  1. Doomak
    Doomak New Member
    22Coins
    if I press stop in SimHUB and press play again, I make it seem like I'm restarting (without disconnecting the USB), then the engine is working fine. And sometimes the engine freezes out of the central position, the green line is not in the center, if I turn the potentiometer, the lever moves, but the center is not in the zero position... it's not related to electronics, it's something in the firmware or settings, I guess..
  2. Joe Cortexian
    Joe Cortexian Active Member Gold Contributor
    1,429Coins
    Generally the Arduino resets when you reconnect the serial port. You might verify by pressing the Arduino reset button to see if that clears the issue.
    Can you reproduce using SMCUtils? There is a check in the codes which trips if it gets a single unexpected encoder reading. This will turn the motor off and you can see that in the SMCUtils screen. I had that problem with a generic Arduino. Noise on the sensor input could also cause this.
    Another possibility is that the ibt-2 or PSU has shut off due to momentary overload or glitch. I have this problem occasionally but it clears when I cut 24v power to the drivers. I have my estop turn off the 24v power so it’s a minor inconvenience. It happens based on how hard I push the limits of the drives. In general reproducing with just SMCUtils makes it easier to debug. I had a similar issue that I could reproduce using the “Motion” pattern even when the drive was disconnected from the rig.
  3. plomo29
    plomo29 New Member
    - 14Coins
    2DOF, 3DOF, DC motor, Arduino, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    Hello this works in Arduino Mega?
  4. Joe Cortexian
    1,429Coins
    If it builds it should run. If it doesn’t build then you will have to fix it.
    153,001Coins
    +11,116 / 56 / -2
    SMC3 was written for the Uno.
  6. Opast
    Opast Member
    Chicago, USA
    172Coins
    3DOF, Arduino
    Attached easy and simple guide for smc3 PID calibration. Only correction to the guide should be the following:
    • Step 1: Tune Kp (Proportional) FIRST with Ki = 0, Kd = 0
    • Step 2: Tune Kd (Derivative) SECOND with final Kp and Ki = 0
    • Step 3: Tune Ki (Integral) THIRD with final Kp and Kd values
  7. OrtiMai
    OrtiMai New Member
    75Coins
    Does your tutorial refer to clean SMC3 or to the one with @Sebastian2 's I-component fix?
  8. Opast
    Opast Member
    Chicago, USA
    172Coins
    3DOF, Arduino
    Only use SMC3 to set up PID, and it doesn’t matter which SMC3 variant.
  9. OrtiMai
    OrtiMai New Member
    75Coins
    Well, with Sebastians fix, the I-component now gets the deviation of the error as input and not the deviation of position. Thus, the principle in your tutorial stays the same and your tutorial is very helpful. But one have to be carful with the values.
  10. Sebastian2
    Sebastian2 Active Member
    459Coins
    @Opast
    I respectfully disagree.
    The vanilla SMC3 code has a buggy PID implementation. The I and D component are basically broken.
    You can test that by turning off your motors and demanding a motor position in SMC3utils thats different from where they are currently at. With a Ki-value > 0 this should result in a PWM-Output thats growing over time. But that doesn't happen.
    A similar test can be done for the D component by turning your motors off and turning on the sine signal generator in SMC3utils. For Kd-values > 0, the PWM-Output should be max every time the sine singal goes through 0 and PWM-Output shoud be 0 everytime the sine signal reaches it's max and min value. Again, that doesn't happen.
    Without a working I and D component, it doesn't make sense to try a calibration for those components.
    My SMC3-version is the only one I know of that hase a working I and D component. I don't recommend flogging to the version I uploaded in this thread a few pages ago, though. This version wasn't perfect by all means. For example: Back then I wasn't aware of a bug of vanilla SMC3 where it was possible for the I component to move the rig way past Clip Input and Max Limits. This bug never bothered anyone, as the I component was broken anyways. But I came across it after I tested my version with fixed I component.
    I fixed those bugs and now spend many months without issues with my latest version of SMC3. I attached my latest version to this posting. But be warned: I only tested it on my rig. Like vanilla SMC3, the executed code is different depending if you choose Mode 1 or Mode 2. For my rig I added a Sub-Mode for Mode 2, that is using a Cytron MD30C motor driver. I was only able to test that. I also tried to bring regular Mode 2 as well as Mode 1 to the same standard, but I have no way of testing.
    Edit: User @OrtiMai seems to by giving this SMC3 version a try with Cytron MD13S drivers that require Mode 1. He instantly found multiple typos that prevented the code to compile and upload to the arduino. So I guess it's not plug and play for Mode 1 users right now. I'll try to work out the kinks with him and post an update when its done.
    Edit: User @Andrey Av successfully tested my code with IBT-2 drivers in "regular" Mode 2 (instead of the Cytron MD30C version of Mode 2). Just make sure to set SoftOff = false if you don't have a switch connected to the analog pin documented in the comments of the code.
    This version also has SoftOff and SoftStart and a working "LiftOffset" to help rigs with a heave axis get smooth motion during slow movements.
  11. Opast
    Opast Member
    Chicago, USA
    172Coins
    3DOF, Arduino
    I only posted a general guide how to setup PID and numbers just for references from ChatGPT. I'd love to try your firmware and should I use your firmware from page 1 modified by you from 1.0 or Cytron? I'm using IBT_2
  12. Sebastian2
    459Coins
    I'm not sure what you are asking me about.
    If you want to try my SMC3 version, you should use the latest, so the one I posted today on page 137 of this thread.
    Or are you asking me what Mode you should use in my SMC3 version? The same as in vanilla SMC3. What mode did you previously use on your rig? The vanilla SMC3 documentation says "typical H-Bridge" should use Mode 1 and "Chinese IBT-2 H-Bridge from e-bay or equivalent" should use Mode 2.
    If you happen to use a Cytron MD30C motor driver like I do, you should choose Mode 2 and set cytron = true.
    However, all this is documented in the code. Have a look at it. I'm glad to help with any remaining questions.
    @noorbeast
    Could you please update the link in
    https://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    to the version i posted above? Thanks.
  13. noorbeast
    153,001Coins
    +11,116 / 56 / -2
  14. Andrey Av
    Andrey Av New Member
    63Coins
    Hello. I'm building 2DOF platform for MSFS mostly but also going to play LFS.
    It is Arduino Uno with SMC3 mode2, 2x IBT-2 drivers, 2x 24V 250w 75rpm 32Nm motors, 2x 24V 21A PSUs.
    Now I'm on the table test stage. When I run SMC3Tools sine I see that the motor reaction is pretty jumping:
    The yellow pwm line goes up and down and the crank moves by steps when stable rotation of the crank is expected.
    Another problem is that in Motion simulation mode when crank changes its rotation direction the motor consumes huge amount of power and my PSU flashes its led and stops its fan for a moment. I tried to limit pwm change speed in the SCM3 firmware, it works in general but conflicts with PID regulator and doesn't help much.
    Tried to limit voltage (21V is minimum for my PSUs), decrease the pwm frequency to 15kHz - the same.
    Also tried powerful 24V LiFePO4 battery instead of PSUs but sine movement is still jumping.
    Setting Kp to 100 and Kd to 20 helps a bit but PSUs are still experiencing problems on fast rotation direction changes.
  15. noorbeast
    153,001Coins
    +11,116 / 56 / -2
    Try setting Fpwm to 25.
    Then, as per the SMC3 initial setup steps, at what PWMmax value did the motor start to move?
    1. Disconnect the motor power supply
    2. Make sure Simtools is not running – we’re not ready for that yet!
    3. Wire up the Arduino (with SMC3 installed) to your H-Bridges and connect to your computer via USB
    4. Run the Windows SMC3 Utility software and make sure it communicates with the Arduino (There is no need to set baud rates, they are not configurable)
    5. Set the Kp, Ki, Kd, PWMmin, PWMmax, PWMrev to 0 for ALL motors (This will make sure the motors don’t move)
    6. Set Clip to 255 (you need to do this first) and Limit to 255 (This will give you plenty of margin if something goes wrong while setting up)
    7. Turn on the power to your motors – nothing should move at this stage!
    8. Set Kp to about 400
    9. Now slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
      • If it is then that motor and feedback is wired correctly - proceed to test other motors.
      • If it is moving away turn off motor power immediately (or quickly reduce PWMmax again). In this case you need to either reverse the wires to the motor being tested –OR– reverse the +5V and GND wires to your feedback pot for the motor being tested (do not do both). Restart the test from the beginning.
    10. Do the above for each motor
  16. Andrey Av
    63Coins
    All Fpwms 15-25 kHz behave the same, below 15 kHz motor starts to produce noise.
    As for pwm - it is starting moving at about pwm 38.
  17. Sebastian2
    459Coins
    Reversing the direction of rotation causes regenerative voltage, which causes the overvoltage protection of you PSU to kick in.
    Ideally, you need to find a way to handle that regenerative energy. There are multiple ways to do it - shunt resistors, batteries or diodes (maybe I missed something).
    You can also try to reduce the regenerative energy by reducing PWMmax. Of course, this also limits the power output of your motors.
    About the "jumpiness" of the motion. Is there lots of backlash in your mechanics? Can you reduce it in any way?
    Also: try a lower Kp value. The motion might get less reponsive, but it could be that you only need to accept a slightly less responsive system while getting one that moves much smoother.
  18. Andrey Av
    63Coins
    Could you please point me to simplest methods of handling regenerative energy (shunt resistors or diodes most likely)?
    Backlash looks pretty small - I can hear it a bit by moving the motor with my hand but can hardly see that.
    Eventually I stopped on Kp=100 and it behaves better while I still see some noticable jumpiness, but I think I can live with that - maybe it will become less on real platform under a load.
    I also read about misimplementation of PID in the original SMC3 firmware, and tried your latest firmware "SMC3_Cytron_MD30C_Blame73_Sebastian2_v7.5" but it looks like it is not compatible with IBT-2 even in MODE2 - the motor behaves strange and do not really follow the desired position. Maybe I'm doing something wrong.
    UPD found that I can put something like tvs supressor 5KP33A in the battery inputs of IBT-2 - easy to try, will do.
  19. Sebastian2
    459Coins
    I'll write you a PM about getting my SMC3 version to work with your rig. It's likely a bug in the code as I can not test regular Mode 2 or Mode 1 on my rig (only modified Mode 2 for Cytron MD30C driver). Hopefully we can sort this out, so the working I and D component becomes accessible to more people.
    About handling of the regenerative energy for a DC motor. I know about 4 options, all of which have disadvantages. Pick your poison:
    1. The most technically elegant and simple to implement option in my eyes is a Sabertooth 2x32 motor driver. Besides beeing a powerful, reliable motor driver, you can simply add a high load resistor to the appropiate terminals. The driver takes care of sending that regenerative currents through the load resistor, which turns that energy into heat. Done. Disadvantage: The Sabertooth driver is expensive.
    2. Recreate what the Sabertooth does, by using a suitable shunt regulator. You need to put it in parallel to the voltage supply connected to your motor driver. This is what I did. The issue: I was not able to find a suitable shunt regulator that works without modifying it first. I needed to remove a SMD resistor and add a load resistor as well as a potentiometer. Then I needed to set the potentiometer so that the shunt kicks in at a sensible voltage. I also had to experiment on what resistance value to use for the load resistor. Here you can read more about that: https://www.xsimulator.net/community/threads/my-3-dof-with-heave.18449/page-2#post-247677
    Disadvantage: NOT plug and play. It costs time to set things up right.
    3. Batteries. Put big batteries in parallel to your PSUs. The regenerative currents will charge the batteries. On load spikes, this stored energy will help drive the motors. Disadvantage: costs a lot of space and isn't really cheap either. I'd hesitate to use Li-based batteries for this, as they are quite picky regarding charging conditions. As far as I know, Pb-based batteries are more robust in this regard.
    4. Put a suitable diode in parallel to your voltage supply. This is an example thread with people talking about this: https://www.xsimulator.net/community/threads/power-supply-tripping.13110/ . I am under the impression that a lot of people do it this way, as it's quite cheap and simple to do. However: to me this is not a technically sound solution. The regenerative energy gets trapped within motor and driver. It has nowhere to go. This should cause the voltage rise to levels way, way past what those parts are designed for. I am surprised to hear that this works - I would expect the driver to burn up. I've not heard of events like that, though.
  20. Andrey Av
    63Coins
    Thanks, I think I will start with a tvs supressing diode first - easy to check and pretty cheap.
