Slow Forum Navigation
Discussion in 'Forum and Website' started by Blame73, Jan 4, 2017.
  1. RaceRay
    23,891Coins
    Thanks, its fixed. It just takes a hour or so until all pages are running with full speed again
  2. obobo
    obobo Active Member
    1,323Coins
    Super, because browsing in 56Kbps mode is limited to read 80 posts
    What is the reason for this global slowdown ?
  3. RaceRay
    23,891Coins
    Our mysql server needed a change of the bin log format to allow row based replication when needed. That's one of the reasons why became very slow after some time.
  4. Blame73
    Blame73 Well-Known Member
    8,315Coins
    You can count on us on reporting it! :thumbs
  5. Blame73
    8,315Coins
    Today's slower than ever
  6. RaceRay
    23,891Coins
  7. RaceRay
    23,891Coins
    ok, you are right, something is going on. I fix it
  8. Blame73
    8,315Coins
    C:\Users\Davide>tracert www.xsimulator.net
    Traccia instradamento verso www.xsimulator.net [178.63.100.131]
    su un massimo di 30 punti di passaggio:
    1 1 ms 1 ms <1 ms dsldevice.lan [192.168.1.254]
    2 7 ms 6 ms 6 ms static-213-205-52-57.clienti.tiscali.it [213.205.52.57]
    3 7 ms 5 ms 5 ms static-213-205-63-17.clienti.tiscali.it [213.205.63.17]
    4 14 ms 16 ms 15 ms static-213-205-13-133.clienti.tiscali.it [213.205.13.133]
    5 27 ms 24 ms 24 ms static-94-32-135-246.clienti.tiscali.it [94.32.135.246]
    6 24 ms 26 ms 29 ms static-94-32-135-181.clienti.tiscali.it [94.32.135.181]
    7 147 ms 60 ms 156 ms ae3-300.cr0-trn3.ip4.gtt.net [77.67.82.229]
    8 * * * Richiesta scaduta.
    9 33 ms 34 ms 34 ms hetzner-online-gw.ip4.gtt.net [77.67.76.142]
    10 38 ms 38 ms 37 ms core21.hetzner.de [213.239.245.217]
    11 38 ms 39 ms 38 ms ex9k2.rz12.hetzner.de [213.239.229.242]
    12 38 ms 37 ms 37 ms xsimulator.net [178.63.100.131]
    at point 7/8 something's going wrong
  9. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
  10. RaceRay
    23,891Coins
    I had to deactivate the post count option from the new post button: http://take.ms/GoGP2
    This leads to very heavy database calculations.
  11. Blame73
    8,315Coins
    Can't you run a scheduled job that empties log / clears caches or whatever you need it to do?
    What server are you running? SQL Server? MySQL?
  12. RaceRay
    23,891Coins
    A cron job would not help here.
    The problem is that the counter plugin uses a lot of joins in its queries. This needs several seconds for execution for every user. The more posts we have and the more user are logged in the longer this query needs.
    If you say this feature is valueable and a must have for you i can check if i am able to cache this db query for a few minutes.
    So than only one time in x minutes this expensive query is executed and not on every pageload.
    Yes, its mysql.
  13. obobo
    obobo Active Member
    1,323Coins
    Is it possible to make the button "new posts" change color if there are new messages, no matter how many?
    It makes it possible to know instantaneously and at a glance that there are new messages
    est il possible par contre de faire que le bouton "nouveaux posts" change de couleur si il y à de nouveaux messages, peu importe le nombre ?
    ça permet de savoir instantannement et d'un coup d'oeil qu'il y à des messages nouveaux
  14. Blame73
    8,315Coins
    There always are new messages :grin
