mode it works, if I load in VR it doesn't work, any ideas.
    I'm using a Quest 2, connected via USB, F1 launches steam VR, the VR side is fine just no motion?
  5. yobuddy
    51,776Coins
    My guess is the game was not played in VR once before the plugin was installed?
    Please remove the game plugin, and then run the game in vr and finish a race, then close the game and re-install the plugin and you should be good to go.
    Take care!
  6. Arta Yasa
    Arta Yasa Member
    968Coins
    Hi sir the simtools not working when i start game outside ftom simtools sir?? I try playin assetto corsa from content manager sir, but the DOF not working sir. Or i wrong trik to play that sir??
  7. yobuddy
    51,776Coins
    You can drag-drop the shortcut (or exe) for content manager onto the banner for assetto corsa and you should be good to go.
  8. Richard Eaton
    241Coins
    Ahh I didn't realise it also needed to be completed in VR as well as normal, I'll give it a go and confirm. Have a great Christmas, thanks for all the work you have put into this.
  9. Richard Eaton
    241Coins
    That fixed it, thanks all working in VR, just need to get the motion tuned in now
  10. MatteKarla
    MatteKarla Member Gold Contributor
    10Coins
    If I change Min/Max Tunings under Motion settings by dragging the sliders, it doesn't save the settings. It works during the current session, but when I exit and start SimTools3 again the settings are reset do default. Am I missing something? the save-button is disabled.
  11. yobuddy
    51,776Coins
    I'll take a peek when I get to my PC in the morning.
  12. Majony_gijon
    Majony_gijon New Member
    27Coins
    3DOF, Motion platform
    I own the 2.6 license to use with my ProSimu 5DOF motion simulator with the PRS200. I would like to try the EA Sports WRC game using my ProSimu cockpit, but I only see the plugin for Simtools version 3.0. I have downloaded this version and installed the Demo (I have not validated it yet) to familiarize myself with it, but the change seems big. I don't see compatibility with the PRS200 (Yes with Thanos, SCN, HyperAxis, etc.) Is this V3.0 currently compatible with my ProSimu PRS200 as in V2.6?
    thanks
  13. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
  14. yobuddy
    51,776Coins
    Yes, we sent them their interface plugin ages ago.
    Contact them and they should have everything you need.
    (Buzz me if you have any problems)
  15. EduardoMoreira
    EduardoMoreira Member
    113Coins
    Yobuddy, wouldn't it be possible to add the possibility of changing the intensity of the profile through a shortcut during the game?
  16. VFX Pro
    VFX Pro Member
    Los Angeles
    472Coins
    Motion platform, 6DOF
    Reach out to support@prosimu.com. I'm using v3 with my 7DOF but you need their customized version.
  17. yobuddy
    51,776Coins
    Yes, but I could never add shortcuts for all things people have asked for, so it's best to make an addon api, and then a addon, for a remote profiler. We are currently going thru the code polishing up v3 for a proper release candidate. (And the v3 manual is 99.5% done for its first release also.) So we are close to getting on with some new things, I will for sure come back and look at a remote profiler for v3 when I can.
    Take care!
  18. yobuddy
    51,776Coins
  19. xidcrisisx
    xidcrisisx New Member
    Games
    Illinois
    - 28Coins
    Is anyone else having problems with Game Vibe in V3 since the last update? It was working previously in all my games, but now the bass shakers work on the settings page where you select your sound card, but when I click the test button when setting volumes per game it always crashes Sim Tools and they don't work in any games anymore, the motion is still working fine. Thanks
  20. xidcrisisx
    Games
    Illinois
    - 28Coins
    Seems all I had to do was disable and re-enable the vibe settings and they are all working again
