Simulateur 3dof any mobile + wseat 2 ou 3dof
Discussion in 'DIY Motion Simulator Projects' started by zigzag49, Aug 25, 2016.
  1. zigzag49
    zigzag49 Active Member
    726Coins
    A video of the simu, there is that roll pitch and heave, I wait for an order to continue on the seat.
  2. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    I really like the responsiveness of the heave effect, I should have gone that way... :(
  3. zigzag49
    726Coins
  4. zigzag49
    726Coins
    Beginning of the prints for the linear guides, the rods and bearing make 16mm its will be used for the seating therefore the effect surge.
  5. zigzag49
    726Coins
    Il me faudrai une plus grande table:grin
    I will need a larger table:grin
  6. zigzag49
    726Coins
    Its continuous, fixing the bearings on a composite plate, like the one seen in public showers.
    Cutting the two flat iron that crossed the seat to leave room for the sliding tray.
    To see for the engine because it will be found under the plate.
    Sway sliding tray with backrest.
    J'ai doubler le bas du baquet de mousse pour avoir un meilleur appui au niveau des lombaires.
    Set of parts for linear guide.
    Continuation of the slide / back, remains to see or place the engine and can be added a curved form of each side pure to drive the bust.
    Cutting the plate for the passage of the crank, I have to make an extension so that the rod protrudes from the plate.
