  1. yobuddy
    51,741Coins
    I thought your were using different hardware?
    https://www.xsimulator.net/communit...-with-arduino-sketch.17963/page-2#post-243250
    But if your running the sketch above with a Adafruit Motor Shield V2, then you would want to add these two commands for speed. (click the pencil to add the commands)
    Map 0 100 0 255 (you can change the 100 value to your desired top speed)
    Pad 3 0
    And this will make speed output always have 3 char's for output - 000 thru 255.
    And then make sure to send S<Sp1> as you were, and you should be good to go.
    Take care!
  2. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    I did use different hardware but didn't work so switched to this new project :)
  3. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    Yes it works, !
  4. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    Any suggestions how to reduce the speed of the fan's when the rollercoaster moves slowly. When the rollercoaster starts moving the output voltage is 11.58 volf (the powersupply and fan's are 12 volt)
    during the ride the fan's slow down and speed up. It looks like the values are reversed. The slower the car is moving the fan's spin faster
    @yobuddy
  5. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    Hi what do I have to change to invert the behavour of the fan's? I have No Limits 2 and when the car is veryslow forward the fan's blow full speed and when the car is going faster the fan's slow down.
    thanks for any help
    Hans
  6. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    Found it :- you must add Round 0
  7. evolaco
    evolaco Member
    Spain
    694Coins
    Hi, I want to make a wind simulator with two 24V Seaflo 270cfm fans, an IBT2, an Arduino Mini, a 24V 9A power supply (the unboxed boards sold on AliExpress), and I want to use it with SimHub. Do I need the inductors? I only find 100uH in 6A, and I only find 3A in 470uH. Will the 100uH ones work, or is it not necessary with the IBT2 and SimHub? I made a wind simulator with 12V 80W car radiator fans with IBT2 and SimHub, and I didn't need any inductors. They work directly without any problems. However, I don't know if they are necessary with the Seaflo fans, for some reason I don't understand.
    Although I understand that at 24V, 3A would be enough, although I have found 470uH. But why are they really needed? How will I know they're necessary when testing the Seaflos?
  8. SwedeSen
    SwedeSen New Member
    40Coins
    Are you all running your blower fans at 12 V?
    I heard these marine/automotive blower fans are usually good up to somewhere in the 13.8-14.4+ V area...
