SimXperience II - 2DOF Driving Simulator With SCN5's
Discussion in 'DIY Motion Simulator Projects' started by bvillersjr, Nov 26, 2008.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    @Fahim...thanks for the compliment... I hope that you are right and that many people will be interested. I have alot of time and money wrapped up in creating a low-cost Frex alternative. I'm only a few short weeks away from making the SimXperience DIY Motion base available for initial orders.
    Aside from purchasing the entire DIY motion base kit, there will be two different part numbers for the actuator covers with built in dampeners. One for the 100mm actuators and one for the 150mm actuators. No SCN6 covers will be manufactured in the first phase.
    I hope by shaving about $1000 off of the price of a Frex and offering a superior product (both by design and because it incorporates X-Sim) that more people will be able to participate in our hobby without having to build each and every piece themself. Not everyone has the ability to weld, or solder etc..
    :cheers:
  2. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
    Good Stuff bvillersjr!! I have been reading posts on this site for more than three months now, and I must say, each time I keep finding new good stuff.
    Please do let us know when you'll have these actuator covers + dampeners available.
    Thanks!
  3. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    Can you tell me where you have found the good drivers for the devantech usb/rs485 adapter ?
    I've made the same wiring that this picture :
    And i dont see the scn5 in the profiler.
    N.Ruas
  4. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    With the debug mode on, i ve response of SCN5 on com3 but incorrect !
    What do you think ?
    Driver problem ?
    Helppp ;)
  5. bvillersjr
    Ohio, USA
    438Coins
    The drivers are obtainded from the FTDI site: http://www.ftdichip.com/Drivers/VCP.htm
    Try one actuator at a time.
    Make sure that you have 24V+ to the kill pin and try reversing the TRx+ and TRX-. It is safe to try reversing only these two.
    NEVER reverse the VCC+ or VCC-!!!
  6. njracer
    njracer Member
    2Coins
    Hey Bernard any chance of showing off your sim with that 3rd axis??
  7. bvillersjr
    Ohio, USA
    438Coins
    Soon. I need to finalize a few decals and remove a few goodies that I would prefer my competitors not see yet, then I can make some new vids.
  8. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    Thanks for these tips,
    I've tried inverting Trx+ and Trx - and nothing appear in the list of actuators same error message appears ...
    I'm desperate !!
    The Devantech converters are new, the power supply makes 24v and 4.5A ...
    Do i have to keep the Zener Diode and resistor ?
    What about the internal 5V optional ?
    Is there another wiring to do ?
    Thx
    Nico
  9. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    Thanks, i'll test,
    I'post when i try...
  10. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    After a pause i'm retrying to detect my actuators ...
    Here a picture of the devantech i use, the drivers i use are FTDI 2.6.0.0 from the 22/10/2009.
    I've the same problem than TOKTINY, the same comport number and in the debug mode the same responses :
    1. “Try to scan SCN5 #0 on COM 3”
    2. “Response from SCN5 #0 on COM 3”
    3. “Response is not correct from SCN5 #0 on COM 3”
    4. “Try to scan SCN5 #1 on COM 3”
    5. “Response from SCN5 #1 on COM 3”
    6. “Response is not correct from SCN5 #1 on COM 3”
    This cotinued until SCN #15 on COM 3 and then moved onto exactly the same procedure for COM 4 with the same results.
    By the way it scanned COM 1 as well but it was slightly different as follows ;
    1. “Try to scan SCN5 #0 on COM 1”
    2. “No Response from SCN5 #0 on COM 1” (Obviosly it knows that COM 1 is not to be used)
    This was repeated until SCN #15 with the same answers.
    My comports parameters are : [​IMG]
    after trying a ot of combinations !
    where can i change the Half or auto parameter of my adapters ?
    thanx
    Nical
  11. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    Thanx Sirnoname,
    I'm searching where i can have errors or bad parameters,
    I've read the hardware an software thread, but they dont talk about the exacts parameters for using the devantech adapters.
    I've lauched the serial port monitor and opened the profiler i've that :
    And my actual Scn5 plug settings are like that :
    I've tested others, and there is all the time the same message in debugmode : Response is not correct from SCN5 #0 on COM 3”
    I will try to get others adapters which are not auto
    what do you think of that ?
  12. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    I've my 2 devantech adapters connected like that,
    The 2 ones send the same response in the serial port monitor. i scan the com3 and com4 its the same screen.
    I've checked many times the wiring,
    is it possible that i've to use smallers usb wires ?
    because i haven't 120ohm resistor today, just 20 * 2,2Kohm !
    I just want a response from my actuators :? i've spent a lot of time and nothing new !
    and with my bad technical english i can have no see an important basic parameter.
    Do you wath another print screen of any page of the profiler ?
    thanks
  13. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    I've tested with shorters usb cables and too with the firsts ones
    the loopback,
    I ve a response in the two ways ...
    I'll continue tomorrow,
    after a good night i can have new ideas !!
  14. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    Windows hyperterminal too :
  15. bvillersjr
    Ohio, USA
    438Coins
    Two actuators cannot exist on the same COM Port unless the device ID is changed on one of them.
    Please show us a screen shot of the Ports section of your device manager when both USB devices are plugged in. We need to be sure that two different virtual com ports are shown there.
    Please try the following:
    -Run X-Sims registry cleaner from the c:\program files\x-sim\other stuff folder and delete everything that the cleaner will allow.
    -Close the force profiler and force sender
    -Unplug one of your adapters and actuators.
    -Reboot your PC and enter BIOS. Disable your motherboards COM port in your BIOS settings if there is one.
    -Save your BIOS settings and restart (usually F10)
    -Try opening the force profiler with only one adapter and one actuator plugged in.
  16. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Nical,
    Sorry, I didn't read everything.
    But, since you are using the same adapter I use, have you tried these settings I show here?
    how-to-convert-your-frex-scm-to-x-sim-t1412.html
    After it is working, changing your switching time to 0 should give you speeds around 200-250o/s!
    Try to attribute lower ports numbers, like 3 and 4...
    Cheers,
    MY
  17. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    here i's my com port config :
    I've The virtual Com3 with One adapter and one actuator,
    and the virtual com4 with the second adapter and the second actuator.
    I've tested the x-sim reg cleaner, Désactivate the integrated com1, unplugged 1 actuator.
    Launched the profiler, and miracle, it moves !!
    but nothing when i retry with the 2 ones ...
    I'm going to check all that you said to me.
    really thanks for help.
    I'll win !!
    I'll post photos of the cockpit soon
  18. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    Yes,
    The two actuators work well,
    After the registry cleaning, i can see the two actuators in the profiler.
    Let's finish the metallic part of my simin order to test that.
    Really thank for your help ... :yes: :cheers:
    I'll be back.
    Nical
  19. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Great news, Nical!!!
    Wondering what was wrong, then!? :)
    BTW, with Serial Printer enabled, I noticed that the output speed oscillates too much.
    Everytime I look it is some different speed.
    I prefer to disable it, you may have a lower speed, but at least it is more stable.
    Test it for yourself and report back.
    Cheers,
    MY
  20. nical
    nical New Member
    Network Technician
    Avignon, France
    300Coins
    I continue the metallic part,
    In a week it will be finished, i'm curious to test it :yes:
    I think it was the integrated com1 disabled or the green and white cable that i've inverted or too the x-sim regclean which had unlocked my profiler !!
    I have test these 3 things in the same time and after it work !
    It dont know really what unlock my problem, but the regcleaner is a great tool :thbup:
    Thanks.
