News Simulator 2 dof progress for beginners !!!
Discussion in 'DIY Motion Simulator Projects' started by RENZOREY18, Apr 30, 2019.
  1. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    English
    TRADUCTOR GOOGLE:
    friends here I leave another video with the simulator mounted and doing the first tests. As you can see for this design I will need more powerful engines since these lack power. In the previous design I had the same fault and I still didn't change the engines
    amigos aqui les dejo otro video con el simulador montado y haciendo las primeras pruebas.Como podéis observar para este diseño necesitaré unos motores mas potentes ya que a estos les falta potencia. En el diseño anterior tuve el mismo fallo y aun no cambié los motores
  2. chavilap
    chavilap New Member Gold Contributor
    Córdoba, Spain
    - 2Coins
    Hello RENZOREY18,
    Perhaps I am not the best one to comment, it is the first time that I intervene in the forum.
    But I dare to assure you that those engines are going well. The problem is that the structure is not well balanced. You should separate the motors more from each other, and thus avoid the lever effect; In addition to looking for the seat, it is balanced in its '0' position. I hope I have explained myself.
  3. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    hello friend @chavilap,
    Thanks for your good advice, I have long since corrected the problems I had with gravity and structure, I think this is the third time I have completely disassembled and changed my 2dof. As you will see, I have somewhat abandoned my conversation with the progress of my simulator due to lack of time, but then I will upload videos of the tests of my latest version.
    thanks and I hope to have you in the thread greetings !!
