simulateur 3 dof heave, motor 350w 24V
Discussion in 'DIY Motion Simulator Projects' started by willaupuis, Apr 7, 2016.
  1. willaupuis
    willaupuis Member
    1,864Coins
    3DOF, DC motor, Arduino, 4DOF
    wanegain thank you to answer in my absence
    photo de l'avancée du projet
    Photo of project progress
    amélioration de la connectique moteur
    improved motor connectors
    perçage et boulonnage
    drilling and bolting,
    I hope to make videos today, so yes, I diffuserais Video
  2. willaupuis
    willaupuis Member
    1,864Coins
    premier essais de fabrication du support volant
    first the wheel support manufacturing test
    ce n'est pas très beau, mais je pourrais tester le full mobile
    it's not very nice, but I could test the full mobile
  3. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    Thanks very much.
    Is plastic gearbox less noise than metalic? If the motion sim too noisy my wife will smash it...
  4. willaupuis
    willaupuis Member
    1,864Coins
    so much less noise is quieter.
  5. willaupuis
    willaupuis Member
    1,864Coins
    je n'aime vraiment pas le tout mobile, le point central de rotation se trouve à l'entre jambe et le fait que les pieds descendent et le dos remonte me perturbe énormément:
    -en descendant il faudrait que seul le moteur avant s'incline ainsi le point d'inclinaison serait au niveau du dos,
    -en montant: seul les moteurs arrière descendent. ainsi le point d'inclinaison serait quasi au genoux
    ça veut dire encore des tests
    I really do not like all mobile, the central point of rotation is located between the leg and the fact that the feet go back and back disturbs me greatly:
    - Down would have only the front engine and tilts the tilt point would be at the back,
    -in amount: only the rear motor down. and the point of inclination would be almost to his knees
    it still means test
    the noise comes from the pedal that is not set
  6. Nick Moxley
    17,057Coins
    Could you show a Real Race track video ? IMO blackfoot or w/e its called lacks in overall surface detail (except the old part of the road) and overall is hard to follow the Pedal/wheel/Axis settings. I want to see a BIG breaking moment from 250+ also some long Full Throttle turns to see some sway and maybe roll some Saw tooth kerbs to show off some of the heave.
  7. willaupuis
    willaupuis Member
    1,864Coins
    I will try to do so, I must see if I have the track
  8. willaupuis
    willaupuis Member
    1,864Coins
    une nouvelle vidéo avec un test entre le "full mobile" et le "semi mobile" et je préfère le "semi mobile", je ressent mieux les effets
    a new video with a test between the "full mobile" and "semi-mobile" and I prefer the "semi mobile," I better feeling the effects
    the wheel is loose so it moves
  9. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    Salut @willaupuis , je l'ai déjà contacté le vendeur vous proposez, on m'a dit que le bruit du moteur est d'environ 75dB qui est trop bruyant. Mais à partir de votre vidéo semble le moteur pas si bruyant (peut-être le son de jeu couvrir le bruit du moteur). Habituellement, je joue à des jeux avec un casque, donc je suis toujours inquiet ma femme serait en colère contre le bruit du moteur. Pourriez-vous s'il vous plaît enregistrer une vidéo juste le bruit du moteur sans son gaming? Merci beaucoup.
    Hi @willaupuis , I already contacted the seller you suggest, they told me the noise of motor is about 75dB which is too noisy. But from your video looks the motor not so noisy(maybe the gaming sound cover up the motor noise). Usually I play games with headset, so I'm still worried my wife would be angry with the motor noise. Could you please record a video just the motor sound without gaming sound? Thanks very much.
  10. Wanegain
    Wanegain Active Member
    Bruxelles
    2,013Coins
    @Racing Mike with plastic gear they are really silent.
    I will probably post a video soon showing them in action with no load.
  11. willaupuis
    willaupuis Member
    1,864Coins
    racin mike: dans la vidéo que je poste, a la dernière minute le simu fonctionne sans le son du jeu donc tu pourras remarquer que l'ensemble est silencieux.
    vidéo qui montre les moteurs arrières qui gère les effets : sway et pitch et le w seat en fonctionnement qui gère le surge
    video shows the rear motors with the dof: sway pitch and roll and the w seat working with the surge effect
  12. willaupuis
    willaupuis Member
    1,864Coins
    une autre vidéo qui montre une vue d'ensemble, le grincement qu'on entend par moment provient du support volant qui n'est pas fini. il n'y a pas d'image car je joue dans le casque htc vive
    another video that shows an overview, the creaking we heard comes from steering wheel support which is unfinished, there is no picture of the game because I play with "htc vive"
  13. francois38200
    francois38200 Member
    vienne
    195Coins
    realy nice vidéo :thumbs
  14. willaupuis
    willaupuis Member
    1,864Coins
    une astuce pour jouer avec le vive sur avec le simulateur (à partir de 2'48)
    a trick to play with the htc vive on the dynamic simulator (from 2'48)
  15. Fluke
    Fluke Member
    Stafford, United Kingdom
    822Coins
    Whats is the maximum total weight that a set up can lift and move when using these 350w motors?
  16. Wanegain
    Bruxelles
    2,013Coins
    Maximum we tested was about 160kg.. We did not try with more weight...
    you can watch this video :
  17. willaupuis
    willaupuis Member
    1,864Coins
    Thank you Wanegain, you were faster than me
