SimTools v3 Public Beta
  1. yobuddy
    51,771Coins
    Hi @Felix_31,
    I suggest configuring one DOF at a time. Start with Surge only maybe, and set Surge to use 40% of the axis for both 1a and 2a. Then give it a ride, does it work like you want it to? If not then adjust the Max/Min values for surge, smaller numbers for quicker feedback, bigger numbers to slower. (auto capturing the setting is an option also)
    Once Surge works like you want it too, then zero Surge out, and do the same for Sway. Once Sway works like you want it too, then zero Sway out, and do the same for Heave. And when Heave works like you want it too, try turning all 3 on for a ride. Maybe set Surge and Sway at 40% and Heave at 10 to 20% and see how the ride is.
    Take care,
  2. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
  3. Felix_31
    Felix_31 New Member
    88Coins
    Thanks yobuddy for the Fast reply and how can i save min max tunings? When i hit save, it will be saved, but when i turn off and than on the computer, there are the defaults.
  4. Felix_31
    Felix_31 New Member
    88Coins
    And Do you think i need pitch and roll or are the other enough?
    154,831Coins
    +11,227 / 57 / -2
    Your Axis allocations are pretty low, particularly for roll pitch and sway, try them at 25 and adjust from there.
    You will likely then need to capture and tweak the Max/Mins.
    The Max/Mins for surge can be a number less the 1, so try 0.5 and see if that makes it more noticeable.
  6. yobuddy
    51,771Coins
    Yes, the 3 will be fine buddy,
  7. Michail
    748Coins
    Hey everyone, can someone guide me on how to test the motion for games like Automobilista 2, Le Mans Ultimate, or others without actually being in the game? Does SimTools v3 offer a test mode beyond the DOF test in the axis allocation menu?
    My temporary solution has been to drive using a keyboard, but that’s hardly driving; it’s more about trying not to hit a wall.
    I’ve seen some YouTube videos where they demonstrate game motion without a driver.
    I’d like to closely observe the motion and the stabilizing rods to identify where a creaking noise is coming from.
    My second question: When driving with VR, the front lever occasionally reaches a position where the hall sensor overflows, causing the motor to move in the incorrect direction, which results in the rods bending. I’ve configured SMC3Utils with clip input and max limits, so I’m puzzled why the motor doesn’t shut off. Instead of stopping, it continues in the wrong direction and overheats because the rod cannot move any further.
  8. yobuddy
    51,771Coins
    With 'Live for Speed' you can play a replay of a previously finished race.
    I'm not sure how VR would change anything, but it sounds like the PID settings of the sketch may need adjusted if your having overshooting issues.
    Let me know how it goes buddy,
  9. Michail
    748Coins
    I mentioned VR because so I was blind… can’t look down to see what happened with the lever…
    I sett thenpower supplies to 21V
    fpid /3
    Kp 400
    Ki 0
    Kd 1
    Ks 1
    Fpwm 20 kHz
    PWMmin 10
    PWMmax 150
    PWMrev 200
    Max Limits 50
    Clip Input 200
    Deadzone 0
    154,831Coins
    +11,227 / 57 / -2
    See the FAQs here re games with replay telemetry: https://www.xsimulator.net/community/faq/stress-testing-telemetry-in-replay-mode.366/
    Overshoots indicate SMC3 refinements are needed.
  11. Michail
    748Coins
    If the lever overshoot and max clipping is reaching I think, that then will the Motor switch off until next reset and is out of max limits I thought.
    Thank you for the link with the replays
  12. noorbeast
    154,831Coins
    +11,227 / 57 / -2
    Clip and Max limits work together:
    Clip Input
    Used to create a band at either limit of the target range beyond which any values sent to the SMC3 are clipped. In addition to this clipping, if the motor feedback does move beyond this range (typically through inertia), the SMC3 will attempt to brake the motors hard by driving them in reverse until they are back out of this limit zone. The value can be anything from 0-255 (however can’t be less than the current limit setting). Reverse braking is applied in the band between the Clip Input and the Max Limit settings. Reverse braking can be disabled - refer to PWMrev.
    Max Limits Used to create a band at either limit of the feedback range beyond which if the motors move (typically through inertia) the SMC3 will automatically shutdown the drivers and keep them disabled until reset. This is essentially a safety mechanism if something goes wrong. The value can be between 0-255 (however can’t be greater than the current clip setting).
    With PID settings also impacting on how the hardware responds, here is a gentle layman's analogy introduction to PID: https://www.xsimulator.net/community/faq/a-laymans-analogy-guide-to-pids-pid-tuning.219/
  13. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 324Coins
    2DOF, 6DOF
    Happen Again, No issue with SCN Interface but same actuator behave like this when apply HyperAXIS Interface.
  14. yobuddy
    51,771Coins
    @Shige Tanaka,
    We were able to replicate the problem.
    A rebuild HyperAXIS plugin that fixes the jerky output is now online. :thumbs
    Thanks for the report!
  15. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    360Coins
    3DOF, AC motor, Motion platform
    I think I mentioned it elsewhere but perhaps this is the right thread for it. The Forza Motorsports Console plugin doesn't appear to work. It just causes random gyrations from the motors. I've been using the Forza Horizon 5 plugin successfully with Motorsports in the interim.
  16. Shige Tanaka
    FREX
    Osaka Japan
    - 324Coins
    2DOF, 6DOF
    I confirmed HyperAXIS plugin smoothly working with this fix. Thank you!
  17. Mr.TopGearMan
    Mr.TopGearMan New Member
    Russia
    - 113Coins
    Hello, I would like to consult with you. Tell me which of the settings is more responsible for the transmission of vibration from the road surface?
  18. Sin.Schumi
    Sin.Schumi Member Gold Contributor
    - 18Coins
    SCN5
    @yobuddy Sorry for the Delay, i have test it and it Works thx for your feedback
  19. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Heavie for sure, lower settings stronger feel
  20. Mr.TopGearMan
    Russia
    - 113Coins
    or maybe pitch rate?
