  1. eaorobbie
    20,506Coins
    Lol I found they put me off my driving and don't use them any more, lol a good toy to show friends, but serious racing , ya got a helment on , winds not much of a factor, unless as blazinh has it , like a twister in ya sim , rofl.
    Fun toy but they are.
  2. BlazinH
    16,697Coins
    I said it helps me with immersion, not necessarily realism. While those mostly go hand in hand, what makes people feel immersed varies.
    I originally set up a fan system to use with No Limits Coasters. But using one fan was not enough air for me so when I built a new rig I decided to incorporate three instead of just one. In the case of roller coasters at least, no one can deny that having air blowing in your face is both immersive and realistic!
    But the reason I still like to use fans for racing is it adds a non-visual method of sensing speed, which adds another layer of immersion that you don’t get otherwise. But if that puts off the since of realism for you, then it is obviously not for you!
    I suppose the only way to know if you like it or not is to try it for yourself! But, in my case, some air blowing at me makes me more comfortable most of the time anyway so I would rather have the air vary with the speed of my vehicle and give me some usable feedback as opposed to just having a constant speed blowing at me all the time.
    154,352Coins
    +11,179 / 57 / -2
    Oculus also differentiates between immersion a presence, the latter being where you know it is not real but your brain reacts as if it is, in other words as if it is real. Interestingly the 6 defining characteristics of presence in VR are technical attributes rather than being related to recreating reality: http://www.roadtovr.com/oculus-shares-5-key-ingredients-for-presence-in-virtual-reality/
    I consider that presence in motion simulation, particularly in VR, is likely to be about the quality of tracking and simulated motion cues representing 6DOF, low latency motion cues, for VR that is less than 20ms, for motion I suspect it is actual linear movement speed above 20mm/s, and high fidelity motion cues from a well defined motion profile and complimentary and accurate haptics.
    For me the main difference between motion simulation and VR is the actual tactile representation of the peripherals. And it is here that motion simulation currently has the edge. I don't think quality peripherals, including wind simulation, need to recreate realism, but rather contribute the sensations that allow the brain to suspend belief and respond as though the experience is real. So it is likely not about recreating a twister but more about defining a volume flow high enough and regulated accurately enough that it triggers an association. It would be interesting if 700cfm as @BlazinH has found is the threshold or the upper end for triggering such associations.
  4. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    @SilentChill
    I already used your code on my one channel defected MM with math at 6.2 but the fan couldn't reach his top speed limit, it need something around 8.0 but the MM shouts off when math is below 6.2 ..I think it needs more Ampere.
    I bought a new MM and wire as A1 B1 one lead of the fan A2 B2 to the other lead (as half bridge)but it didn't work. I rewire the fan to A2 B2 then it works.
    I checked the outputs of the new MM and it gives same voltage on both output...so the MM is working correctly.
    My question is: to which leads you wired your fan? A1 B1 or A2 B2 or as a half bridge?
    Thanks in advance for your help
  5. SilentChill
    20,602Coins
    I wired it up as two sides using both sides for the motors.
  6. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    Do you have two motors?
    Do you have an idea why as half-bridge it is not working?
  7. SilentChill
    20,602Coins
    I had 3 motors running 1 on one side 2 on the other.
    Have you wired it up correctly as in @Pit tutorial ?
  8. Pit
    30,512Coins
    If the MMs are not working as a half bridge, please check first each output itself using the standard h-bridge mode.
  9. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    The @SilentChill Arduino code pin outs are different, that's why it is not working. I pulled back my MM from Arduino board and wire it as Half-bridge configuration with different pins. Now it works but same issue happened...
    My fan stopping for 1-2 sec at full speed then come back if Math is set more then 6.2
    But the problem is that for reaching the full speed capability of my fan I need to set more then 6.2
    I tried two MM that's Works fine....I think that something is limiting the full speed output.
    Any advice?
  10. SilentChill
    20,602Coins
    @Mamati what game are you trying to use it on ??
  11. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
  12. SilentChill
    20,602Coins
    I think you have other issues going on as it should be hitting the full "255" which would be full load. Perhaps when the Math is to big it is going past 255 and the reading does not get sent to the MM ?? I dont know really but just guessing.
    Have you tested the voltage and pause the game on a fast part of a coaster to see what it is outputting ??
  13. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    @SilentChill Thank you for your reply.
    I believe you are right...maybe it is passing 255. I didn't check the output voltage and I won't be able to check it before 24th because I am on vacation :)
    But do you have an idea about math setup? what can I use for reaching the max output voltage without cutoff?
  14. lcturkey
    lcturkey Member
    163Coins
    hi to all,
    I am using RacingMat's 2 dof code, to add a windfan on it do I need to use another Arduino and motor driver ? thanks for the code @SilentChill
  15. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    You need a seperate Arduino and Motordriver for Wind.
  16. lcturkey
    lcturkey Member
    163Coins
    thanks for the answer @tombo . Doest two arduino work on the simtools at the same time ?
  17. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    You can use more than two arduinos at the same time in simtools as different interfaces.
    But you need to use it with gamedash.
    Look at the first page of this topic. SilentChill added some pictures and a very good explentation how to setup your arduino in Gamedash.
  18. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Hello
    Very nice idea with the fan control. I'm going to try as soon as possible, but can anyone tell me how to configure this thing? I downloaded Ardu code and the gamedash, but no clue what next. The pictures on the first page do not show ;(
    EDIT, ok, now the pictures are back, maybe some hosting was down... but still don't know how to get to Command Editor
  19. SilentChill
    20,602Coins
  20. MiNeM
    MiNeM ..........
    Self Employed
    Johannesburg
    333Coins
    This would work awesome once i setup my motion rig and oculus :)
